Followed the Customize Gateware using Verilog demo and encountered some issues. I called my gateware TEST_CAPE, but otherwise followed the demo. Used the Beagleboard Gitlab build system and it seemed to build correctly.
However, when it booted it reported:
[1.730046] Design Info:
Design Name: MY_CUSTOM_FPGA_DESIGN_7A84992A
Design Version: 02.16.1
[1.740462] Attempting to select eMMC … Failed
later in the boot I got:
[ 3.623722] Waiting for root device /dev/mmcblk0p3…
[ 3.745685] mmc0: error -110 whilst initialising MMC card
[ 4.013311] mmc0: error -110 whilst initialising MMC card
[ 4.296233] mmc0: error -110 whilst initialising MMC card
[ 4.625548] mmc0: error -110 whilst initialising MMC card
at which point it stopped and I figured it was soft bricked.
However, after a couple of restart attempts it did boot.
However, listing the device tree, it showed VERILOG_TEMPLATE as the device tree name rather than TEST_CAPE.
So why are MY_CUSTOM_FPGA_DESIGN and VERILOG_TEMPLATE showing up rather than TEST_CAPE and why is it having issues booting?
Also, the instructions do not say if the dtso file needs a particular name so I’m not sure if that is part of the problem.
The LED did correctly blink, so the code did actually load into the FPGA.
