Hello There…it seems whenever I figured this would work, I was mistaken.
I got a part number ZP-0110 from S2PI but for some reason I was mistaken… Do not get this item.
It will not fit the BeagleY-AI (I think).
P.S. Speaking Heatsinks, does anyone know of where to get one that may fit for the BeagleY-AI?
RPI 5 is exact fit, also, it works out of the box, bby has it already enabled and same connector. I believe I added some thermal tape in the appropriate thickness. You will see when you get it since the layout is different.
5 and A-Okay. I got another variation.
P.S. Back to shopping (my nemesis).
Hey…
I found one: Raspberry Pi 5 Official Active Cooler
They say official but not for the BeagleY-AI.
Did beagleboard.org people make their WiFi Adapter or something?
BeagleY-AI is a direct clone of RPi5 form factor. Mechanically speaking, all the official RPi accessories are compatible, including the Active Cooler (in fact, the last page of the QSG shows photos using the Active Cooler: BeagleY-AI Quick Start — BeagleBoard Documentation)
WiFi/BLE module is the BM3301 (BEAGL-3P-BEAGLEMOD-CC33 by BeagleBoard.org Foundation | TI.com) based on TI’s CC3301 chipset in a 13x13mm footprint that is backwards compatible with WL1807MOD.
@brainbern , no issue and thank you for clarifying. I see now what I purchased at first was for a PI thing but before the 5. The docs. have all sorts of data to use for these boards.
