I’m having problems getting the BeagleBone to complete the processes
needed to fully come up and run. My PC environment is Windows XP. I
am connecting to the board through the USB cable included in the kit.
I do not have a wired Ethernet network to connect to. From the
README.htm file I have been able to:
1. Install the BONE_DRV.exe on Windows.
2. I can connect the BeagleBone’s serial console with Hyperterminal
3. I am able to logon as root
The problem comes when I need to launch the USB-to-Ethernet
interface. The BeagleBone storage gadget shows up as “USB Mass
Storage Device” on Windows. I stop that driver, but the “USB-to-
Ethernet” interface does not automatically start. I do note that the
C:\Windows\system32\DRVSTORE\linux_ and ftdibus_ directories exist.
I’m not quite sure what I am doing wrong so I can’t get to the next
step and get the USB-to-Ethernet gadget running so I can go the web
interface. Any suggestions?
Also, does a direct Ethernet connection to the board make sense?
Which type of ethernet cable should I use? Thanks.
Yes, it'll work, but you'll need to define an IP address and
appropriate settings for each side if your PC doesn't provide a DHCP
server.
Or, perhaps you just mean connecting it to your existing Ethernet
network, in which case, it should fetch an address via DHCP and work
fine.
Either a normal cable or a cross-over cable should work. The hardware
is meant to have an auto-detect feature to cross-over when necessary.
I've tried using both types of cables.
Jason,
Thanks for the response. I don't have a wired network to plug into.
It would take a wireless connection for it to get a DHCP address. My
connection would need to be a direct one. I've tried using a normal
ethernet cable, but since I don't know how to assign an IP address to
the board, it made no connection - as expected. Can you point me to
instructions on how to do this? My more fundamental issue (forgetting
the ethernet connection) is how to get the USB-to-Ethernet gadget
running so I can talk to the BB and get to its web site. Any
suggestions? The current situation leaves me with an unusable BB.
Thanks.
John
Another source suggested I go to Windows Explorer and eject the
BeagleBone from there. This made all the difference. I had been
using the icon in the system tray to stop the BeagleBone USB
connection. This is NOT the same as an eject. When I did this eject,
the new drivers were installed. I could then access the BeagleBone
101 presentation and the Cloud9 IDE. I was also able to run the
"blinkled" application. I do find that I can't access GateOne. I get
an error message saying this webpage has a redirect loop that resulted
in too many redirects. Any thoughts on what is wrong here? Running
ifconfig -a yields:
eth0 Link encap:Ethernet HWaddr D4:94:A1:37:71:11
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:221 errors:0 dropped:0 overruns:0 frame:0
TX packets:33 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:57593 (56.2 KiB) TX bytes:11800 (11.5 KiB)
Interrupt:40
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:12 errors:0 dropped:0 overruns:0 frame:0
TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:744 (744.0 B) TX bytes:744 (744.0 B)
usb0 Link encap:Ethernet HWaddr 22:00:7E:49:D8:00
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::2000:7eff:fe49:d800/64 Scope:Link
RX packets:4461 errors:0 dropped:0 overruns:0 frame:0
TX packets:6322 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:694767 (678.4 KiB) TX bytes:6457322 (6.1 MiB)
Thanks.
John
I use Windows 7 and HyperTerminal is not included, but you can use the
polular Putty, a ssh client. (Download from http://www.chiark.greenend.org.uk/~sgtatham/putty/).
I connect with putty not even using the serial connection but the IP
of the BeagleBone: 192.168.7.2.
Martin
I've been able to use Putty. Thanks for the recommendation. However,
I'm still unable to access GateOne. I am using Chrome on Windows XP.
It thinks there are too many redirects. Any other thoughts?
John
I’m using Windows 7, with Putty, but when I try to connect over Google Chrome I get 103 error connection… With Ubuntu and Usb-to-Ethernet I didn’t have any problem!!
again… I tried to connect via Android Phone, Ubuntu and I didn’t get any kind of error… But When I try to connect with Windows 7 I cannot retrieve page with some errors like:
Errore 324 (net::ERR_EMPTY_RESPONSE): The server had close the connection without send datas.
I tried to turn off Firewall, but nothing works…
I think it’s a setup of beaglebone or windows 7…
Let me know!
