Hi All,
I have finally managed to get my BeagleBone connect to my local network using WiFi (using Asus N10).
To make it work I have to run wpa_supplicant first to load a config file that has the details for my WiFi network.
So I run this:
wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant_my_network.conf
Then I run:
/etc/init.d/networking restart
and everything works fine. It picks up an ip address and life is beautiful!
I have modified /etc/network/interfaces to this:
Wireless interfaces
auto wlan0
iface wlan0 inet dhcp
wireless_mode managed
wireless_essid any
wpa-driver wext
wpa**-conf /etc/wpa_supplicant_my_network.conf**
I do not know why not simplely restarting the networking process load wpa_supplicant.
Anyway, the goal is to get the bone connect to WiFi right after boot, without my intervention.
I tried to make a service with systemd. Here is my .service file:
Description=loads wpa_supplicant and restarts networking process
After=network.target
[Service]
ExecStart=/usr/myScripts/setupWifi.sh
[Install]
WantedBy=multi-user.target
setupWifi.sh is made of those two commands that I have to run manually :
#!/bin/sh
sleep 8
It is not working. systemctl status does not show the script as failed.
I guessing it is a timing issue. It seems my script runs before the driver for the Wifi stick is loaded.
Two question:
How can I run my service as the last thing that loads, or at least after the WiFi stick driver is loaded ?
I have removed connman. It was hard to configure. no command line. Is there a better way of connecting to a Wifi network right after boot ? Do I have to go back to connman?
thank you
