Hi all,
I am writing a node.js app using bonescript and am using a systemctl service to start it on boot. I have written the service, which correctly fires the startup script but it errors out when trying to load bonescript. I can run the app from the command line just fine (node app.js) and it works, but when called from the service, it gives the following error:
Sep 25 09:42:43 brewbone brewbone[581]: at Function.Module._load (module.js:280:25)
Sep 25 09:42:43 brewbone brewbone[581]: at Module.require (module.js:362:17)
Sep 25 09:42:43 brewbone brewbone[581]: at require (module.js:378:17)
Sep 25 09:42:43 brewbone brewbone[581]: at Object. (/var/lib/cloud9/brewbone/lib/output.js:1:71)
Sep 25 09:42:43 brewbone brewbone[581]: at Module._compile (module.js:449:26)
Sep 25 09:42:43 brewbone brewbone[581]: at Object.Module._extensions…js (module.js:467:10)
Sep 25 09:42:43 brewbone brewbone[581]: at Module.load (module.js:356:32)
Sep 25 09:42:43 brewbone brewbone[581]: at Function.Module._load (module.js:312:12)
Sep 25 09:42:43 brewbone brewbone[581]: [96B blob data]
My startup script is /user/bin/brewbone:
#!/bin/bash
nodemon /var/lib/cloud9/brewbone/app.js
The service is /lib/systemd/system/brewbone.service
[Unit]
Description=Brewbone Application
After=syslog.target
[Service]
ExecStart=/usr/bin/brewbone
[Install]
WantedBy=multi-user.target
The suspect line (output.js:1:71) is:
var b = require(“bonescript”);
Any ideas what could be causing the error?
Josh
