Hi Everyone,
Does anyone know how many UART's the Beaglebone has? I have an
application that requires at least 3 RS-232 serial ports. I was
thinking of using a TTL<->RS-232 converter to bring up the 3.3v logic
level serial ports on the beaglebone to rs-232 levels. But, I don't
know if it has the UARTs to support this. Thanks in advance for anyone
that replies.
-Alex
There are up to five of them, depending on how you set up the pin muxing. Four have TX,RX,CTS, and RTS, and the fifth one only TX and Rx.
I think that doesn't count the one used for the console that is
connected to the FTDI USB-to-serial adapter, but only the ones on the
expansion headers.
That was only counting the ones needing a level shifter on them to be used, such as on a cape.
