ksrenjith <renjith.rohin@gmail.com> [13-02-07 05:32]:
Hello All,
I am a newbie in Linux world. I am trying to build the kernel for my
Beaglebone a5. The make command gives an error : line 61: warning:
here-document at line 24 delimited by end-of-file (wanted `EOF')
/scripts/mkmakefile: line 62: syntax error: unexpected end of file
I did some googling to solve this problem and I got information that the
change was probably introduced with the new version of bash,
# bash --version
GNU bash, version 4.2.24(1)-release (x86_64-pc-linux-gnu)
and when I checked mkmakefile with sed -n l I could see the last line EOF
is followed by an extra character.I have tried a lot to remove that but
failed.
*EOF\r$*
*Please help me to solve this problem and cross compile kernel for my
beagle.*
For more options, visit http://beagleboard.org/discuss
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out.
Hi Renjith,
what you see there is a <cr> character -- the extra carriage return,
DOS/WINDOW needs to end a line. Unix needs a <lf> character, which
stands for linefeed, which is recognized in the putput as '$'.
My guess is, that the file in question is in DOS-format.
There are several tools out there like
"fixdos" (http://e.co.za/marius/) or
"dos2unix" (dos2unix download | SourceForge.net)
to address this problem of converting DOS-text files to UNIX.
But if you on the way to do it "the UNIX way" you can simply
start vim/vi like this
vim <your text file>
and give the following commands:
<ESC>
set ff<RET>
This should print
fileformat=dos
Now give this commands
<ESC>
set ff=unix<RET>
wq<RET>
Now the file is written in UNIX-format back to your harddisc.
(<RET> means "press the return/enter key" and <ESC> means "press the
escape key")
HTH!
Best regards,
mcc
