xz -cd ubuntu-precise-12.04.2-armhf-3.8.13-bone20.img.xz > /dev/sdb
It looks to install on the SD card okay, with fdisk showing:
sdb 8:16 1 29.7G 0 disk
├─sdb1 8:17 1 1M 0 part /media/boot
└─sdb2 8:18 1 1.8G 0 part /media/rootfs
But when I put it in the BeagleBone Black, hold down the USER/BOOT button and power on the BBB (with a 5V DC power supply and while still holding the button), the 4 LEDs will flash constantly, but that seems to be it. If I plug the BeagleBone to my computer with USB, nothing happens and I cannot SSH into the device.
I was however able to get Ubuntu 12.10 on the SD card and boot and SSH successfully using the demo images described on eLinux. Unfortunately, I need 12.04 because a third-party repository I’m requiring only builds ARM debs for 12.04 Precise.
In short, my question is how do I install 12.04 onto a MicroSD card so that my BeagleBone Black can boot from it? If it’s just the steps mentioned above, is there something else I can try or check?
I only 'build' two ubuntu releases, otherwise it's just too much to
upload once a month..
If you 'really' need 12.04, use my netinstall... Note for the
"initial" netboot install you will need to use a secondary usb-network
adapter as, due to issues with the onboard and the limited ip tools
used by the debian-installer. Once you reboot after installing 12.04
you can remove the usb-network adapter and use the onboard just fine..
wget [http://rcn-ee.net/deb/rootfs/raring/ubuntu-13.04-console-armhf-2013-06-14.tar.xz](http://rcn-ee.net/deb/rootfs/raring/ubuntu-13.04-console-armhf-2013-06-14.tar.xz)
mirrors (will take some time to update):
wget [http://ynezz.ibawizard.net/beagleboard/raring/ubuntu-13.04-console-armhf-2013-06-14.tar.xz](http://ynezz.ibawizard.net/beagleboard/raring/ubuntu-13.04-console-armhf-2013-06-14.tar.xz)
tar xJf ubuntu-13.04-console-armhf-2013-06-14.tar.xz
cd ubuntu-13.04-console-armhf-2013-06-14
If you don’t know the location of your SD card:
sudo ./setup_sdcard.sh --probe-mmc
You should see something like
Are you sure? I don't see [/dev/idontknow], here is what I do see...
fdisk -l:
Disk /dev/sda: 500.1 GB, 500107862016 bytes **<- x86 Root Drive**
Disk /dev/sdd: 3957 MB, 3957325824 bytes **<- MMC/SD card**
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 465.8G 0 disk
├─sda1 8:1 0 446.9G 0 part / **<- x86 Root Partition**
├─sda2 8:2 0 1K 0 part
└─sda5 8:5 0 18.9G 0 part [SWAP]
sdd 8:48 1 3.7G 0 disk
├─sdd1 8:49 1 64M 0 part
└─sdd2 8:50 1 3.6G 0 part
In this example, we can see via mount, /dev/sda1 is the x86 rootfs, therefore /dev/sdd is the other drive in the system, which is the MMC/SD card that was inserted and should be used by ./setup_sdcard.sh…
Appears as though the Beaglebone Black is working with Ubuntu 12.04 off the microSD card. Just need a confirmation that 2 lights flashing indicates that the Beaglebone is working fine.
What is the IP address used by default for Ubuntu 12.04 (the build from the Armhf website)?
