Board swapping between usb0 and usb1?
Hi all,
Is there a way to turn off one of the USB CDC-ether gadgets? My board
and laptop seem to switch between using usb0 and usb1… just before I was
connected via SSH to 192.168.7.2, with my laptop on .1… all fine.
Set up a default route via 192.168.7.1, and had my laptop routing to the
Internet, `apt-get update` was running, all was well. Then it froze. I
disconnect SSH (using the ~. exit sequence; thank-you UUCP) and try to
re-connect.
SSH wouldn't let me back in… I try 192.168.6.2, and lo and behold, it
works, but I then had to blow away my previous default route and set up
192.168.6.1 as my default route.
The address seems indeterminate, with my laptop (running Gentoo) seeing
both interfaces. It's a race condition as to which will initialise
first. From what I gather; one is meant for that legacy OS from Redmond
and the other is meant for "everyone else".
Is there a preferred interface I should be using?
There are some threads about this already that may have more details. On Linux, the CDC should be preferred over RNDIS.
You can try commenting out the line
 ln \-s functions/rndis\.usb0 configs/c\.1/
and probably also just below comment out
 usb1="enable"
in /opt/scripts/boot/am335x_evm.sh
No problems, I'll give this a shot in a few days when I'm next home.
