Hi All,
I am have recently brought the beaglebone. I have booted with Angstrom image supplied with the board. it works.
- I have downloaded Ubuntu from http://elinux.org/BeagleBoardUbuntu#Precise_12.04_armhf
- done md5sum check, downloaded image is fine. loaded into SD card.
- Inserted the SD card into beaglebone and powered up using USB.
After power up nothing happens, not able to open serial port also. two serial port was shown, but not able to open both ports.
if i load the Angstrom SD card, then angstrom boots properly.
Can you please help me in solving this issue.
Thanks and Regards,
Ashok Kumar P
