I’m having a hard time making the BeaglePlay go into a low power state and waking afterwards, hope someone here can help.
When I try to suspend to RAM (“echo mem > /sys/power/state”) the kernel starts to shut down parts of the system, but it doesn’t seem to finish the suspend process and it is no longer responsive to any wakeup sources I tried (user button, rtcwake, uart, usb keyboard).
I’ve tried both on Debian, and on a custom TI SDK 09.01 based system built with Yocto.
I measured the current both while idle and after issuing the suspend command, the difference was about 30mA (230mA down to ~200mA). This suggests to me that suspend failed to finish properly.
Here are the logs after suspending on the TI SDK based OS:
I think that the Beagleplay has an AM625 GP SoC (Non-HS). However TI-SDK has stopped support for GP devices in the latest SDK that you’re talking about.
This release supports High Security - Field Securable (HS-FS) devices. For migration guide and other info, refer GP to HS-FS Migration Guide
Also, the firmware revision that I see from your logs seems to be from a much older release (08.06?)
What version of bootloaders are you using? Are you building on your own or using the default one’s on the emmc?
There are alot of entities involved in Low Power Mode support (TF-A, DM Firmware, TIFS firmware, U-Boot, Linux kernel) which makes things a bit harder to debug if there are version mismatches.
Thanks for the information. I tried the steps for GP systems from the migration guide but it didn’t change the suspend to ram behavior.
I built the default TI SDK and added a few libraries on top of that, I did not change the boot loader or kernel. (u-boot-ti-staging/1_2023.04+gitAUTOINC+b0d717b732-r0_tisdk_1_edgeai_2, git hash e5972306f9ac7ab9733ded53321dfb5dffba8d02 of last commit)
@sdo Can you please try with one of Robert’s latest images once?
The image I have has following versions:
debian@BeaglePlay:~$ uname -a
Linux BeaglePlay 6.1.69-ti-arm64-r23 #1bookworm SMP PREEMPT_DYNAMIC Wed Jan 31 06:22:50 UTC 2024 aarch64 GNU/Linux
debian@BeaglePlay:~$ cat /sys/power/mem_sleep
s2idle [deep]
debian@BeaglePlay:~$ dmesg | grep -i "ti-sci 44043000.system-controller"
[ 1.251255] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
root@BeaglePlay:~# rtcwake -s 10 -m mem -d rtc1
rtcwake: assuming RTC uses UTC ...
[2024-02-14 10:56:14] rtcwake: wakeup from "mem" using rtc1 at Thu Jan 1 00:03:58 1970
[2024-02-14 10:56:14] [ 205.093668] PM: suspend entry (deep)
[2024-02-14 10:56:14] [ 205.097503] Filesystems sync: 0.000 seconds
[2024-02-14 10:56:14] [ 205.104801] Freezing user space processes
[2024-02-14 10:56:14] [ 205.110710] Freezing user space processes completed (elapsed 0.001 seconds)
[2024-02-14 10:56:14] [ 205.117772] OOM killer disabled.
[2024-02-14 10:56:14] [ 205.121029] Freezing remaining freezable tasks
[2024-02-14 10:56:14] [ 205.127008] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[2024-02-14 10:56:14] [ 205.134439] printk: Suspending console(s) (use no_console_suspend to debug)
with the above I am definitely able to hit deepsleep because I can see the power consumption by beagleplay drop significantly as shown: 1.2 W in active and 0.09W in deepsleep
I am first trying to make sure that you’re able to atleast enter deepsleep before we debug the wakeup/ resume path.
However, it seems to me that ti-u-boot has some patches that are not yet upstreamed, particularly this:
commit 91886b68025c7ad121e62d1fc1fa4601eeb736cd
Author: Kamlesh Gurudasani <kamlesh@ti.com>
Date: Mon Jun 12 15:39:09 2023 +0530
arm: dts: k3: binman: am625: add support for signing FSSTUB images
Add support for signing of FSSTUB images for HSSE, HSFS and GP devices
and include them in tispl.bin and tispl.bin_unsigned.
Signed-off-by: Kamlesh Gurudasani <kamlesh@ti.com>
I’d advise you to replace the Boot binaries from Robert’s images with boot binaries built from ti-u-boot: ti-u-boot-2023.04-next
Thanks for the suggestions. I tried one of the newer builds and the power usage while suspended seems much lower than what I saw in my original build.
You were also right about the firmware version being old, I solved that issue now.
I managed to make suspend to ram/resume work by applying the UART daisy chain changes mentioned in the documentation you shared.
Unfortunately waking only works once per boot, after resuming once it no longer works.
I added multiple combinations of kernel modules to a blacklist (including optee_rng), but this did not seem to improve the problem I see now. Even with no kernel modules loaded it still freezes after the first suspend/resume pair.
I see the following errors after resuming the first time:
@sdo please can you share fuller logs, right from the point your first UBoot print comes?
I want to make sure all the OPTEE, TF-A are correct. Also, I see the date of your Linux compilation to be Nov 30th which seems a bit old? Can you try with the latest ti-linux kernel please?
Also, the following is a known issue:
am65-cpsw-nuss 8000000.ethernet eth0: failed to start
And a fix is underway, however it shouldn’t affect overall system suspend resume.
With all submodules enabled the system won’t allow suspend to happen after the first resume is done. There is an error mentioning an invalid address when writing “mem” to /sys/power/state.
After blacklisting every submodule it behaved in a similar manner to the older kernel, the system froze after a few successful suspend/resume pairs.
@sdo I tried multiple times on my end, I am not able to reproduce the issue, can you try this versions of binaries: ( v2.9(release):v2.9.0-614-gd7a7135d32)
U-Boot SPL 2023.04-00001-g1a59dc85127f (Feb 19 2024 - 11:41:54 +0530)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.1--v09.02.01 (Kool Koala)')
SPL initial stack usage: 13400 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was d
Starting ATF on ARM64 core...
NOTICE: BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty
NOTICE: BL31: Built : 09:34:15, Aug 24 2023
U-Boot SPL 2023.04-00001-g1a59dc85127f (Feb 19 2024 - 11:42:00 +0530)
Seems like the TF-A (BL31) is the only major delta, also in your logs be sure to give dmesg after a suspend resume otherwise at the uboot prompt when it asks to select you can choose 1:
