I got the following issue when I rebuilt console-image from scratch
today. Someone has reported this issue 4 months ago, I just wonder if
it has been resolved.
/usr/src/oe/tmp-zaurus/work/x86_64-linux/bison-native-2.4.3-r9.0/
bison-2.4.3/m4/
glib.m4:8: warning: underquoted definition of AM_PATH_GLIB
configure.ac:128: warning: gl_GLIBC21 is m4_require'd but not
m4_defun'd
bison-2.4.3/m4/
localcharset.m4:7: gl_LOCALCHARSET is expanded from...
bison-2.4.3/m4/
gnulib-comp.m4:153: gl_INIT is expanded from...
configure.ac:128: the top level
autoreconf: configure.ac: tracing
m4_defun'd
aclocal.m4:6788: gl_LOCALCHARSET is expanded from...
aclocal.m4:3203: gl_INIT is expanded from...
configure.ac:128: warning: AC_RUN_IFELSE called without default to
allow cross c
ompiling
../../lib/autoconf/general.m4:2716: AC_RUN_IFELSE is expanded from...
../../lib/m4sugar/m4sh.m4:598: AS_IF is expanded from...
../../lib/autoconf/general.m4:1999: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:2020: AC_CACHE_CHECK is expanded from...
aclocal.m4:8839: gl_POSIX_SPAWN_WORKS is expanded from...
aclocal.m4:8768: gl_POSIX_SPAWN_BODY is expanded from...
aclocal.m4:8763: gl_POSIX_SPAWN is expanded from...
autoreconf: configure.ac: not using Libtool
autoreconf: running: /usr/src/oe/tmp-zaurus/sysroots/x86_64-linux/usr/
bin/autoconf
--include=/usr/src/oe/tmp-zaurus/work/x86_64-linux/bison-native-2.4.3-
r9.0/bison-2.4.3/data/
r9.0/bison-2.4.3/m4/
r9.0/bison-2.4.3/tests/
--include=/usr/src/oe/tmp-zaurus/sysroots/x86_64-linux/usr/share/
aclocal-1.11
aclocal --force --warnings=cross
m4_defun'd
allow cross compiling
aclocal.m4:8763: gl_POSIERROR: Function 'do_configure' failed (see
/usr/src/oe/tmp-zaurus/work/x86_64-linux/bison-native-2.4.3-r9.0/temp/
log.do_configure.8271
for further information)
configure:9788: error: possibly undefined macro: gl_GLIBC21
If this token and others are legitimate, please use
m4_pattern_allow.
See the Autoconf documentation.
autoreconf: /usr/src/oe/tmp-zaurus/sysroots/x86_64-linux/usr/bin/
autoconf failed with exit
status: 1
+ oefatal 'autoreconf execution failed.'
Kai
