I had this issue as well... however I was trying different linux
kernels.
My board would boot perfectly with the rootfs on mmc with kernel
2.6.28-omap-r25, as came with the openembedded env, however when I
tried 2.6.29 with the omap3_beagle_defconfig, it would hang waiting
for the root device.
Adding a rootdelay did not solve the problem.
I also tried 2.6.30-rc3 but it oopsed early on in boot when trying to
some linking with sysfs.
Well I've tried fsck but it had no effect. I will try a new SD card
tomorrow. I have a feeling my SD reader is playing up a bit so ill go
and get a new one tomorrow and see. It's odd how it was working, then
i rebooted and then poooof, nothing.
I am glad tht worked for you, however I did not have time to go and
buy another card. I found in the kernel logs this
OMAP3: MMC needs CONFIG_REGULATOR{,_TWL4030} now in defconfigs
MMC doesn't work after 3fe326511c66ab842ef0a09a1f4c564b1a8beecf unless
CONFIG_REGULATOR, CONFIG_REGULATOR_TWL4030 are present in the .config.
Add those in for all OMAP3 defconfigs. Tested on BeagleBoard, but
this is
presumably needed for anything with MMC and TWL4030.
2 months agoOMAP: mmc_twl4030 nicely disable vmmc_aux
commit | commitdiff | tree
Adrian Hunter [Tue, 24 Mar 2009 12:15:54 +0000]
The MMC driver turns the power off before it turns it
on. To avoid regulator warnings, vmmc_aux must only be
disabled if it has previously been enabled.
So I did that and it works.
Look in drivers near the bottom of the list from menuconfig and select
Voltage and Current regulators.
And inside that select the TI TWL4030
Recompile and you should be good.
