IDK, it looks like the wpa_gui tool broke…
So using the latest image: Debian Bullseye Xfce Image 2023-08-05
So over serial we see:
debian@BeaglePlay:~$ sudo beagle-version
eeprom:[BEAGLEPLAY-A0-02007801030101640723005162SSSS]
model:[BeagleBoard.org_BeaglePlay]
dogtag:[BeagleBoard.org Debian Bullseye Xfce Image 2023-08-05]
So doing it the normal way, Connect to my testing WiFi network:
debian@BeaglePlay:~$ cat /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
ctrl_interface=DIR=/run/wpa_supplicant GROUP=netdev
update_config=1
p2p_disabled=1
country=US
network={
ssid="BeagleBone"
psk="BeagleBone"
Reboot:
debian@BeaglePlay:~$ journalctl -b 0 -k -g wlan
-- Journal begins at Sun 2023-06-18 14:55:54 UTC, ends at Sun 2023-08-13 20:22:51 UTC. --
Aug 13 20:20:16 BeaglePlay kernel: wlan_en: supplied by vdd_3v3
Aug 13 20:20:28 BeaglePlay kernel: wlan0: authenticate with c2:fb:e4:f5:7b:d2
Aug 13 20:20:28 BeaglePlay kernel: wlan0: send auth to c2:fb:e4:f5:7b:d2 (try 1/3)
Aug 13 20:20:28 BeaglePlay kernel: wlan0: authenticated
Aug 13 20:20:28 BeaglePlay kernel: wlan0: associate with c2:fb:e4:f5:7b:d2 (try 1/3)
Aug 13 20:20:28 BeaglePlay kernel: wlan0: RX AssocResp from c2:fb:e4:f5:7b:d2 (capab=0x1511 status=0 aid=1)
Aug 13 20:20:28 BeaglePlay kernel: wlan0: associated
Aug 13 20:20:28 BeaglePlay kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Aug 13 20:20:28 BeaglePlay kernel: wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by c2:fb:e4:f>
debian@BeaglePlay:~$ sudo ifconfig -a
SoftAp0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.8.1 netmask 255.255.255.0 broadcast 192.168.8.255
inet6 fe80::6e30:2aff:fe0a:dad3 prefixlen 64 scopeid 0x20<link>
ether 6c:30:2a:0a:da:d3 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 49 bytes 8964 (8.7 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:0f:e4:93:c2 txqueuelen 0 (Ethernet)
TX packets 0 bytes 0 (0.0 B)
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 34:08:e1:85:0a:11 txqueuelen 1000 (Ethernet)
eth1: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 3a:41:56:1f:32:9d txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 210 bytes 18665 (18.2 KiB)
TX packets 210 bytes 18665 (18.2 KiB)
lowpan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1280
inet6 fe80::212:4b00:29b9:9884 prefixlen 64 scopeid 0x20<link>
unspec 00-12-4B-00-29-B9-98-84-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
TX packets 26 bytes 3860 (3.7 KiB)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 1c:ba:8c:a2:ed:6b txqueuelen 1000 (Ethernet)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 1c:ba:8c:a2:ed:6d txqueuelen 1000 (Ethernet)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.3.66 netmask 255.255.252.0 broadcast 192.168.3.255
inet6 fe80::6e30:2aff:fe0a:dad2 prefixlen 64 scopeid 0x20<link>
ether 6c:30:2a:0a:da:d2 txqueuelen 1000 (Ethernet)
RX packets 13307 bytes 17007068 (16.2 MiB)
RX errors 0 dropped 117 overruns 0 frame 0
TX packets 5240 bytes 522445 (510.2 KiB)
wpan0: flags=130<BROADCAST,NOARP> mtu 123
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 300 (UNSPEC)
wpan1: flags=195<UP,BROADCAST,RUNNING,NOARP> mtu 123
unspec 00-12-4B-00-29-B9-98-84-00-00-00-00-00-00-00-00 txqueuelen 300 (UNSPEC)
TX packets 42 bytes 3696 (3.6 KiB)
networkctl
debian@BeaglePlay:~$ sudo networkctl
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 eth0 ether no-carrier configuring
3 eth1 ether off unmanaged
4 wpan0 ieee802154 off unmanaged
5 wpan1 ieee802154 carrier unmanaged
6 lowpan0 6lowpan degraded unmanaged
7 wlan0 wlan routable configured
8 SoftAp0 wlan routable configured
9 docker0 bridge no-carrier unmanaged
10 usb0 gadget no-carrier configuring
11 usb1 gadget no-carrier configuring
11 links listed.
route
debian@BeaglePlay:~$ sudo route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default unifi.gfnd.rcn- 0.0.0.0 UG 1024 0 0 wlan0
172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
192.168.0.0 0.0.0.0 255.255.252.0 U 0 0 0 wlan0
unifi.gfnd.rcn- 0.0.0.0 255.255.255.255 UH 1024 0 0 wlan0
192.168.8.0 0.0.0.0 255.255.255.0 U 0 0 0 SoftAp0
and we see the world…
debian@BeaglePlay:~$ ping -c3 www.google.com
PING www.google.com (142.250.190.132) 56(84) bytes of data.
64 bytes from ord37s36-in-f4.1e100.net (142.250.190.132): icmp_seq=1 ttl=57 time=26.1 ms
64 bytes from ord37s36-in-f4.1e100.net (142.250.190.132): icmp_seq=2 ttl=57 time=32.5 ms
64 bytes from ord37s36-in-f4.1e100.net (142.250.190.132): icmp_seq=3 ttl=57 time=45.4 ms
--- www.google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 26.097/34.663/45.386/8.021 ms
So wpa_gui is broken, do it the old way with /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
