BeagleBone minicom problem
My BeagleBone arrived (in the UK) on Friday, and it seems to work well
in all respects but one.
It boots quite happily using the supplied micro-sd card, and using
minicom to talk to ttyUSB1 I can watch it boot, and the kernel writes
to the console cleanly.
But I can not log on on the console. Nothing I type appears on the screen.
I can connect to it using ssh through the ethernet interface and log on.
So I tried following the Debian install onto another micro-sd card,
and the same symptom.
I use minicom all the time to talk to a bunch of other embedded boards
through a variety of USB serial adapters, and for this setup I have it
configured to use 115200n8 with hardware flow control (as recommended
in a number of web pages).
Anyone got any clues as to how to fix this?
David
if this is the issue with minicom, try picocom ( sometimes I faced trouble using minicom )
picocom -b 115200 /dev/ttyUSB0
Thanks, that fixed it. Never had that sort of problem with minicom
before, but I now have picocom in case I hit it in the future.
David
small suggestion here , its better to use graphical terminals ,
minicom can be very frustrating at times , instead try out gtkterm or
cutecom ,
cutecom ,
I don't see that either of those if going to help with this kind of
problem. As I just commented on another person with much the same
problem there seems to a dissagreement on the web sites as to whether
you should have hardware flow control enabled or not. Get it right
and it works (or a use a program like picocom which seems to ignore
flow control) or get it wrong and it does not.
David
You need to turn Hardware flow control OFF.
There must be an error on the web pages ??
Simplest to use is "gtkterm" which I have used for over a decade and a half.
With it you can save the dialogue if you need to look at past activity.
73 ... Sid.
