I spent a while getting EdgeAI 11.02 (PSDK 11.02.01.03 debs) fully working on a 4 GB BeagleY-AI - Armbian vendor image, kernel 6.12.49 - and wrote up everything that bit me, because most of it fails silently and isn’t documented anywhere.
What’s covered, all verified on hardware:
DTB selection: fdtfile in armbianEnv.txt is silently ignored by the uEnv.txt → bootcmd_ti_mmc chain, so C7x firmware load fails with “bad phdr da 0xa3ffec00”. Fix is to overwrite k3-am67a-beagley-ai.dtb.
GPU: installing EdgeAI replaces the kernel but does not rebuild the pvrsrvkm DKMS module, so /dev/dri silently loses card1. No error at all.
e5010 JPEG encoder: pinctrl@f4000 in the shipped DTB claims GIC SPI 98, which collides with e5010 → “genirq: Flags mismatch irq 14 … probe failed: -EBUSY”. Upstream k3-am62a-main.dtsi has no interrupts property there at all.
IMX219 + VPAC ISP working at 1080p30, including two undocumented details: dcc-2a-file is a pad property (sink_0::dcc-2a-file), and format-msb=7 is required for 8-bit Bayer.
cpufreq: there is no CPU OPP table in the DTB, so cpufreq-dt never gets instantiated and the cluster sits at 1.2 GHz. Adding the table also unlocks 1.4 GHz (verified with a throwaway module calling clk_set_rate before touching the DTB, so a bad OPP cannot cost you a boot).
Measured baselines, so you can tell “broken” from “as fast as it gets”: ISP 30.09 fps, + H.264 encode 29.70 fps, but + NV12->BGR on the CPU drops to 9.75 fps. That last one is why the bundled gatekeeper demo does only 7.8 fps with a camera source.
The most useful part is probably the error-signature table: about 18 exact error strings, each with root cause and fix - including the cases where one message has several unrelated causes (tiovxisp’s “Unable to init TIOVX module” is three different failures, you need GST_DEBUG=3 to tell them apart).
Caveats: this is community bring-up on an unsupported combination (TI’s EdgeAI stack on a BeagleBoard board), so none of it is official. Several things I could not fix, and I documented them as unfixed rather than guessing: there is no cpuidle for J722S upstream, tiovxmultiscaler negotiates caps but emits zero frames, and VISS can wedge after a few tiovxisp sessions until you reboot.
Corrections very welcome - especially if anyone knows why tiovxmultiscaler produces no frames. That would get the camera pipeline off the CPU colour conversion.
