hello folks. veteran developer, new to BeagleBone and Linux internals.
I'm trying to configure my BeagleBone so that I can mount it on my
Ubuntu development system via NFS. So far I've had no luck. I found
some 4 year old info on how to do this but it no longer works.
A quick instruction or a pointer to an article would be most appreciated.
_______________________________________
From: beagleboard@googlegroups.com [beagleboard@googlegroups.com] on behalf of NeonJohn [jgd@neon-john.com]
Sent: Saturday, February 02, 2013 6:24 PM
To: beagleboard@googlegroups.com
Subject: [beagleboard] Beaglebone NFS mount
Thanks Gregory. I found that in my searching and it works fine but it's
the wrong direction. I want to mount the BeagleBoard on my desktop so I
can use my normal desktop tools including the quad core processor to run
the cross-compiler. IOW I wan the server to be running on the BB.
I found some instructions from 2009 that involved installing a package
called nfs-tools or something like that. The package no longer exists.
I can't find anything modern on setting up a server on the Angstrom
distribution that came with the board.
I looked at Arch Linux for the BB. It has the server but it had so many
problem with dependencies (couldn't even install gcc) that I gave up.
________________________________________
Sent: Sunday, February 03, 2013 2:32 PM
Subject: Re: [beagleboard] Beaglebone NFS mount
[snip]
I followed Gregory’s instructions (with the opkg update), and can’t seem to access the /mnt drive on my BBB from my ubuntu machine (12.04 running on VMWare). I installed nfs-common on ubuntu and am have messed around with the mount command, but am always getting the same output:
$ sudo mount -v -t nfs 172.16.2.50:/mnt /nfs
mount.nfs: timeout set for Wed Sep 18 11:40:49 2013
mount.nfs: trying text-based options ‘vers=4,addr=172.16.2.50,clientaddr=172.16.2.56’
mount.nfs: mount(2): Connection refused
My /etc/exports file is:
/mnt 172.16.2.0/255.255.255.0(rw)
I have also tried connecting beaglebone to beaglebone and haven’t had any luck there either. The command I’m using there is:
busybox mount -t nfs 172.16.2.50:/mnt /mnt
and it comes back with:
mount: 172.16.2.50:/home/admin failed, reason given by server: Permission denied
Any help you could offer would be greatly appreciated!
Thanks!
