Hi guys,
i am trying to connect to my BeagleBone via screen command.
I am connection through USB-Connection
screen /dev/tty.usbserial-*******B 115200
Then i am going to see the Angstrom login
.—O—.
.-. o o
__ | —'| ‘–.| .-’| | |
The Angstrom Distribution rocon ttyO0
Angstrom v2012.05 - Kernel 3.2.34
martin login:
After a short period of time (like 30 seconds) the Beaglebone is rebooting.
Sending SIGTERM to remaining processes…
Sending SIGKILL to remaining processes…
Unmounting file systems.
Unmounted /dev/mqueue.
Unmounted /sys/kernel/debug.
Disabling swaps.
Detaching loop devices.
Detaching DM devices.
[ 54.320220] Restarting system.
U-Boot SPL 2011.09-00053-gb423c52 (Aug 10 2012 - 11:26:55)
Texas Instruments Revision detection unimplemented
No daughter card present
No AC power, disabling frequency switch
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00053-gb423c52 (Aug 10 2012 - 11:26:55)
I2C: ready
DRAM: 256 MiB
WARNING: Caches not enabled
NAND: HW ECC Hamming Code selected
No NAND device found!!!
0 MiB
Net: cpsw
SD/MMC found on device 0
reading uEnv.txt
33 bytes read
Loading file “/boot/uImage” from mmc device 0:2 xxa2
3489560 bytes read
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.2.34/beaglebone
Data Size: 3489496 Bytes = 3.3 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
XIP Kernel Image … OK
OK
Starting kernel …
systemd-fsck[56]: Angstrom-Cloud9-: clean, 91694/218592 files, 473626/873534 blocks
Anyone who can see what happens here?
Thanks in advance!
Martin
