I have extras and can send you one if you’d like.
No Worries, i’ll wait on Seeed…
Ps give this a try… You’ll have to install it first on the one that boots, then move the card over…
git clone -b v4.19.x-ti-overlays https://github.com/beagleboard/BeagleBoard-DeviceTrees
cd ./BeagleBoard-DeviceTrees/
make
sudo make install
That seems to have fixed the bluetooth problem, thanks! Version 1.1 board still won’t power down though. Also see this on the console immediately after I execute systemctl poweroff:
[ 39.619097] Bluetooth: hci0: sending frame failed (-49)
Just a quick update on this, i’ve merged the Device Tree change, so 4.19.94-ti-r73 is now safe for you to upgrade too…
That seems to work for 4.19. I also tried upgrading from 5.10.106-ti-r41 to 5.10.106-ti-r42, but that unfortunately broke bluetooth again on the BBGW v1.1…
hi @ridgelift that’s disappointing, ‘r42’ has the same changes… please run…
sudo beagle-version
Here’s the output of beagle-version just prior to upgrading the kernel with update_kernel.sh. After the kernel upgrade bluetooth no longer works and I have to reflash to go back. Let me know if you need to see the output after the upgrade.
eeprom:[A335BNLTGW1ABBGW20110520]
model:[TI_AM335x_BeagleBone_Green_Wireless]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2020-05-18]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2022.04-g4237220b (Apr 08 2022 - 13:42:29 +0000)]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot.dts]
UBOOT: Loaded Overlay:[BB-BBGW-WL1835-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.kernel]
UBOOT: Loaded Overlay:[uio-pruss-5.4]
kernel:[5.10.106-ti-r41]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay_addr4=/lib/firmware/CT-INPUT-KEYS-00A0.dtbo]
uboot_overlay_options:[uboot_overlay_addr5=/lib/firmware/CT-PWM-P8_34-00A0.dtbo]
uboot_overlay_options:[uboot_overlay_addr6=/lib/firmware/CT-EGPIO-00A0.dtbo]
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[disable_uboot_overlay_adc=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/uio-pruss-5.4.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~bullseye+20210821]
pkg:[bb-customizations]:[1.20220325.0-0~bullseye+20220325]
pkg:[bb-usb-gadgets]:[1.20220316.1-0~bullseye+20220316]
pkg:[bb-wl18xx-firmware]:[1.20211222.2-0~bullseye+20211222]
pkg:[kmod]:[28-1]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
pkg:[firmware-ti-connectivity]:[20210315-3]
groups: ‘debian’: no such user
groups:
cmdline:[console=ttyS0,115200n8 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 3.852102] remoteproc remoteproc0: wkup_m3 is available
[ 29.261015] remoteproc remoteproc0: powering up wkup_m3
[ 29.261055] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 29.261355] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 40.501263] Bluetooth: hci0: change remote baud rate command in firmware
dmesg | grep pru
dmesg | grep pinctrl-single
[ 3.712010] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
lsusb
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
END
This Bluetooth issue was fixed in ‘r42’…
sudo apt update
sudo apt upgrade
Bluetooth is working for me in r41 though and breaks when I update to r42 using update_kernel.sh. Running apt update/upgrade doesn’t upgrade the kernel for me. Should it?
has been replaced by: [ARMHF] Debian 10.x/11.x/12.x Kernel Updates
That’s a key post that I somehow missed, and I’m happy to know about the new method. Still no bueno after upgrading using apt install bbb.io-kernel-5.10-ti-am335x though. The bluetooth light doesn’t come on. Here’s the new output of beagle-version. Don’t know how to get things working again without reflashing back to r41.
UBOOT: Loaded Overlay:[wl1835_bt]
kernel:[5.10.109-ti-r42]
pkg:[kmod]:[28-1]
groups:
dmesg | grep remote
[ 3.852323] remoteproc remoteproc0: wkup_m3 is available
[ 28.960127] remoteproc remoteproc0: powering up wkup_m3
[ 28.960166] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 28.960448] remoteproc remoteproc0: remote processor wkup_m3 is now up
dmesg | grep pru
[ 3.714887] pinctrl-single 44e10800.pinmux: 142 pins, size 568
lsusb
END
I tried copying /boot/dtbs/5.10.106-ti-r41/overlays/BB-BBGW-WL1835-00A0.dtbo to /boot/dtbs/5.10.109-ti-r42/overlays/BB-BBGW-WL1835-00A0.dtbo after doing the upgrade. That makes Bluetooth work again.
ah fun…
So what works on v5.10.x broke v4.19.x and what works on v4.19.x breaks v5.10.x ![]()
edit: so 5.10.109-ti-r43 is now out… with what was r41…
Curious behavior indeed! Did you hear back from Seeed on the BBGW v1.1 changes? I haven’t seen anything new posted on their github or wiki pages.
edit: 5.10.109-ti-r43 works great, thanks!
