I successfully installed OE and bitbake, and even ran bitbake ffmpeg.
But I am not sure how to or what I need to do to install this program
in to my existing Angstrom install.
Is there a wiki describing what to do after a bitbake is complete?
I've wished for something like that too, and I will try to put together a wiki page now that I have found out what to do through asking on this list, the gumstix list, and trial and error. If you have a revision C4 board, you need to use the demo version of u-boot in order to turn power on to the HS usb port.
then you should be able to navigate to ~/{$OE}/angstrom-dev/deploy/glibc/images/beagleboard
where $OE is whatever you named your openembedded directory.
Some people call '~/{$OE}/angstrom-dev' a different name, '~/{$OE}/work', use whatever name you decided on.
Inside the directory, you will find the various images that you can copy to your SD card. (I didn't say you should copy all of them, just the ones you need.)
[mailto:beagleboard@googlegroups.com] On Behalf Of Robert L Cochran
Sent: Thursday, February 04, 2010 7:27 PM
To: beagleboard@googlegroups.com
Subject: Re: [beagleboard] Bitbake tutorial
Ooops, I forgot you need base-image, too. So the bitbake order seems to
»Images generated by building package groups like opie-image or
pivotboot-image are placed in the tmp/deploy/images/ directory.
Individual ipkg packages are put in tmp/deploy/ipk.« [1]
Copy the ffmpeg*.ipk (?) from `tmp/deploy/ipk` (or what your temporary
directory is) to your system and install them using `opkg`. If you do
not want to build it by yourself you can take the package from the feeds
using `opkg install packagename` [2].
I'm interested in just building a very small rootfs to be flashed in
the NAND (no video/X11/multimedia needed). Will bitbake base-image
give me such as small footprint image? Thanks.
