BeagleMind Prompts
This thread is created to gather your suggested prompts for testing the performance of BeagleMind – a Conversational AI Assistant designed to help users navigate and understand BeagleBoard documentation more effectively.
BeagleMind uses Retrieval-Augmented Generation (RAG) to provide accurate, reference-backed answers by pulling relevant content from technical docs, tutorials, and source files.
If you have:
  • Questions you’ve previously asked while working with BeagleBoard hardware or software
  • Troubleshooting prompts
  • “How-to” queries
  • Setup/configuration-related questions
  • Anything you think a BeagleBoard user might ask
Please drop them here! Your input will help build a comprehensive set of test cases and ensure the assistant responds well across a wide range of real-world queries.
Thanks in advance!
Prompts & Responses
These are the prompts that you suggested in the GDoc @Aryan_Nanda
Prompt: My beaglebone ai-64 is not booting. What should I do?
Response:
Prompt: How to run edgeai models in BeagleBone AI-64
Response:
Prompt: What is the difference between BeagleBone AI-64 and beagley-ai?
Response:
Prompt: Can you show me the components location of beagley ai?
Response:
Hi everyone,
I’ve just deployed a prototype of the chatbot, you can try it out here:
:backhand_index_pointing_right: https://fayezzouari-beaglemind-rag-poc.hf.space
I’d really appreciate it if you could test it and share any suggestions or feedback, especially around usability, response quality, or areas for improvement. Your input will help guide the next iteration!
Thanks a lot!
@jkridner
@lorforlinux
@RobertCNelson
@silver2row
@jkridner, @lorforlinux, @RobertCNelson, @silver2row
If you could give feedback, that would help a lot.
