I’ve noticed that the beaglebone black sometimes does not startup after a short power loss, even when pressing the power button, it does not start.
To reproduce with a regulated power supply (tested with BBB rev B and C):
Output of power supply 5V
connect power supply to BBB
BBB starts up normally
down-regulate the output slowly
at 3.5 V, the beaglebone turns off
go back to 5V
press the power button, the beaglebone won’t startup
go above 5.1V and press the power button => now the beaglebone starts
Are you measuring the voltage at the BBB terminals or are you reading the voltage from your power supply? Do you use thin wires to connect from your power supply to the BBB? My thinking is there is a voltage drop across the wires of 100mV or more.
John, this happens to me too, but powering via USB. Once in w blue moon, there seems to be some sort of race condition, or something where the BBB is not getting enough power.
So in order to thwart this I’ve stopped using shutdown now -r, and instead use shutdown now -h. Then manually remove / reapply the USB cable.
@ John:
Thanks for your answer. I measured with a multimeter directly at the BBB. The BBB normally even starts with only 4.5V so its definitely something wrong with the PMIC.
@Gerald:
Thank you. The problem is, we are using the BBB in an industrial product that has to run 24/7. Replugging the device is therefore no option. Powering the BBB with at least 5.1V seems to resolve the problem but I wondered if there is a reason for that.
Well, I didn’t design the board for that application. There is a way to take care of that if you are willing to fix it. It is not something that I will put in the design just for your application.
Add a battery to the board to keep it up long enough to shutdown if the failure is long or to not be impacted by momentary losses of power, which can also corrupt the filesystem on either the eMMC or the SD card.
Any reason that you can’t use a cape to solve the problem? The PowerCape will prevent brown-outs and transients from bringing the BB down. Your application/script can monitor DC power good and battery voltage/current and then do a clean shutdown if necessary. The cape can also restart the system when DC power returns. It’s my cape so feel free to ping me with any questions about it…
