I would like to use the BeagePlay as a host computer and communicate via SSH to ie BeagleBoneBlack through USB. The image’s device tree shows BP’s USB-A port (usb1) is configured as host.
But SSH does not work → ping 192.168.7.2 on Port 22 → no response.
I also changed my BP’s IP address for usb1 in /etc/network/interfaces to a static 192.168.7.132 in order to not conflict with other beagleboards. Kernel driver g_ether is loaded.
Basically my SSH service is running OK since I can communicate to other boards over Ethernet or Wifi. But I need to use an USB connection.
Anyone any idea what’s missing ?
Your netmask is too restrictive, you can only run 2 with your settings.
netmask 255.255.255.240 will allow upto 14, unless you have an extremely good need to be that restrictive set it to 0 until your system is ready to be deployed.
lsusb and dmesg do show that the BeagleBoneBlack was detected and attached as USB Serial Device .
To my understanding ifconfig should show this device as new network connection, but that’s not the case here.
Maybe a kernel driver is missing ?
lsusb Bus 001 Device 006: ID 1d6b:0104 Linux Foundation Multifunction Composite Gadget
dmesg
[ 103.337158] usb 1-1.2: new high-speed USB device number 6 using xhci-hcd
[ 103.439980] usb 1-1.2: New USB device found, idVendor=1d6b, idProduct=0104, bcdDevice= 4.04
[ 103.440030] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 103.440059] usb 1-1.2: Product: BeagleBone
[ 103.440084] usb 1-1.2: Manufacturer: BeagleBoard.org
[ 103.440112] usb 1-1.2: SerialNumber: 1234BBBK5678
[ 103.896943] usbcore: registered new interface driver usbserial_generic
[ 103.897028] usbserial: USB Serial support registered for generic
[ 103.938657] usbcore: registered new interface driver ftdi_sio
[ 103.938779] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 104.011736] usbcore: registered new interface driver cdc_ether
[ 104.032296] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
[ 104.032692] usb 1-1.2: Detected FT2232C
[ 104.045411] ftdi_sio ttyUSB0: Unable to read latency timer: -32
[ 104.052003] ftdi_sio ttyUSB0: Unable to write latency timer: -32
[ 104.059979] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 104.060500] ftdi_sio 1-1.2:1.1: FTDI USB Serial Device converter detected
[ 104.060903] usb 1-1.2: Detected FT2232C
[ 104.063044] ftdi_sio ttyUSB1: Unable to read latency timer: -32
[ 104.069576] ftdi_sio ttyUSB1: Unable to write latency timer: -32
[ 104.076446] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
[ 104.083707] cdc_acm 1-1.2:1.4: ttyACM0: USB ACM device
[ 104.086088] usbcore: registered new interface driver cdc_acm
[ 104.086106] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 104.089013] usbcore: registered new interface driver rndis_host
[ 104.142912] cdc_ncm 1-1.2:1.2: MAC-Address: 98:5d:ad:51:fc:4d
[ 104.144479] cdc_ncm 1-1.2:1.2 eth2: register 'cdc_ncm' at usb-xhci-hcd.2.auto-1.2, CDC NCM, 98:5d:ad:51:fc:4d
[ 104.144867] usbcore: registered new interface driver cdc_ncm
[ 104.159686] usbcore: registered new interface driver rndis_wlan
[ 104.187578] usbcore: registered new interface driver cdc_wdm
[ 104.201586] usbcore: registered new interface driver cdc_mbim
At this point I am just making a very cheap guess, if you are using a windows host it might be the issue. I don’t care for the usb to IP thing, have briefly touched it a few times. Sorry, I am out of guesses…
SOLVED. I was on the wrong track thinking that my USB connection will always show up as usb0/usb1. Furthermore I had totally crap udev rule assigning FTDI instead of RNDIS.
Thanks to USB Networking - Openmoko things started to become clearer.
Just connect your PocketBeagle (or whatever board) to the BeaglePlay’s USB-A port.
Then identify by dmesg which network name was assigned to rndis-service and bring this network up with the correct host IP and port.
Example:
