Well… Maybe it’s time to move on to a new kernel, so… I cleared out my oe directory and redid the instructions here [1] to get a fresh kernel. I then did bitbake virtual/kernel and the sources for the 3.2.28 kernel appeared. A bit newer than what I wanted, but it should work. I also did bitbake u-boot. I then
- Reformatted the FAT partition on the SD card.
- Copied MLO for the u-boot sources to the FAT partition.
- Copied u-boot.img and uEnv.txt from the original FAT paritition.
- Copied …/arch/arm/boot/uImage to /boot on the EXT4 partition.
- Copied lib/modules and lib/firmware to /lib on the EXT4.
I booted up the card and nothing appears on /dev/ttyUSB0. (It was working earlier.)
Maybe too many changes at once, so I restored the original MLO (after reformatting) and I get
U-Boot SPL 2011.09-00053-gb423c52 (Aug 10 2012 - 11:26:55)
Texas Instruments Revision detection unimplemented
No daughter card present
No AC power, disabling frequency switch
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
Hmmm… the new u-boot doesn’t seem to be starting.
Let’s go back the the original u-boot (the one from the A6A image). Now I get
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00053-gb423c52 (Aug 10 2012 - 11:26:55)
I2C: ready
DRAM: 256 MiB
WARNING: Caches not enabled
NAND: HW ECC Hamming Code selected
No NAND device found!!!
0 MiB
Net: cpsw
SD/MMC found on device 0
reading uEnv.txt
27 bytes read
Loading file “/boot/uImage” from mmc device 0:2 xxa2
4388792 bytes read
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.2.28/beagleboard
Data Size: 4388728 Bytes = 4.2 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
XIP Kernel Image … OK
OK
Starting kernel …
Well, the original u-boot is working, but the 3.2.28 kernel never gets going. This boot is with quiet removed from uEnv.txt.
Where should I go from here?
–Mark
[1] http://www.angstrom-distribution.org/building-angstrom
