In u-boot/board/ti/am57xx/board.c, function, vcores_init() appears to be initializing a pointer to one of 2-3 tables which appear to contain a set of voltage rails for all the cores on a given board.
I witnessed something a little funky last-night and I was wondering if you might have some insight into what’s going on. If you implement a simple if, else statement (e.g. with two possible tables), then SPL boots. However, if you implement an if : else if : else construct, the board doesn’t want to boot. I’m not sure what’s going on here, but I’m wondering if vcores_init has timing constraints? I know that the PMIC shuts everything (or at least the A15 cores) down if you don’t send a message to it on the I2C bus to keep the cores powered on.
I’m wondering if vcores_init is called close to the end of this time window??
If you use a simple if, else statement:
if (board_is_am572x_idk())
*omap_vcores = &am572x_idk_volts;
else
*omap_vcores = &beagle_x15_volts;
SPL loads and vectors to u-boot.
If, however, you code the following construct:
else if (board_is_am571x_idk())
*omap_vcores = &am571x_idk_volts;
else if (board_is_am572x_custom())
else
Then all that pops up on the boot console is 1-2 ASCII characters and then everything APPEARS dead.
I have no idea what’s going on, but I wonder if the additional assembly code generated for the else if, else if could be delaying the “stay powered on” I2C message which gets sent to the PMIC until after the PMIC has already started the core power down ???
Thanks!
Jeff
