Hello…I think, via some debugging probe on uart0, I have a dirty form of u-boot on my board.
My BeagleV-Fire cannot update/upgrade any longer and I wanted to update the board…
Are there any ideas floating around outside of the docs.beagleboard.org pages that may help?
If need be, I can try to use SoftConsole and/or Libero Software. Please let me know which route I should take and what data you need to help me.
Update
Also, it seems it is looking for a user button on the output. I am guessing here but I think that the user button in this output once stated is for SD Card usage. Is there a way to hardwire and button for this usage? I grabbed the latest artifact.zip on openbeagle.org under BeagleV-Fire-ubuntu and flashed it but without knowing what exactly to do…
Send guidance once you have time. I will try to stay patient.
Okay…
mmc
usbdmsc
The commands work and are successful but…
- My board on Ubuntu Jammy does not show as a USB Device
- My board on Debian Bookworm does not show as a USB Device
- Off to try WSL2
I will report back.
And Yep,
I cannot update nor can I update the image to the older image. Is there any workaround for getting a working system for the BeagleV-Fire so I can test the build process?
P.S. WSL2 does not show a USB device either. I tried different combinations of OSs and still notta. Send guidance and/or instructions, please.
Instructions for what Seth?
You’re kinda all over the map here. Is your usbdmsc working or not?
Windows doesn’t recognize my Beagle when in dmsc mode either,
but I have a ThinkStation Tiny, running Linux natively, that does,
so I just dd a known good image from there.
Yes but not so much…
usbdmsc works but the device is not connecting either via MTD or another route. I have no networking on the board for now for whatever reason.
P.S. I am not well-renowned in dd for now. I mean, I can purport images via dd but not with confidence. I will try. Does the board need networking to handle dd?
Apart for downloading the image itself to the “donor” machine, no networking is required.
Okay. How would I go about flashing the BeagleV-Fire? Would I need to have a specific library installed on a Linux Distro?
I read and reread the docs.beagleboard.org instructions and I have not gotten the thing to boot via micro SD Card or via Balena or via USB. I even tried to run through the scripts to install via bmap tools.
I have a 3.3v UART0 connection, GND, and I checked the device in /dev/. My board connects but not for Balena or bmap-tools.
Oh! I know what I did not try. I did not try to use dd or the sudo bmaptool copy sdcard.img /dev/sde
Sheesh. I just understood what you were saying.
P.S. Bless you fine young sir!
I will test dd and/or bmaptool.
P.S. I was expecting the USB C to USB C to connect magically to Balena Etcher and for my sdcard.img to then be installed via Etcher. Thonk.
This is what I do:
- Find the proper device when connected via
lsblk.
- Use
sudo dd if=sdcard.img of=/dev/sda bs=512 status=progress to transfer the image.
Change sda to match the right one from lsblk.
I used sudo bmap …
It is doing something. I will call it a clean sweep once it finalizes!
@lranders ,
Yeppers…I got it good this time. sudo bmaptool copy sdcard.img /dev/sdc worked on my current desktop on a Debian Distro. It fooled me long enough and I finally got it this time around.
P.S. yeppers.
