Hello I am experimenting with the pocketbeagle,
and i try to write a normal digitalWrite to a gpio pin with my node script.
i am able to get button input signals and analog read.
Anyway when i try to use:
b.pinMode(pin, b.OUTPUT);
b.digitalWrite(pin, b.LOW);
i get the message:
error: Unable to write to /sys/class/gpio/gpio60/value
the pin seems to be owned by root user, is this the problem?
1 root gpio 0 Dec 13 12:57 gpio60 → …/…/devices/platform/ocp/4804c000.gpio/gpio/gpio60
how can this be solved with a beaglescript from nodejs app?
thank you for any help! i am hitting a wall at the moment.
On Wed, 13 Dec 2017 05:47:29 -0800 (PST),
info@fabianalthaus.de declaimed the following:
1 root gpio 0 Dec 13 12:57 gpio60 -> ../../devices/platform/ocp/
Well... The brute force method is likely to run your script via sudo...
The other method... Might be to modify your user account to be a member
of the GPIO group... (Hopefully the group has full R/W access).
You should be part of the gpio group, double check via:
debian@test-bbb-1:~$ cat /etc/group | grep gpio
gpio:x:995:debian
