BeagleY-AI adding overlays when using NVMe hangs boot
Adding an overlay when using SD card is fine.
Adding an overlay when using NVMe hangs the boot. Not sure how far along it goes because the networking does not come up either so I cannot ssh into it. The debug port connector is different on this board than the ai64 so I will have to wait until it arrives to see what is going on. Also the kernel messages are not being output to the screen.
Testing in a bit, which overlay did you try to load?
Imx219, spi, i2c.
What might have happened is the video died on it.
Sequence of events.
  1. Green and pink monitor
  2. Next time it was fired up, works fine.
  3. Overlays loaded when on SD
Some point I installed a fresh image before NVMe setup
  1. Removed some packages like node-red, nginx
  2. Set it up for NVMe, that worked perfect.
  3. Added 3 overalys and it hung up, assumed fat fingers.
  4. Removed one at time, no boot
  5. Removed all of them, no boot.
  6. Did notice the heartbeat (green) is running so the kernel has to be up.
Not sure what to think at this point, did an RMA on it.
Well i’m getting stuck in the initramfs…
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
BeagleY-AI NVMe (extlinux.conf) (swap enabled)
1:	return to microSD
2:	NVMe (debug)
3:	NVMe (default)
Enter choice: 3:	NVMe (default)
Retrieving file: /Image
Retrieving file: /initrd.img
append: console=ttyS2,115200n8 root=/dev/nvme0n1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
Retrieving file: /ti/k3-am67a-beagley-ai.dtb
Retrieving file: /overlays/k3-am67a-beagley-ai-pwm-epwm0-gpio14.dtbo
## Flattened Device Tree blob at 88000000
Working FDT set to 88000000
   Loading Ramdisk to 8e9e7000, end 8ffff59b ... OK
   Loading Device Tree to 000000008e9c7000, end 000000008e9e6fff ... OK
Working FDT set to 8e9c7000
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.968604] Initramfs unpacking failed: ZSTD-compressed data is corrupt
[    1.545469] omap8250 2860000.serial: Failed to create device link (0x180) with regulator-3
[    2.950600] debugfs: Directory 'pd:249' with parent 'pm_genpd' already present!
[    2.958023] debugfs: Directory 'pd:248' with parent 'pm_genpd' already present!
[    2.965363] debugfs: Directory 'pd:247' with parent 'pm_genpd' already present!
[    2.972902] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.980303] debugfs: Directory 'pd:244' with parent 'pm_genpd' already present!
[    2.990057] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.997507] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
/scripts/init-top/udev: 24: /scripts/init-top/udev: /lib/systemd/systemd-udevd: not found
/scripts/init-premount/plymouth: 35: /scripts/init-premount/plymouth: /usr/sbin/plymouthd: not found
/scripts/local-premount/btrfs: 21: /scripts/local-premount/btrfs: modprobe: not found
trap: EXIT: bad trap
Failed to send exit request: No such file or directory
run-init: opening console: No such file or directory
Target filesystem doesn't have requested /sbin/init.
No init found. Try passing init= bootarg.
(initramfs)
Green LED is still blinking…
If i enable more debug… earlycon=ns16550a,mmio32,0x02800000
mmc1 is current device
Scanning mmc 1:1...
2:	NVMe (debug)
3:	NVMe (default)
Enter choice: 2
2:	NVMe (debug)
append: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nvme0n1p2 ro rootfstype=ext4 rootwait net.ifnames=0
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.80-ti-arm64-r58 (voodoo@rpi5b8g-65) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1bookworm SMP PREEMPT_DYNAMIC Sun Jun 23 01:29:22 UTC 2024
[    0.000000] Machine model: BeagleBoard.org BeagleY-AI
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x00000008c8000000, size 896 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node main-r5fss-dma-memory-region@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node main-r5fss-memory-region@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c7x-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c7x-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c7x-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c7x-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a6bfffff]
[    0.000000]   node   0: [mem 0x00000000a6c00000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 30 pages/cpu s84520 r8192 d30168 u122880
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nvme0n1p2 ro rootfstype=ext4 rootwait net.ifnames=0
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 1970748K/4194304K available (17920K kernel code, 2912K rwdata, 5332K rodata, 6080K init, 1156K bss, 339028K reserved, 917504K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 56050 entries in 219 pages
[    0.000000] ftrace: allocated 219 pages with 6 groups
[    0.000000] trace event string verifier disabled
[    0.000000] Dynamic Preempt: voluntary
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880200000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880210000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008705] Console: colour dummy device 80x25
[    0.013299] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023960] pid_max: default: 32768 minimum: 301
[    0.028907] LSM: Security Framework initializing
[    0.033704] landlock: Up and running.
[    0.037435] Yama: becoming mindful.
[    0.041107] AppArmor: AppArmor initialized
[    0.045291] TOMOYO Linux initialized
[    0.048952] LSM support for eBPF active
[    0.053023] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.060590] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.070814] cblist_init_generic: Setting adjustable number of callback queues.
[    0.078237] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.084541] cblist_init_generic: Setting adjustable number of callback queues.
[    0.091915] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.098212] cblist_init_generic: Setting adjustable number of callback queues.
[    0.105585] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.111996] rcu: Hierarchical SRCU implementation.
[    0.116889] rcu: 	Max phase no-delay instances is 1000.
[    0.123595] Platform MSI: msi-controller@1820000 domain created
[    0.130134] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.139816] EFI services will not be available.
[    0.145025] smp: Bringing up secondary CPUs ...
[    0.158421] Detected VIPT I-cache on CPU1
[    0.158538] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.158556] GICv3: CPU1: using allocated LPI pending table @0x0000000880220000
[    0.158606] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.167404] Detected VIPT I-cache on CPU2
[    0.167496] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.167512] GICv3: CPU2: using allocated LPI pending table @0x0000000880230000
[    0.167547] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.176288] Detected VIPT I-cache on CPU3
[    0.176376] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.176391] GICv3: CPU3: using allocated LPI pending table @0x0000000880240000
[    0.176421] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.176505] smp: Brought up 1 node, 4 CPUs
[    0.256067] SMP: Total of 4 processors activated.
[    0.260867] CPU features: detected: 32-bit EL0 Support
[    0.266110] CPU features: detected: 32-bit EL1 Support
[    0.271355] CPU features: detected: CRC32 instructions
[    0.276670] CPU: All CPU(s) started at EL2
[    0.280873] alternatives: applying system-wide alternatives
[    0.309441] node 0 deferred pages initialised in 20ms
[    0.316082] devtmpfs: initialized
[    0.339396] Registered cp15_barrier emulation handler
[    0.344600] Registered setend emulation handler
[    0.349526] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.359500] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.396402] pinctrl core: initialized pinctrl subsystem
[    0.402480] DMI not present or invalid.
[    0.407111] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.414496] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.421887] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.429938] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.438079] audit: initializing netlink subsys (disabled)
[    0.443829] audit: type=2000 audit(0.308:1): state=initialized audit_enabled=0 res=1
[    0.444369] thermal_sys: Registered thermal governor 'fair_share'
[    0.451746] thermal_sys: Registered thermal governor 'bang_bang'
[    0.457967] thermal_sys: Registered thermal governor 'step_wise'
[    0.464098] thermal_sys: Registered thermal governor 'user_space'
[    0.470226] thermal_sys: Registered thermal governor 'power_allocator'
[    0.476734] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.490430] ASID allocator initialised with 65536 entries
[    0.531666] KASLR disabled due to lack of seed
[    0.544906] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.551867] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.558329] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.565262] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.571665] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.578595] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.584998] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.591932] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.599927] raid6: skipped pq benchmark and selected neonx8
[    0.605692] raid6: using neon recovery algorithm
[    0.610967] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
[    0.622230] iommu: Default domain type: Translated
[    0.627243] iommu: DMA domain TLB invalidation policy: strict mode
[    0.634365] SCSI subsystem initialized
[    0.638608] usbcore: registered new interface driver usbfs
[    0.644262] usbcore: registered new interface driver hub
[    0.649722] usbcore: registered new device driver usb
[    0.655682] pps_core: LinuxPPS API ver. 1 registered
[    0.660758] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.670094] PTP clock support registered
[    0.674808] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[    0.681703] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[    0.688521] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[    0.695436] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
[    0.703431] NetLabel: Initializing
[    0.706929] NetLabel:  domain hash size = 128
[    0.711379] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.717211] NetLabel:  unlabeled traffic allowed by default
[    0.723347] vgaarb: loaded
[    0.727725] clocksource: Switched to clocksource arch_sys_counter
[    0.734512] VFS: Disk quotas dquot_6.6.0
[    0.738593] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.745780] FS-Cache: Loaded
[    0.749168] CacheFiles: Loaded
[    0.752832] AppArmor: AppArmor Filesystem Enabled
[    0.765296] NET: Registered PF_INET protocol family
[    0.770552] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.781132] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.789934] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.797947] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.806416] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.814895] TCP: Hash tables configured (established 32768 bind 32768)
[    0.822079] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.829824] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.836756] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.844342] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.850903] RPC: Registered named UNIX socket transport module.
[    0.856980] RPC: Registered udp transport module.
[    0.861785] RPC: Registered tcp transport module.
[    0.866584] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.873190] NET: Registered PF_XDP protocol family
[    0.878092] PCI: CLS 0 bytes, default 64
[    0.882496] Trying to unpack rootfs image as initramfs...
[    0.905874] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.916039] kvm [1]: IPA Size Limit: 40 bits
[    0.921601] kvm [1]: vgic-v2@100020000
[    0.925518] kvm [1]: GIC system register CPU interface enabled
[    0.936112] kvm [1]: vgic interrupt IRQ9
[    0.944125] kvm [1]: Hyp mode initialized successfully
[    1.457245] Initialise system trusted keyrings
[    1.462325] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.475595] zbud: loaded
[    1.481701] NFS: Registering the id_resolver key type
[    1.487060] Key type id_resolver registered
[    1.491401] Key type id_legacy registered
[    1.495780] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.502698] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.510736] fuse: init (API version 7.37)
[    1.552781] NET: Registered PF_ALG protocol family
[    1.557765] xor: measuring software checksum speed
[    1.566485]    8regs           :  2625 MB/sec
[    1.574759]    32regs          :  2626 MB/sec
[    1.583348]    arm64_neon      :  2421 MB/sec
[    1.587835] xor: using function: 32regs (2626 MB/sec)
[    1.593048] Key type asymmetric registered
[    1.597288] Asymmetric key parser 'x509' registered
[    1.602332] Asymmetric key parser 'pkcs8' registered
[    1.687186] Initramfs unpacking failed: ZSTD-compressed data is corrupt
[    1.702421] Freeing initrd memory: 22624K
[    1.708154] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    1.714177] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.721899] io scheduler mq-deadline registered
[    1.732342] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    1.740441] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    1.757715] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    1.772411] SPI driver tps6594 has no spi_device_id for ti,tps6594-q1
[    1.779016] SPI driver tps6594 has no spi_device_id for ti,tps6593-q1
[    1.785594] SPI driver tps6594 has no spi_device_id for ti,lp8764-q1
[    1.792816] megasas: 07.719.03.00-rc1
[    1.803231] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.809664] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.815851] sky2: driver version 1.30
[    1.821140] VFIO - User Level meta-driver version: 0.3
[    1.828735] usbcore: registered new device driver onboard-usb-hub
[    1.837495] i2c_dev: i2c /dev entries driver
[    1.842282] Driver for 1-wire Dallas network protocol.
[    1.849423] sdhci: Secure Digital Host Controller Interface driver
[    1.855743] sdhci: Copyright(c) Pierre Ossman
[    1.860568] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.868094] ledtrig-cpu: registered to indicate activity on CPUs
[    1.874887] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.882471] hid: raw HID events driver (C) Jiri Kosina
[    1.888159] usbcore: registered new interface driver usbhid
[    1.893864] usbhid: USB HID core driver
[    1.899906] optee: probing for conduit method.
[    1.904485] optee: revision 4.2 (12d7c4ee)
[    1.921063] optee: dynamic shared memory is enabled
[    1.930460] optee: initialized driver
[    1.935920] NET: Registered PF_INET6 protocol family
[    1.943809] Segment Routing with IPv6
[    1.947609] In-situ OAM (IOAM) with IPv6
[    1.951685] mip6: Mobile IPv6
[    1.954733] NET: Registered PF_PACKET protocol family
[    1.960107] Key type dns_resolver registered
[    1.964477] mpls_gso: MPLS GSO support
[    1.969042] registered taskstats version 1
[    1.973279] Loading compiled-in X.509 certificates
[    1.979060] zswap: loaded using pool lzo/zsmalloc
[    1.984378] Key type .fscrypt registered
[    1.988399] Key type fscrypt-provisioning registered
[    1.995512] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[    2.002751] Key type encrypted registered
[    2.006870] AppArmor: AppArmor sha1 policy hashing enabled
[    2.012507] ima: No TPM chip found, activating TPM-bypass!
[    2.018128] ima: Allocated hash algorithm: sha256
[    2.022979] ima: No architecture policies found
[    2.027650] evm: Initialising EVM extended attributes:
[    2.032895] evm: security.selinux
[    2.036279] evm: security.SMACK64 (disabled)
[    2.040635] evm: security.SMACK64EXEC (disabled)
[    2.045347] evm: security.SMACK64TRANSMUTE (disabled)
[    2.050522] evm: security.SMACK64MMAP (disabled)
[    2.055237] evm: security.apparmor
[    2.058708] evm: security.ima
[    2.061734] evm: security.capability
[    2.065383] evm: HMAC attrs: 0x1
[    2.082424] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--w2023.01-j722s (Kool Koa')
[    2.162016] omap_i2c 4900000.i2c: bus 1 rev0.12 at 100 kHz
[    2.209448] input: tps65219-pwrbutton as /devices/platform/bus@f0000/bus@f0000:bus@b00000/2b200000.i2c/i2c-2/2-0030/tps65219-pwrbutton.2.auto/input/input0
[    2.228584] rtc-ds1307 2-0068: registered as rtc0
[    2.234865] rtc-ds1307 2-0068: setting system clock to 2024-06-23T17:41:39 UTC (1719164499)
[    2.243491] omap_i2c 2b200000.i2c: bus 2 rev0.12 at 100 kHz
[    2.250667] omap_i2c 20000000.i2c: bus 3 rev0.12 at 400 kHz
[    2.257803] omap_i2c 20010000.i2c: bus 4 rev0.12 at 100 kHz
[    2.264869] omap_i2c 20020000.i2c: bus 5 rev0.12 at 400 kHz
[    2.270881] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    2.279335] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    2.288585] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    2.297639] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
[    2.314567] ti-udma 485c0100.dma-controller: Number of rings: 82
[    2.323023] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16)
[    2.334539] ti-udma 485c0000.dma-controller: Number of rings: 150
[    2.345206] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    2.355272] ti-udma 4e230000.dma-controller: Number of rings: 40
[    2.362802] ti-udma 4e230000.dma-controller: Channels: 20 (bchan: 0, tchan: 8, rchan: 12)
[    2.373351] printk: console [ttyS2] disabled
[    2.377792] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 327, base_baud = 3000000) is a 8250
[    2.386646] printk: console [ttyS2] enabled
[    2.395102] printk: bootconsole [ns16550a0] disabled
[    2.406372] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 328, base_baud = 3000000) is a 8250
[    2.415906] omap8250 2860000.serial: PM domain pd:158 will not be powered off
[    2.423363] 2860000.serial: ttyS6 at MMIO 0x2860000 (irq = 329, base_baud = 3000000) is a 8250
[    2.432106] serial serial0: tty port ttyS6 registered
[    2.479735] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
[    2.489590] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    2.497731] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
[    2.510834] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    2.517969] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    2.524631] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
[    2.535758] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    2.551535] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[    2.671054] omap8250 2860000.serial: Failed to create device link (0x180) with regulator-3
[    2.735857] it66121 4-004c: IT66121 revision 0 probed
[    2.745250] j721e-pcie-host f102000.pcie: host bridge /pcie@f102000 ranges:
[    2.752259] j721e-pcie-host f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
[    2.760787] j721e-pcie-host f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
[    2.769311] j721e-pcie-host f102000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.881842] j721e-pcie-host f102000.pcie: Link up
[    2.886721] j721e-pcie-host f102000.pcie: PCI host bridge to bus 0000:00
[    2.893424] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.898908] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
[    2.908375] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
[    2.915272] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
[    2.921347] pci 0000:00:00.0: supports D1
[    2.925354] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.931122] pci 0000:00:00.0: PTM enabled (root), 4ns granularity
[    2.941116] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.949329] pci 0000:01:00.0: [15b7:5017] type 00 class 0x010802
[    2.955376] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    2.962471] pci 0000:01:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[    4.095809] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    4.102456] pci 0000:00:00.0: BAR 14: assigned [mem 0x68100000-0x681fffff]
[    4.109333] pci 0000:01:00.0: BAR 0: assigned [mem 0x68100000-0x68103fff 64bit]
[    4.116652] pci 0000:00:00.0: PCI bridge to [bus 01]
[    4.121614] pci 0000:00:00.0:   bridge window [mem 0x68100000-0x681fffff]
[    4.128705] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    4.135110] pcieport 0000:00:00.0: PME: Signaling with IRQ 538
[    4.141316] pcieport 0000:00:00.0: AER: enabled with IRQ 538
[    4.147567] nvme nvme0: pci function 0000:01:00.0
[    4.152332] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    4.167943] hwmon hwmon0: temp1_input not attached to any thermal zone
[    4.174611] hwmon hwmon0: temp2_input not attached to any thermal zone
[    4.181218] hwmon hwmon0: temp3_input not attached to any thermal zone
[    4.220485] nvme nvme0: allocated 32 MiB host memory buffer.
[    4.228736] nvme nvme0: 4/0/0 default/read/poll queues
[    4.230362] [drm] Initialized tidss 1.0.0 20180215 for 30220000.dss on minor 0
[    4.242298] tidss 30220000.dss: [drm] Cannot find any crtc or sizes
[    4.250104] tidss 30220000.dss: [drm] Cannot find any crtc or sizes
[    4.251230]  nvme0n1: p1 p2
[    4.258171] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    4.264712] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1
[    4.272669] xhci-hcd xhci-hcd.5.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
[    4.282101] xhci-hcd xhci-hcd.5.auto: irq 545, io mem 0x31210000
[    4.288321] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    4.293813] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2
[    4.301476] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[    4.308194] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    4.316461] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.323675] usb usb1: Product: xHCI Host Controller
[    4.328548] usb usb1: Manufacturer: Linux 6.1.80-ti-arm64-r58 xhci-hcd
[    4.335066] usb usb1: SerialNumber: xhci-hcd.5.auto
[    4.340509] hub 1-0:1.0: USB hub found
[    4.344321] hub 1-0:1.0: 1 port detected
[    4.355850] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.364063] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    4.372328] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.379544] usb usb2: Product: xHCI Host Controller
[    4.384418] usb usb2: Manufacturer: Linux 6.1.80-ti-arm64-r58 xhci-hcd
[    4.390938] usb usb2: SerialNumber: xhci-hcd.5.auto
[    4.396370] hub 2-0:1.0: USB hub found
[    4.400155] hub 2-0:1.0: 1 port detected
[    4.406077] sdhci-am654 fa00000.mmc: Got CD GPIO
[    4.406727] mmc2: CQHCI version 5.10
[    4.408641] debugfs: Directory 'pd:249' with parent 'pm_genpd' already present!
[    4.408687] debugfs: Directory 'pd:248' with parent 'pm_genpd' already present!
[    4.408722] debugfs: Directory 'pd:247' with parent 'pm_genpd' already present!
[    4.408956] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    4.409028] debugfs: Directory 'pd:244' with parent 'pm_genpd' already present!
[    4.411019] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    4.411342] mmc1: CQHCI version 5.10
[    4.451742] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[    4.452451] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    4.458326] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    4.489309] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
[    4.503066] Freeing unused kernel memory: 6080K
[    4.509796] mmc2: new high speed SDIO card at address 0001
[    4.533625] mmc1: new ultra high speed SDR104 SDHC card at address 0001
[    4.541260] mmcblk1: mmc1:0001 GB1QT 29.8 GiB
[    4.548221]  mmcblk1: p1 p2 p3
[    4.570812] Checked W+X mappings: passed, no W+X pages found
[    4.576519] Run /init as init process
Loading, please wait...
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... /scripts/init-premount/plymouth: 35: /scripts/init-premount/plymouth: /usr/sbin/plymouthd: not found
done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... /scripts/local-premount/btrfs: 21: /scripts/local-premount/btrfs: modprobe: not found
Scanning for Btrfs filesystems
done.
Warning: fsck not present, so skipping root file system
[    4.863097] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... trap: EXIT: bad trap
done.
(initramfs) [
and if i disable the fdtoverlays it boots fine… weird! something is corrupting something!
Scanning mmc 1:1...
2:	NVMe (debug)
3:	NVMe (default)
Enter choice: 2
2:	NVMe (debug)
   Loading Device Tree to 000000008e9c9000, end 000000008e9e6c63 ... OK
Working FDT set to 8e9c9000
Starting kernel ...
voodoo@beagley-ai:~$ lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
mmcblk1     179:0    0  29.8G  0 disk
├─mmcblk1p1 179:1    0   256M  0 part /boot/firmware
├─mmcblk1p2 179:2    0     4G  0 part
└─mmcblk1p3 179:3    0  25.6G  0 part
nvme0n1     259:0    0 931.5G  0 disk
├─nvme0n1p1 259:1    0     4G  0 part [SWAP]
└─nvme0n1p2 259:2    0 927.5G  0 part /
voodoo@beagley-ai:~$ cat /boot/firmware/extlinux/extlinux.conf
menu title BeagleY-AI NVMe (extlinux.conf) (swap enabled)
timeout 50
default NVMe (default)
label return to microSD
    kernel /Image
    append console=ttyS2,115200n8 root=/dev/mmcblk1p3 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
    fdtdir /
    fdt /ti/k3-am67a-beagley-ai.dtb
    initrd /initrd.img
label NVMe (debug)
    kernel /Image
    append console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nvme0n1p2 ro rootfstype=ext4 rootwait net.ifnames=0
    fdtdir /
    initrd /initrd.img
label NVMe (default)
    kernel /Image
    append console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nvme0n1p2 ro rootfstype=ext4 resume=/dev/nvme0n1p1 rootwait net.ifnames=0 quiet
    fdtdir /
    #fdtoverlays /overlays/<file>.dtbo
    fdtoverlays /overlays/k3-am67a-beagley-ai-pwm-epwm0-gpio14.dtbo
    initrd /initrd.img
voodoo@beagley-ai:~$ cat /proc/cmdline
So pci/nvme boot + fdtoverlays can’t find init
Got it! it’s teh intrd.img…
voodoo@beagley-ai:~$ sudo beagle-version
[sudo] password for voodoo:
eeprom:[BYAI202405000229]
model:[BeagleBoard.org_BeagleY-AI]
dogtag:[BeagleBoard.org Debian Bookworm Xfce Image 2024-06-22]
bootloader:[/dev/mmcblk1]:[/boot/firmware/tiboot3.bin]:[U-Boot SPL 2023.04-g93735daa (Jun 14 2024 - 23:22:59 +0000)]
bootloader:[/dev/mmcblk1]:[/boot/firmware/tispl.bin]:[U-Boot SPL 2023.04-g93735daa (Jun 14 2024 - 23:22:59 +0000)]
bootloader:[/dev/mmcblk1]:[/boot/firmware/u-boot.img]:[U-Boot 2023.04-g93735daa (Jun 14 2024 - 23:22:59 +0000)]
UBOOT: Booted Device-Tree:[k3-am67a-beagley-ai.dts]
UBOOT: Loaded Overlay:[k3-am67a-beagley-ai-pwm-epwm0-gpio14.kernel]
Edit this works fine:
    kernel /Image
    fdtdir /
    #initrd /initrd.img
Pushed as: bb-u-boot-beagley-ai (2023.04.20240319.19) (21218e16) · Commits · BeagleBoard.org / repos-arm64 · GitLab
So nvme will not use initrd till we figure out what’s happening…
and package built and pushed to apt repo…
starting image generation…
I will power it back up and see if hdmi comes up with the new image. Are you going to build a new image, I used the one in beagle imager.
Image is now up: Index of /rootfs/debian-arm64-12-bookworm-xfce-v6.1-ti/2024-06-23
in bb-imager, use the “Use Custom” option and select ^ for the file you downloaded
Just loaded it up on the new image. Screen is still dead, green heartbeat went on then turned solid red then its back to green heartbeat. Drawing 96 mA. so something is running. The other board should arrive and I will use this current SD and see what happens.
Update. It just booted with video, this is on the new image. I was wiggling the connector on the board…
Got the debug port up, looks like board sn/209 has an issue with the SD. The other board arrived today and it is working fine. SD boots fine in sn/497, swapped sd cards several time each time 497 would boot. 209 was having trouble with reading sd card. Here is output.
\00
U-Boot SPL 2023.04-g93735daa (Jun 23 2024 - 18:02:19 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--w2023.01-j722s (Kool Koa')
SPL initial stack usage: 17048 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.11.0(release):0567eca
NOTICE:  BL31: Built : 18:02:19, Jun 23 2024
NOTICE:  Upgrade Firmwares for Power off functionality
ERROR:   Failed to get response (-19)
ERROR:   Transfer send failed (-19)
ERROR:   Unable to query firmware capabilities (-19)
I/TC:
I/TC: OP-TEE version: 4.2.0 (gcc version 12.2.0 (Debian 12.2.0-14)) #1 Sun Jun 23 18:02:19 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--w2023.01-j722s (Kool Koa')
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2023.04-g93735daa (Jun 23 2024 - 18:02:19 +0000)
SoC:   J722S SR1.0 HS-FS
Model: BeagleBoard.org BeagleY-AI
DRAM:  2 GiB (effective 4 GiB)
Core:  104 devices, 28 uclasses, devicetree: separate
MMC:   mmc@fa00000: 1, mmc@fa20000: 2
Loading Environment from nowhere... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
MMC Device 0 not found
no mmc device at slot 0
Scanning mmc 1:1...
BeagleY-AI microSD (extlinux.conf) (swap enabled)
1:	microSD (production test)
2:	transfer microSD rootfs to NVMe (advanced)
3:	microSD (debug)
4:	microSD (default)
Enter choice: 4:	microSD (default)
append: console=ttyS2,115200n8 root=/dev/mmcblk1p3 ro rootfstype=ext4 resume=/dev/mmcblk1p2 rootwait net.ifnames=0 quiet
   Loading Ramdisk to 8ea0d000, end 8ffff640 ... OK
   Loading Device Tree to 000000008e9ef000, end 000000008ea0cc63 ... OK
Working FDT set to 8e9ef000
Starting kernel ...
[    1.440453] rtc-ds1307 2-0068: hctosys: unable to read the hardware clock
[    1.660928] omap8250 2860000.serial: Failed to create device link (0x180) with regulator-3
[    2.834485] debugfs: Directory 'pd:249' with parent 'pm_genpd' already present!
[    2.841880] debugfs: Directory 'pd:248' with parent 'pm_genpd' already present!
[    2.849238] debugfs: Directory 'pd:247' with parent 'pm_genpd' already present!
[    2.856775] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.864161] debugfs: Directory 'pd:244' with parent 'pm_genpd' already present!
[    2.873474] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.880826] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.923028] mmc1: error -110 whilst initialising SD card
[    3.062685] mmc1: error -110 whilst initialising SD card
[    3.213134] mmc1: error -110 whilst initialising SD card
[    3.364292] mmc1: error -110 whilst initialising SD card
e[2Je[3Je[-1;-1f\00
The jiberish on the tail is from the board.
Then after a while this one shows up.
Gave up waiting for suspend/resume device
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/mmcblk1p3 does not exist.  Dropping to a shell!
(initramfs)
that’s some of the same issues we’ve seen on the Play and AI64, some microSD cards just don’t work… What model and brand? @Grippy98
PNY 32 gb. (green/gray)
That is odd, been using these for several years and they have booted all BB products, Khadas, NXP, Pi without any problems.
Even went so far as to overwrite all of it, assumed it might have a hole somewhere and that did not help.
What brand/cap do you recommend?
A guess, maybe its related to the clock drifting?? Not sure how they generate the master clock, the old days we had a crystal for the osc.
A few times it did boot okay, must be something on the limits. Since the first boot it was a pink and green screen it could be linked to timing. The next day it was fine, the screenshot was in correct color.
Just had another 20 of these delivered…
But I go thru so many flash-reflash-flash cycles on a normal day. At some point I get I/o errors on my USB adapter, I just throw it out and open a new one… plus all the boards running 24/7 and me adding more boards to CI…
All of them verify as correct after the image is laid down. Are you letting them verify after the burning process?
I will order some of the ones you are using and see what happens.
No, if you flash a microSD a few hundred times, at some point the controller just gives up!
