There is a problem with my HP Computer I download and install the new Bluetooth Software but it gets not Working There is a connection problem. I tried the following things for solution Check Bluetooth driver is active or upgrade and update Bluetooth Driver, Check the visibility, check the device is discoverable, and also the device is in the range etc But the is persists with me. If you have solutions to this? Reply I think this helps you to fix your Bluetooth connection. If you have HP laptop and Computer and facing the proble of HP Accelerometer error with Windows 10 or any other Windows version and other devices click on HP Accelerometer.
