Hello Gerlad,
I’m sorry that I missed this for so long.
I want to use the ETMV570G2DHU Touchdisplay.
At first I only want to get the lcdpanel working and in the second the touchscreen.
I have read a lot into this ant got that I have to use the registers of the lcd controller from the processor.
In the spruf98x.pdf from ti is the point 15 Display subsystem from which I learned a lot.
On my understanding is my next step to write a programm (in c / c++) that writes into the registers to initalialize the lcd controller.
I had not understand everything in point 15 Display subsystem. So please tell me, if I misunderstand something.
1.) I must get the adress from the registers for:
15.5.3.5 LCD-Specific Control Registers
The following registers define the LCD output configuration:
• DSS.
DISPC_CONTROL
• DSS.
DISPC_CONFIG
• DSS.
DISPC_DEFAULT_COLOR_m(m=0)
• DSS.
DISPC_TRANS_COLOR_m(m=0)
• DSS.
DISPC_TIMING_H
• DSS.
DISPC_TIMING_V
• DSS.
DISPC_POL_FREQ
• DSS.
DISPC_DIVISOR
• DSS.
DISPC_SIZE_LCD
• DSS.
DISPC_DATA_CYCLEk
• DSS.
DISPC_CPR_COEF_R, DSS.DISPC_CPR_COEF_G, DSS.DISPC_CPR_COEF_B
Setting/resetting the DSS.
DISPC_CONTROL[0] LCDENABLE bit enables/disables the LCD output. A valid
configuration must be set before enabling the LCD output.
(copied from spruf98x.pdf)
and then I have to write the display data into the registers?
Here a question:
I read that there is userspace and kernelspace. I have to write this program under userspace.
Can I access the kernelmemory “easy” with pointers from userspace, or do I have to use methods like >>*request_region(…)<<, >>relase_region(…)<< ?
I think that it for first
Thank you for your answer.
Markus
2013/8/13 Gerald Coley <gerald@beagleboard.org>
