I try to compile x11-image under Angstrom using bitbake.
my system is debian lenny. and I did according to
http://elinux.org/BeagleBoardAndOpenEmbeddedGit
After setup environment and create profile.sh and local.conf
just follow steps
1.git checkout origin/stable/2009 -b stable/2009
2.git pull
3.bitbake x11-image
it compile serveral hours, but error appears.
And I tried serveral time . It take me a long time to rebuild it. But
every time ,the same error appear.
Any one could help with it ?
Regards
alex
error info:
OE:beagleboard yl@bogon:~/oe/openembedded$ bitbake x11-image
NOTE: Handling BitBake files: \ (6972/6972) [100 %]
NOTE: Parsing finished. 6690 cached, 0 parsed, 282 skipped, 2 masked.
NOTE: Cache is clean, not saving.
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version git of u-boot not available (for item u-boot)
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 3580 of 4447 (ID: 1868, /home/yl/oe/openembedded/
recipes/e2fsprogs-libs/e2fsprogs-libs_1.41.5.bb, do_package_write_ipk)
ERROR: Error in executing: /home/yl/oe/openembedded/recipes/e2fsprogs-
ERROR: Exception:<type 'exceptions.OSError'> Message:[Errno 2] No such
file or directory: '/home/yl/oe/tmp/work/armv7a-angstrom-linux-gnueabi/
util-linux-ng-2.15-r6/install/e2fsprogs-libs-dbg'
ERROR: Printing the environment of the function
ERROR: 0048: basedir = os.path.join(os.path.dirname(root))
ERROR: 0049: arch = bb.data.getVar('PACKAGE_ARCH', localdata, 1)
ERROR: 0050: pkgoutdir = "%s/%s" % (outdir, arch)
ERROR: 0051: bb.mkdirhier(pkgoutdir)
ERROR: 0052: os.chdir(root)
ERROR: 0053: from glob import glob
ERROR: 0054: g = glob('*') + glob('.[!.]*')
ERROR: 0055: try:
ERROR: 0056: del g[g.index('CONTROL')]
ERROR: Build of /home/yl/oe/openembedded/recipes/e2fsprogs-libs/
e2fsprogs-libs_1.41.5.bb do_package_write_ipk failed
Traceback (most recent call last):
File "/usr/bin/bitbake", line 143, in <module>
main()
File "/usr/bin/bitbake", line 140, in main
cooker.cook()
File "/var/lib/python-support/python2.5/bb/cooker.py", line 643, in
cook
return self.buildTargets(pkgs_to_build)
File "/var/lib/python-support/python2.5/bb/cooker.py", line 550, in
buildTargets
failures = rq.execute_runqueue()
File "/var/lib/python-support/python2.5/bb/runqueue.py", line 841,
in execute_runqueue
self.execute_runqueue_internal()
File "/var/lib/python-support/python2.5/bb/runqueue.py", line 950,
in execute_runqueue_internal
self.cooker.tryBuild(fn)
File "/var/lib/python-support/python2.5/bb/cooker.py", line 136, in
tryBuild
return self.tryBuildPackage(fn, item, self.configuration.cmd,
the_data)
File "/var/lib/python-support/python2.5/bb/cooker.py", line 110, in
tryBuildPackage
bb.build.exec_task('do_%s' % task, the_data)
File "/var/lib/python-support/python2.5/bb/build.py", line 278, in
exec_task
exec_func(task, localdata)
File "/var/lib/python-support/python2.5/bb/build.py", line 113, in
exec_func
exec_func_python(func, d)
File "/var/lib/python-support/python2.5/bb/build.py", line 136, in
exec_func_python
utils.better_exec(comp, g, tmp, bbfile)
File "/var/lib/python-support/python2.5/bb/utils.py", line 171, in
better_exec
exec code in context
File "do_package_write_ipk", line 11, in <module>
File "do_package_write_ipk", line 9, in do_package_write_ipk
exec_func
exec_func_python
better_exec
File "do_package_ipk", line 174, in <module>
File "do_package_ipk", line 52, in do_package_ipk
OSError: [Errno 2] No such file or directory: '/home/yl/oe/tmp/work/
armv7a-angstrom-linux-gnueabi/util-linux-ng-2.15-r6/install/e2fsprogs-
libs-dbg'
ERROR: Task 1868 (/home/yl/oe/openembedded/recipes/e2fsprogs-libs/
e2fsprogs-libs_1.41.5.bb, do_package_write_ipk) failed
NOTE: Tasks Summary: Attempted 3579 tasks of which 3579 didn't need to
be rerun and 1 failed.
ERROR: '/home/yl/oe/openembedded/recipes/e2fsprogs-libs/e2fsprogs-
libs_1.41.5.bb' failed
