Does anyone know what the thermal_zone0 and thermal_zone1 stand for?
debian@BeaglePlay:~$ ls /sys/class/thermal/thermal_zone
thermal_zone0/ thermal_zone1/
When idle, the temperatures, 39.45°C and 38.05°C, are still ok, but they seem to rise quite quickly under load.
debian@BeaglePlay:~$ cat /sys/class/thermal/thermal_zone0/temp
39450
debian@BeaglePlay:~$ cat /sys/class/thermal/thermal_zone1/temp
38046
A plugged-in Fan Click MIKROE-2004 is not recognised.
debian@BeaglePlay:~$ sudo sensors-detect
[sudo] password for debian:
# sensors-detect version 3.6.0
# Kernel: 5.10.162-ti-arm64-r96 aarch64
# Cannot show processor info on aarch64 architecture.
Next adapter: OMAP I2C adapter (i2c-3)
Do you want to scan it? (YES/no/selectively):
Adapter doesn't support all probing functions.
Some addresses won't be probed.
debian@BeaglePlay:~$ i2cdetect -y 3
Warning: Can't use SMBus Quick Write command, will skip some addresses
0 1 2 3 4 5 6 7 8 9 a b c d e f
00:
10:
20:
30: -- -- -- -- -- -- -- --
40:
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60:
70:
However, I can both read out the EMC2301 on the Click Board and write data to it.
Here I have read out the “duty cycle” from register 0x30, which is set to 0xFF at system start, which corresponds to a duty cycle of 100%. Because the small fan was too loud for me, I then tried two lower values.
debian@BeaglePlay:~$ i2cget -y 3 0x2f 0x30
0xff
debian@BeaglePlay:~$ i2cset -y 3 0x2f 0x30 0x68
0x68
debian@BeaglePlay:~$ i2cset -y 3 0x2f 0x30 0x80
0x80
Unfortunately, I can’t find the driver for the EMC2301. I think the driver is only integrated in the 6.2.6 kernel version.
debian@BeaglePlay:~$ ls /lib/modules/5.10.162-ti-arm64-r96/kernel/drivers/hwmon/emc*
/lib/modules/5.10.162-ti-arm64-r96/kernel/drivers/hwmon/emc1403.ko.xz
/lib/modules/5.10.162-ti-arm64-r96/kernel/drivers/hwmon/emc2103.ko.xz
/lib/modules/5.10.162-ti-arm64-r96/kernel/drivers/hwmon/emc6w201.ko.xz
EMC2301/2/3/5 Data Sheet - Microchip Technology
Fan click (EMC2301) user manual
NF-A4x10 5V PWM Fan
hwmon: add Microchip EMC230X fan controller driver
