BeaglePlay: Ubuntu 22.04: Failed to start File System Check on Root Device.
My commands to build the image:
./RootStock-NG.sh -c rcn-ee.net-console-ubuntu-2204-v5.10-ti-arm64-k3-am62.conf
Then to dump image to the SD Card (32 GB Sandisk Ultra):
sudo ./setup_sdcard.sh --mmc /dev/sda --dtb beagleplay --hostname mindboggling
I connected the serial port and I shows booting process and reacts to keys pressed while in U-Boot. But that’s the error I’m seeing:
4:	BeaglePlay microSD (default)
Retrieving file: /Image
Retrieving file: /initrd.img
append: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
Retrieving file: /ti/k3-am625-beagleplay.dtb
## Flattened Device Tree blob at 88000000
Working FDT set to 88000000
   Loading Ramdisk to 8f2d2000, end 8ffff112 ... OK
   Loading Device Tree to 000000008f2bf000, end 000000008f2d1435 ... OK
Working FDT set to 8f2bf000
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    1.944723] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[    1.964697] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    2.079258] sdhci-am654 fa00000.mmc: parsing dt failed (-517)
[    2.097644] bq32k 0-0068: hctosys: unable to read the hardware clock
[    2.573222] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present!
[    2.580539] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present!
[    2.587857] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present!
[    2.595631] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[FAILED] Failed to start File System Check on Root Device.
[    7.260890] davinci-mcasp 2b10000.mcasp: IRQ common not found
[    7.290896] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[    7.302625] remoteproc remoteproc2: request_firmware failed: -2
[    7.398355] platform 78000000.r5f: could not request atcm region for resource
[    7.405682] platform 78000000.r5f: failed to get internal memories, ret = -16
[    7.412998] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_core_of_init failed, ret = -16
[    7.421980] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_of_init failed, ret = -16
You are in emergency mode. After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "Press Enter for maintenance
(or press Control-D to continue): [    8.857212] wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2
So after pressing Enter I should land in the recovery console, but it doesn’t react to keys anymore at this stage.
Any hints welcome what’s wrong? Either why booting dies, or why I cannot type anymore on that console?
Thank you.
Console still should be fully active…Can you boot with #1 (recovery) as it disables ‘quiet’ by default so we can see what else is going on…
That’s were it hangs in recovery:
Enter choice: 1
1:	BeaglePlay microSD Recovery
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.168-ti-arm64-r111 (voodoo@rpi4b8g-20) (gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1jammy SMP Mon Sep 25 23:37:56 UTC 2023
[    0.000000] Machine model: BeagleBoard.org BeaglePlay
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
[    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] cma: Reserved 144 MiB at 0x00000000f4000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 32 pages/cpu s92824 r8192 d30056 u131072
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 1808620K/2097152K available (17216K kernel code, 2298K rwdata, 5416K rodata, 3776K init, 720K bss, 141076K reserved, 147456K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000800d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000800e0000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.000356] Console: colour dummy device 80x25
[    0.000774] printk: console [tty0] enabled
[    0.000830] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.000850] pid_max: default: 32768 minimum: 301
[    0.001133] LSM: Security Framework initializing
[    0.001188] Yama: becoming mindful.
[    0.001341] AppArmor: AppArmor initialized
[    0.001354] TOMOYO Linux initialized
[    0.001485] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.001515] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.003863] rcu: Hierarchical SRCU implementation.
[    0.005130] Platform MSI: msi-controller@1820000 domain created
[    0.005460] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.005540] EFI services will not be available.
[    0.006167] smp: Bringing up secondary CPUs ...
[    0.014962] Detected VIPT I-cache on CPU1
[    0.015000] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.015012] GICv3: CPU1: using allocated LPI pending table @0x00000000800f0000
[    0.015077] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.023946] Detected VIPT I-cache on CPU2
[    0.023973] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.023983] GICv3: CPU2: using allocated LPI pending table @0x0000000080100000
[    0.024024] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.032838] Detected VIPT I-cache on CPU3
[    0.032863] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.032873] GICv3: CPU3: using allocated LPI pending table @0x0000000080110000
[    0.032910] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.033004] smp: Brought up 1 node, 4 CPUs
[    0.033103] SMP: Total of 4 processors activated.
[    0.033113] CPU features: detected: 32-bit EL0 Support
[    0.033124] CPU features: detected: CRC32 instructions
[    0.033133] CPU features: detected: 32-bit EL1 Support
[    0.049867] CPU: All CPU(s) started at EL2
[    0.049944] alternatives: patching kernel code
[    0.051729] devtmpfs: initialized
[    0.061820] KASLR disabled due to lack of seed
[    0.062132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.062194] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.066655] pinctrl core: initialized pinctrl subsystem
[    0.067388] DMI not present or invalid.
[    0.068188] NET: Registered protocol family 16
[    0.070110] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.070280] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.070489] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.070569] audit: initializing netlink subsys (disabled)
[    0.070848] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[    0.071405] thermal_sys: Registered thermal governor 'fair_share'
[    0.071410] thermal_sys: Registered thermal governor 'bang_bang'
[    0.071421] thermal_sys: Registered thermal governor 'step_wise'
[    0.071430] thermal_sys: Registered thermal governor 'user_space'
[    0.071439] thermal_sys: Registered thermal governor 'power_allocator'
[    0.072117] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.072289] ASID allocator initialised with 65536 entries
[    0.101504] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.101541] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.101552] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.101563] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.104539] cryptd: max_cpu_qlen set to 1000
[    0.107951] raid6: skip pq benchmark and using algorithm neonx8
[    0.107987] raid6: using neon recovery algorithm
[    0.108931] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.109449] vdd_3v3: supplied by vsys_5v0
[    0.110398] iommu: Default domain type: Translated
[    0.111125] SCSI subsystem initialized
[    0.111341] usbcore: registered new interface driver usbfs
[    0.111381] usbcore: registered new interface driver hub
[    0.111417] usbcore: registered new device driver usb
[    0.111951] mc: Linux media interface: v0.10
[    0.111982] videodev: Linux video capture interface: v2.00
[    0.112117] pps_core: LinuxPPS API ver. 1 registered
[    0.112127] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.112184] PTP clock support registered
[    0.112223] EDAC MC: Ver: 3.0.0
[    0.113024] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    0.114214] NetLabel: Initializing
[    0.114236] NetLabel:  domain hash size = 128
[    0.114244] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.114314] NetLabel:  unlabeled traffic allowed by default
[    0.115089] clocksource: Switched to clocksource arch_sys_counter
[    0.988206] VFS: Disk quotas dquot_6.6.0
[    0.988335] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.988534] FS-Cache: Loaded
[    0.989005] CacheFiles: Loaded
[    0.989539] AppArmor: AppArmor Filesystem Enabled
[    0.996593] NET: Registered protocol family 2
[    0.996873] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.998171] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.998424] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.998675] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.998909] TCP: Hash tables configured (established 16384 bind 16384)
[    0.999338] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[    0.999468] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.999532] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.999772] NET: Registered protocol family 1
[    1.000538] RPC: Registered named UNIX socket transport module.
[    1.000561] RPC: Registered udp transport module.
[    1.000570] RPC: Registered tcp transport module.
[    1.000578] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.000594] NET: Registered protocol family 44
[    1.000618] PCI: CLS 0 bytes, default 64
[    1.000869] Trying to unpack rootfs image as initramfs...
[    1.502560] Freeing initrd memory: 13492K
[    1.503769] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.504371] kvm [1]: IPA Size Limit: 40 bits
[    1.505249] kvm [1]: vgic-v2@100010000
[    1.505280] kvm [1]: GIC system register CPU interface enabled
[    1.505381] kvm [1]: vgic interrupt IRQ9
[    1.505528] kvm [1]: Hyp mode initialized successfully
[    1.509925] Initialise system trusted keyrings
[    1.510198] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    1.515721] zbud: loaded
[    1.518345] NFS: Registering the id_resolver key type
[    1.518411] Key type id_resolver registered
[    1.518420] Key type id_legacy registered
[    1.518522] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.518535] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.518583] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.519365] fuse: init (API version 7.32)
[    1.556691] NET: Registered protocol family 38
[    1.556737] xor: measuring software checksum speed
[    1.560759]    8regs           :  2464 MB/sec
[    1.564285]    32regs          :  2918 MB/sec
[    1.568189]    arm64_neon      :  2530 MB/sec
[    1.568198] xor: using function: 32regs (2918 MB/sec)
[    1.568221] Key type asymmetric registered
[    1.568231] Asymmetric key parser 'x509' registered
[    1.568296] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.568496] io scheduler mq-deadline registered
[    1.570686] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    1.571300] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    1.579508] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    1.593690] brd: module loaded
[    1.719203] loop: module loaded
[    1.720594] megasas: 07.714.04.00-rc1
[    1.725716] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.725750] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.725837] sky2: driver version 1.30
[    1.727020] VFIO - User Level meta-driver version: 0.3
[    1.727902] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.727954] ehci-pci: EHCI PCI platform driver
[    1.729853] i2c /dev entries driver
[    1.730063] Driver for 1-wire Dallas network protocol.
[    1.730141] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[    1.732231] sdhci: Secure Digital Host Controller Interface driver
[    1.732256] sdhci: Copyright(c) Pierre Ossman
[    1.732552] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.733743] ledtrig-cpu: registered to indicate activity on CPUs
[    1.734179] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.734679] hid: raw HID events driver (C) Jiri Kosina
[    1.735147] usbcore: registered new interface driver usbhid
[    1.735160] usbhid: USB HID core driver
[    1.736005] optee: probing for conduit method.
[    1.736050] optee: revision 3.22 (7c243321)
[    1.752645] optee: dynamic shared memory is enabled
[    1.753006] optee: initialized driver
[    1.754692] NET: Registered protocol family 10
[    1.784517] Segment Routing with IPv6
[    1.784646] mip6: Mobile IPv6
[    1.784663] NET: Registered protocol family 17
[    1.784894] Key type dns_resolver registered
[    1.784907] mpls_gso: MPLS GSO support
[    1.785294] registered taskstats version 1
[    1.785316] Loading compiled-in X.509 certificates
[    1.785497] zswap: loaded using pool lzo/zbud
[    1.785839] Key type .fscrypt registered
[    1.785850] Key type fscrypt-provisioning registered
[    1.790732] Btrfs loaded, crc32c=crc32c-generic
[    1.790924] AppArmor: AppArmor sha1 policy hashing enabled
[    1.802829] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.7--v09.00.07 (Kool Koala)')
[    1.869084] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0
[    1.869126] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[    1.872459] omap_i2c 4900000.i2c: bus 5 rev0.12 at 10 kHz
[    1.900757] VDD_CORE: Bringing 750000uV into 850000-850000uV
[    1.901640] VDD_CORE: supplied by vsys_5v0
[    1.902636] VDD_1V8: supplied by vsys_5v0
[    1.903544] VDD_1V2: supplied by vsys_5v0
[    1.904548] VDD_SD_3V3: supplied by vdd_3v3
[    1.905773] VDDA_0V85: supplied by VDD_1V8
[    1.906933] VDDA_1V8: supplied by vdd_3v3
[    1.907835] VDD_2V5: supplied by vdd_3v3
[    1.910316] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.1.auto/input/input0
[    1.910947] tps65219 0-0030: Setup as system-power-controller but pm_power_off function already registered, overwriting
[    1.911262] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.912917] omap_i2c 20010000.i2c: bus 1 rev0.12 at 10 kHz
[    1.914803] omap_i2c 20020000.i2c: bus 2 rev0.12 at 10 kHz
[    1.916234] omap_i2c 20030000.i2c: bus 3 rev0.12 at 400 kHz
[    1.916661] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.916814] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.917102] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.917446] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.919744] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.922978] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.927311] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.930622] 4a00000.serial: ttyS1 at MMIO 0x4a00000 (irq = 15, base_baud = 3000000) is a 8250
[    1.932153] 2b300000.serial: ttyS0 at MMIO 0x2b300000 (irq = 18, base_baud = 3000000) is a 8250
[    1.933473] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 29, base_baud = 3000000) is a 8250
[    3.445901] printk: console [ttyS2] enabled
[    3.451801] 2850000.serial: ttyS3 at MMIO 0x2850000 (irq = 30, base_baud = 3000000) is a 8250
[    3.460422] serial serial0: tty port ttyS3 registered
[    3.466206] omap8250 2860000.serial: PM domain pd:158 will not be powered off
[    3.473665] 2860000.serial: ttyS4 at MMIO 0x2860000 (irq = 31, base_baud = 3000000) is a 8250
[    3.482315] serial serial1: tty port ttyS4 registered
[    3.493054] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    3.506105] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[    3.512385] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    3.519515] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    3.526223] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    3.536702] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    3.551889] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    3.557449] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   13.565127] xhci-hcd xhci-hcd.2.auto: can't setup: -110
[   13.570359] xhci-hcd xhci-hcd.2.auto: USB bus 1 deregistered
[   13.576078] xhci-hcd: probe of xhci-hcd.2.auto failed with error -110
[   13.585140] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[   13.694678] sdhci-am654 fa00000.mmc: parsing dt failed (-517)
[   13.695131] mmc0: CQHCI version 5.10
[   13.697467] gpio gpiochip2: gpio-line-names is length 92 but should be at most length 87
[   13.703992] wlan_en: supplied by vdd_3v3
[   13.716637] vdd_3v3_sd: supplied by vdd_3v3
[   13.721898] mikrobus:mikrobus_port_register: registering port mikrobus-0
[   13.721964] mikrobus mikrobus-0: mikrobus port 0 eeprom empty probing default eeprom
[   13.737990] bq32k 0-0068: Oscillator Failure. Check RTC battery.
[   13.744526] bq32k 0-0068: registered as rtc0
[   13.745502] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[   13.749078] bq32k 0-0068: hctosys: unable to read the hardware clock
[   13.848234] it66121 2-004c: IT66121 revision 1 probed
[   13.862396] mmc0: Command Queue Engine enabled
[   13.866883] mmc0: new HS200 MMC card at address 0001
[   13.872664] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[   13.877502] mmcblk0boot0: mmc0:0001 TB2916 partition 1 4.00 MiB
[   13.883692] mmcblk0boot1: mmc0:0001 TB2916 partition 2 4.00 MiB
[   13.889831] mmcblk0rpmb: mmc0:0001 TB2916 partition 3 4.00 MiB, chardev (236:0)
[   13.898980]  mmcblk0: p1 p2
[   14.074634] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[   14.090096] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[   14.249552] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present!
[   14.256883] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present!
[   14.264171] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present!
[   14.271594] sdhci-am654 fa00000.mmc: Got CD GPIO
[   14.271887] mmc2: CQHCI version 5.10
[   14.271931] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[   14.274970] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[   14.275434] of_cfs_init
[   14.275476] of_cfs_init: OK
[   14.287873] mmc1: CQHCI version 5.10
[   14.333762] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[   14.344192] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[   14.354151] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
[   14.354771] Freeing unused kernel memory: 3776K
[   14.374322] mmc2: new high speed SDIO card at address 0001
[   14.425917] Checked W+X mappings: passed, no W+X pages found
[   14.431634] Run /init as init process
Loading, please wait...
[   14.459748] mmc1: new ultra high speed SDR104 SDHC card at address 5048
[   14.467740] mmcblk1: mmc1:5048 SD32G 29.7 GiB
[   14.475321]  mmcblk1: p1 p2
Starting version 249.11-0ubuntu3.10
[   15.056096] bcfserial serial1-0: bcfserial started
[   15.281657] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
[   15.440380] remoteproc remoteproc0: 30074000.pru is available
[   15.447193] remoteproc remoteproc1: 30078000.pru is available
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Warning: fsck not present, so skipping root file system
[   15.686660] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
[   15.694076] EXT4-fs (mmcblk1p2): write access will be enabled during recovery
[   15.770124] EXT4-fs (mmcblk1p2): recovery complete
[   15.776640] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[   15.958084] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   16.159425] systemd[1]: System time before build time, advancing clock.
[   16.218721] systemd[1]: systemd 249.11-0ubuntu3.10 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   16.250779] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 22.04.3 LTS!
[   16.272444] systemd[1]: Hostname set to <mindboggling>.
[   16.821627] systemd[1]: Queued start job for default target Graphical Interface.
[   16.830819] random: systemd: uninitialized urandom read (16 bytes read)
[   16.840883] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[   16.863347] random: systemd: uninitialized urandom read (16 bytes read)
[   16.871999] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[   16.895318] random: systemd: uninitialized urandom read (16 bytes read)
[   16.904224] systemd[1]: Created slice Slice /system/wpa_supplicant.
[  OK  ] Created slice Slice /system/wpa_supplicant.
[   16.928897] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[   16.951750] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[   16.975916] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[   17.000587] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  OK  ] Set up automount Arbitrary…s File System Automount Point.
[   17.027686] systemd[1]: Reached target Local Encrypted Volumes.
[  OK  ] Reached target Local Encrypted Volumes.
[   17.051810] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[   17.067453] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[   17.087591] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[   17.103634] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[   17.119818] systemd[1]: Reached target Local Verity Protected Volumes.
[  OK  ] Reached target Local Verity Protected Volumes.
[   17.144957] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[   17.160792] systemd[1]: Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
[   17.185458] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[   17.212396] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[   17.236755] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[   17.262553] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[   17.287602] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[   17.321591] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[   17.346126] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[   17.383288] systemd[1]: Mounting Huge Pages File System...
[   17.404256] systemd[1]: Mounting POSIX Message Queue File System...
[   17.433750] systemd[1]: Mounting /sys/kernel/debug...
[   17.457893] systemd[1]: Mounting Kernel Trace File System...
[   17.495261] systemd[1]: Starting Journal Service...
[   17.518558] systemd[1]: Starting Set the console keyboard layout...
[   17.545610] systemd[1]: Starting Create List of Static Device Nodes...
[   17.573696] systemd[1]: Starting Load Kernel Module configfs...
[   17.600799] systemd[1]: Starting Load Kernel Module drm...
[   17.628928] systemd[1]: Starting Load Kernel Module efi_pstore...
[   17.656506] systemd[1]: Starting Load Kernel Module fuse...
[   17.671509] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[   17.686493] systemd[1]: Starting File System Check on Root Device...
[   17.724000] systemd[1]: Starting Load Kernel Modules...
[   17.736649] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network …ts from Kernel command line...
[   17.752785] systemd[1]: Starting Coldplug All udev Devices...
[   17.768953] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted /sys/kernel/debug.
[  OK  ] Mounted Kernel Trace File System.
[  OK  ] Finished Set the console keyboard layout.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module efi_pstore.
[  OK  ] Finished Load Kernel Module fuse.[   17.837708] random: systemd-journal: uninitialized urandom read (16 bytes read)
[  OK  ] Finished Load Kernel Modules.[   17.850835] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Reached target[   17.866422] random: systemd-journal: uninitialized urandom read (16 bytes read)
 Preparation for Network.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
[  OK  ] Started File System Check Daemon to report status.
         Starting Apply Kernel Variables...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
[  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
[  OK  ] Reached target Timer Units.
[  OK  ] Closed Syslog Socket.
[  OK  ] Reached target Login Prompts.
         Starting Set console scheme...
[  OK  ] Reached target Socket Units.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Emergency Shell.
[  OK  ] Reached target Emergency Mode.
See 'systemctl status systemd-fsck-root.service' for details.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Set console scheme.
[  OK  ] Created slice Slice /system/getty.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Finished Remount Root and Kernel File Systems.
         Starting Flush Journal to Persistent Storage...
         Starting Load/Save Random Seed...
         Starting Create System Users...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Finished Create System Users.
[  OK  ] Finished Flush Journal to Persistent Storage.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Started Rule-based Manager for Device Events and Files.
         Starting Network Configuration...
[  OK  ] Started Network Configuration.
[  OK  ] Finished Load/Save Random Seed.
[   19.916574] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[   19.934979] davinci-mcasp 2b10000.mcasp: IRQ common not found
[   19.943465] remoteproc remoteproc2: request_firmware failed: -2
[   20.051591] platform 78000000.r5f: could not request atcm region for resource
[   20.058893] platform 78000000.r5f: failed to get internal memories, ret = -16
[   20.066203] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_core_of_init failed, ret = -16
[   20.075153] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_of_init failed, ret = -16
[  OK  ] Reached target Hardware activated USB gadget.
[  OK  ] Found device /dev/mmcblk1p1.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Mounting /boot/firmware...
[  OK  ] Mounted /boot/firmware.
[  OK  ] Reached target Local File Systems.
         Starting Set console font and keymap...
         Starting Set Up Additional Binary Formats...
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Set console font and keymap.
[  OK  ] Finished Create Volatile Files and Directories.
         Mounting Arbitrary Executable File Formats File System...
         Starting Network Name Resolution...
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Mounted Arbitrary Executable File Formats File System.
[  OK  ] Finished Set Up Additional Binary Formats.
[  OK  ] Reached target Sound Card.
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
         Starting Record Runlevel Change in UTMP...
[  OK  ] Finished Record Runlevel Change in UTMP.
[   21.076323] wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Created slice Slice /system/hostapd.
[  OK  ] Stopped target Emergency Mode.
[  OK  ] Stopped Emergency Shell.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Access point and …i-Fi and Ethernet (SoftAp0)...
         Starting Hostname Service...
[  OK  ] Started Access point and a… Wi-Fi and Ethernet (SoftAp0).
[  OK  ] Started Hostname Service.
idk, honestly after ^ this message a login prompt should have shown up… I’ll have to test it later tonight when i get home.
Okay here’s my image, this build:
https://rcn-ee.net/rootfs/ubuntu-arm64-22.04-console-v5.10-ti/2023-09-21/
it’s built in jenkins with this script: ci/daily-ubuntu-arm64-2204-minimal-v5.10-ti-am62.sh · master · BeagleBoard.org / image-builder · GitLab
with:
sudo ./setup_sdcard.sh --img-${filesize} beagleplay-${export_filename} --dtb beagleplay --hostname BeaglePlay
so not that much different then your build…
U-Boot SPL 2023.04-g52a1bfa3 (Sep 15 2023 - 21:47:38 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.7--v09.00.07 (Kool Koala)')
SPL initial stack usage: 13376 bytes
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.9(release):cc933e1
NOTICE:  BL31: Built : 21:47:38, Sep 15 2023
I/TC:
I/TC: OP-TEE version: 7c24332 (gcc version 11.2.0 (Ubuntu 11.2.0-19ubuntu1)) #1 Fri Sep 15 21:47:38 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.7--v09.00.07 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
SPL initial stack usage: 1856 bytes
U-Boot 2023.04-g52a1bfa3 (Sep 15 2023 - 21:47:38 +0000)
SoC:   AM62X SR1.0 GP
Model: BeagleBoard.org BeaglePlay
Board: BEAGLEPLAY-A0- rev 02
DRAM:  2 GiB
Core:  88 devices, 29 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Error: Can't set serial# to SSSS
Net:   Could not get PHY for ethernet@8000000port@1: addr 0
am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
No ethernet found.
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
BeaglePlay microSD (extlinux.conf) Options
2:	BeaglePlay microSD disable BCFSERIAL
3:	BeaglePlay copy microSD to eMMC
Enter choice: 4:	BeaglePlay microSD (default)
   Loading Ramdisk to 8f2d2000, end 8ffff12c ... OK
Starting kernel ...
[    1.934993] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[    1.954702] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    2.069319] sdhci-am654 fa00000.mmc: parsing dt failed (-517)
[    2.086314] bq32k 0-0068: hctosys: unable to read the hardware clock
[    2.559501] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present!
[    2.566808] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present!
[    2.574084] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present!
[    2.581797] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    6.930880] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[    6.980511] remoteproc remoteproc2: request_firmware failed: -2
[    7.048800] davinci-mcasp 2b10000.mcasp: IRQ common not found
[    7.135495] platform 78000000.r5f: could not request atcm region for resource
[    7.142829] platform 78000000.r5f: failed to get internal memories, ret = -16
[    7.150072] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_core_of_init failed, ret = -16
[    7.159115] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_of_init failed, ret = -16
[    9.255300] wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2
Ubuntu 22.04.3 LTS BeaglePlay ttyS2
rcn-ee.net Ubuntu 22.04.3 Console Image 2023-09-21
Support: https://forum.digikey.com/
default username:password is [ubuntu:temppwd]
BeaglePlay login: ubuntu
Password:
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
ubuntu@BeaglePlay:~$ cat /etc/dogtag
So since, your image is acting strange… Are you building in a virtual environment? VMware, VirtualBox, WSL, etc?
official builds are done on native Debian machine (RPI4’s, BBAI64’s or QEMU…) but on a native Debian install…
Thanks for support, @RobertCNelson. The downloaded image works. I’m going to use them with Packer to do image customisation.
I’ve run the script on Ubuntu 23.04 on AMD64 thinking it does qemu under the hood, so maybe that’s the issue. The script doesn’t warn.
Your CI script you linked has copy&paste bug saying it provisions Debian 11 image, despite attempt to provision Ubuntu image.
