Hi
I am working on beaglebone black trying to integrate TP link TL-WN721N Wifi dongle which uses atheros driver.
I am using linux 3.2 kernel with ti-sitara rootfs
The problem is when is type the command
wpa_supplicant -Dwext -i wlan0 -c /etc/wpa_supplicant.conf
it shows Successfully initialised wpa_supplicant
but it gets stuck there and i have to give ctrl+c to exit from that ,after that i gave
ifup wlan0
the response was
Sending discover…
Sending discover…
Sending discover…
No lease, failing
after this I repeated the step for wpa_supplicant this time also it gets stuck and when I gave ifup wlan0
this time it got the correct IP and was able to ping…
This cycles was seemed to repeat when I tried connecting any-other wifi networks (ie: wpa_supplicant gets stuck two times and on the second attempt of ifup wlan0 only i will be able to get IP)
here is my /etc/wpa_supplicat.conf file
network={
ssid=“UTStarcom”
#psk=“123force”
psk=44d83e5c96bd39f47b54625d80b80c79d5b14430d424fdf6636365901b01ab14
and my /etc/network/interfaces
The loopback interface
auto lo
iface lo inet loopback
Wired or wireless interfaces
auto eth0
iface eth0 inet static
address 192.168.2.30
netmask 255.255.255.0
gateway 192.168.2.1
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-driver wext
wpa-conf /etc/wpa_supplicant.conf
Please help me out of this issue
Regards
HPCR
