ubuntu@omap:/boot$ cat /proc/cpuinfo
Processor : ARMv7 Processor rev 2 (v7l)
BogoMIPS : 274.24
Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc08
CPU revision : 2
Hardware : am335xevm
Revision : 0000
Serial : 0000000000000000
ubuntu@omap:/boot$ uname -a
Linux omap 3.2.0-psp7 #1 Fri Apr 13 04:55:05 UTC 2012 armv7l armv7l armv7l GNU/Linux
ubuntu@omap:/boot$ cat /etc/issue
Ubuntu 12.04 LTS \n \l
I want to speed up it. And it looks I should change /boot/boot.script, but I didn’t find that file:
It's selecting a cpufreq to match operating system load...
cat /proc/cpuinfo is only a one time valid value for cpu speed, run
"cpufreq-info" and put the device under load..
voodoo@bone-a3-256mb:~$ cpufreq-info
cpufrequtils 007: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
driver: omap
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 300 us.
hardware limits: 275 MHz - 720 MHz
available frequency steps: 275 MHz, 500 MHz, 600 MHz, 720 MHz
available cpufreq governors: conservative, ondemand, powersave,
userspace, performance
current policy: frequency should be within 275 MHz and 720 MHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency is 720 MHz.
cpufreq stats: 275 MHz:5.44%, 500 MHz:0.35%, 600 MHz:0.31%, 720
MHz:93.90% (5669)
Robert,
are you saying that the kernel dynamically changes the cpu freq
depending on the cpu load?
Oh, Thanks for that reply.
I also found if I use “cpufreq-set -g performance”, then cpu will be running at 720MHZ.
