BeaglelBone Black ethernet port PoE power
I’d like your help in sorting out a problem I’m having with a project. We’re using a BeagleBoard Black in a recording setup. The BeagleBoard is connected via a power jack to a PowerBoost 1000C and a PoE adapter for power. After a while, the system fails, and it seems the reason is that the BeagleBone’s Ethernet port is failing. Does the BeagleBone’s Ethernet port support PoE? Could there be another reason? Thank you.
The BBB does not support POE out of the box, you must take care of the power before the rj45 plug..
