I downloaded a new image (bone-debian-8.4-iot-armhf-2016-05-13-4gb) and wrote it to an SD card using Win32DiskImager. I know this is a very old image, I have some software written for that version which is incompatible due to changes to the cape manager related stuff. I don’t have the time to update it yet.
I then inserted it into a Beaglebone Black and powered on holding the S2 button. As expected the board booted onto the SD card. The lights are behaving normally, I can access the “Getting Started” drive. However, I am unable to SSH to or even ping ‘192.168.7.2’. I have been able to communicate via the JTAG serial header.
I have flashed (bone-eMMC-flasher-debian-10.3-iot-armhf-2020-04-06-4gb) onto the same board and had no issues. There is nothing wrong with the Beaglebone, the cables, or any other hardware.
The following is the JTAG output on boot to Debian 8.
U-Boot SPL 2016.03-00001-gd12d09f (Mar 17 2016 - 16:16:15)
Trying to boot from MMC
bad magic
U-Boot 2016.03-00001-gd12d09f (Mar 17 2016 - 16:16:15 -0500), Build: jenkins-github_Bootloader-Builder-351
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
1179 bytes read in 7 ms (164.1 KiB/s)
Importing environment from mmc ...
Checking if uenvcmd is set ...
Running uenvcmd ...
1197 bytes read in 41 ms (28.3 KiB/s)
debug: [/boot/vmlinuz-4.4.9-ti-r25] ...
7833256 bytes read in 469 ms (15.9 MiB/s)
debug: [/boot/initrd.img-4.4.9-ti-r25] ...
4550796 bytes read in 284 ms (15.3 MiB/s)
debug: [/boot/dtbs/4.4.9-ti-r25/am335x-boneblack.dtb] ...
60958 bytes read in 61 ms (975.6 KiB/s)
debug: [console=tty0 console=ttyO0,115200n8 root=/dev/mmcblk0p1 rootfstype=ext4 rootwait coherent_pool=1M quiet cape_universal=enable] ...
debug: [bootz 0x82000000 0x88080000:45708c 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x7786a8 ]
## Flattened Device Tree blob at 88000000
Using Device Tree in place at 88000000, end 88011e1d
Starting kernel ...
[ 1.990552] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.161414] omap_voltage_late_init: Voltage driver support not added
[ 2.168852] PM: Cannot get wkup_m3_ipc handle
[ 2.281318] bone_capemgr bone_capemgr: slot #0: No cape found
[ 2.325284] bone_capemgr bone_capemgr: slot #1: No cape found
[ 2.369303] bone_capemgr bone_capemgr: slot #2: No cape found
[ 2.413279] bone_capemgr bone_capemgr: slot #3: No cape found
Loading, please wait...
fsck: error 2 (No such file or directory) while executing fsck.ext4 for /dev/mmcblk0p1
fsck exited with status code 8
[ 10.080244] systemd-fsck[156]: rootfs: clean, 106009/217728 files, 458745/870144 blocks
[ 16.737033] remoteproc1: failed to load am335x-pru0-fw
[ 16.774666] remoteproc1: request_firmware failed: -2
[ 16.779973] pru-rproc 4a334000.pru0: rproc_boot failed
[ 17.279045] remoteproc1: failed to load am335x-pru1-fw
[ 17.306166] remoteproc1: request_firmware failed: -2
[ 17.311465] pru-rproc 4a338000.pru1: rproc_boot failed
[ 19.643988] platform 48300180.eqep: Cannot lookup hwmod 'eqep0'
[ 19.690678] platform 48302180.eqep: Cannot lookup hwmod 'eqep1'
[ 19.727236] platform 48304180.eqep: Cannot lookup hwmod 'eqep2'
[ 20.349709] eqep 48300180.eqep: failed to get clock
[ 20.476400] eqep 48302180.eqep: failed to get clock
[ 20.573840] eqep 48304180.eqep: failed to get clock
Debian GNU/Linux 8 beaglebone ttyS0
BeagleBoard.org Debian Image 2016-05-13
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
The IP Address for usb0 is: 192.168.7.2
beaglebone login:
