Can saveenv be used for beagleplay u-boot?
SAVEENV is disabled by default and for the new flow uses Uenv.txt as the default way for saving the environments. This has been done as Uenv.txt is more granular then the saveenv command and can be used across various bootmodes too.
SAVEENV is disabled by default and for the new flow uses Uenv.txt as the default way for saving the environments. This has been done as Uenv.txt is more granular then the saveenv command and can be used across various bootmodes too. … are then any examples of usinbg uenv.txt for this purpose ?
Thanks in advance
