I grabbed a day old image from openbeagle.org and then applied it to the BeagleV-Fire.
sudo bmaptool copy sdcard.img /dev/sde is the command given and it works. The only issue I see is that when I get into debug sessions, the mmc and usbdmsc commands work but only mmc provides a safe avenue to usbdmsc.
Then, the command usbdmsc only writes so many bytes to the BeagleV-Fire.
I was thinking of pushing ROS2 on this board since it accepts Ubuntu Builds.
P.S. Are there any known, working images from the openbeagle.org build artifacts that one can recommend?
