BeaglePlay: SGX drivers for OpenGL?
I’m looking for OpenGL drivers for the PowerVR GPU on BeaglePlay, but there doesn’t seem to a good source of information about these. Can anyone point at right location how to get them?
Hi @Michal.Fita right now, “OpenGL ES” driver are available from ti in their yocto build, and we have a blobs enable, but it’s under EGL/wayland only.
We are really close with a mainline solution using mesa with a full Vulkan stack in a few months…
On the BeaglePlay, the display works on mainline, we just need Imagination’s DRM patch set ( [PATCH v6 00/20] Imagination Technologies PowerVR DRM driver - Sarah Walker ) to finally get merged, then the mesa ‘winsys’ driver (waiting on DRM merge) to be finished…
Thanks for quick reply.
What we’re looking for are drivers that would let us run own shaders (computing kernels) on GPU as now it looks like there’s some emulation happening. I understand the work you mentioned has to happen first for the full OpenGL ES experience to materialize. Am I right?
If Yocto works, maybe that’s what we should try… do you have links at hand to right metalayers?
Also note that currently:
  • PowerVR Vulkan has a runtime dependency on X11
  • PowerVR GLES/EGL does not have a dependency on X11
Is there any status on the Beagleplay OpenGL software release? If not, is it crazy to ask if I can port the yocto support to a Buildroot environment?
Same answer: Beagleplay graphics - #2 by RobertCNelson
Downloaded the TI Yocto SDK. I built the thinlinux image (because it has ti-connectivity + graphics), it won’t boot on beagleplay. I tried using the uboot from beagleboard.org gitlab, that didn’t work. Are there instructions somewhere for getting the Beagleplay going with the TI Yocto SDK? I looked at the TI-Yocto-SDK manual online today, it no information about Beagleplay and Beagleplay is not on the listed supported hardware for TI-Yocto-SDK.
