I’m trying to flash an Android image onto my Beaglebone Black following the steps at http://learn.adafruit.com/beaglebone-black-installing-operating-systems/mac-os-x
Initially I couldn’t get it to boot from the 8gb SD card (and I tried a couple of different ones), however I eventually found this post (https://groups.google.com/forum/#!category-topic/beagleboard/android/kx43JkGPDkA) which matched my symptoms and I could at least get the user leds to light up when holding down the BOOT button.
However, the user leds continued to flash busily for hours, rather than the 45-60 minutes I’d seen described. I left it overnight with no difference.
I gave up and found a USB-Serial converter to watch what was happening during the boot process (see below).
What should I be looking for to know if it is even attempting to flash from the sd card and why it’s falling over?
Cheers
Malcolm
Script started on Wed Jan 15 11:43:25 2014
e[?1034hbash-3.2$ ls /dev/tty.e[Kcd /devls /dev/tty.
e[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Csudo fdisk -d /dev/disk2s1 e[2P/dev/disk2s1 dpe[K
e[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[11@diskutil unmounte[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[C
e[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[11Pfdiske[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[C
e[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Cdf -he[Ksudo fdisk /dev/disk2s1
e[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[11Pfdiske[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[C pd-d /dev/disk2s1
e[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[14Pls /dev/tty.*
e[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[6Pcd /devlse[K /dev/tty.*
e[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Ce[Kaascreen /dev/ttya.usbmodemfa131 115200
e[?1049he[!pe[?3;4le[4le>e[4le[?1he=e[0me(Be[1;40re[He[2Je[He[2J[ 4
U-Boot SPL 2013.04 (Jun 20 2013 - 22:42:21)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.04 (Jun 20 2013 - 22:42:21)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
Hit any key to stop autoboot: 1 0
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
534 bytes read in 17 ms (30.3 KiB/s)
Running uenvcmd …
reading zImage
3320040 bytes read in 401 ms (7.9 MiB/s)
reading am335x-boneblack.dtb
24129 bytes read in 9 ms (2.6 MiB/s)
Flattened Device Tree blob at 815f0000
Booting using the fdt blob at 0x815f0000
Using Device Tree in place at 815f0000, end 815f8e40
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone22 (notroot@ubuntu) (gcc version 4.7.3 20130328 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.04-20130415 - Linaro GCC 2013.04) ) #1 SMP Thu Jun 20 22:32:44 UTC 2013
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0e2c000 s14080 r8192 d14592 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: consoleblank=0 console=ttyO0,115200n8 androidboot.console=ttyO0 mem=512M root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait init=/init ip=off video=720x480-16@60 qemu=1 vt.global_cursor_default=0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 507256k/507256k available, 17032k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08d6580 (9018 kB)
[ 0.000000] .init : 0xc08d7000 - 0xc0920700 ( 294 kB)
[ 0.000000] .data : 0xc0922000 - 0xc09a4e00 ( 524 kB)
[ 0.000000] .bss : 0xc09a4e00 - 0xc0a1c180 ( 477 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000381] Calibrating delay loop… 363.67 BogoMIPS (lpj=354304)
[ 0.017385] pid_max: default: 32768 minimum: 301
[ 0.017634] Security Framework initialized
[ 0.017732] Mount-cache hash table entries: 512
[ 0.027610] Initializing cgroup subsys cpuacct
[ 0.027649] Initializing cgroup subsys memory
[ 0.027720] Initializing cgroup subsys blkio
[ 0.027876] CPU: Testing write buffer coherency: ok
[ 0.028476] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.028555] Setting up static identity map for 0x806166f0 - 0x80616748
[ 0.030245] Brought up 1 CPUs
[ 0.030269] SMP: Total of 1 processors activated (363.67 BogoMIPS).
[ 0.031684] devtmpfs: initialized
[ 0.097402] pinctrl core: initialized pinctrl subsystem
[ 0.097705] rstctl core: initialized rstctl subsystem
[ 0.098219] regulator-dummy: no parameters
[ 0.098764] NET: Registered protocol family 16
[ 0.099926] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.110094] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.110861] platform 49000000.edma: alias fck already exists
[ 0.110893] platform 49000000.edma: alias fck already exists
[ 0.110918] platform 49000000.edma: alias fck already exists
[ 0.112292] OMAP GPIO hardware version 0.1
[ 0.116935] gpio-rctrl rstctl.3: loaded OK
[ 0.122317] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.124472] cpsw.0: No hwaddr in dt. Using 90:59:af:4e:a8:53 from efuse
[ 0.124506] cpsw.1: No hwaddr in dt. Using 90:59:af:4e:a8:55 from efuse
[ 0.139217] bio: create slab at 0
[ 0.150911] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.151368] vmmcsd_fixed: 3300 mV
[ 0.154279] SCSI subsystem initialized
[ 0.154709] usbcore: registered new interface driver usbfs
[ 0.154822] usbcore: registered new interface driver hub
[ 0.155141] usbcore: registered new device driver usb
[ 0.157283] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.158914] input: tps65217_pwr_but as /devices/ocp.2/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.161241] DCDC1: at 1500 mV
[ 0.162496] vdd_mpu: 925 <–> 1325 mV at 1100 mV
[ 0.163622] vdd_core: 925 <–> 1150 mV at 1100 mV
[ 0.164830] LDO1: at 1800 mV
[ 0.165988] LDO2: at 3300 mV
[ 0.167968] LDO3: 1800 mV
[ 0.169106] LDO4: at 3300 mV
[ 0.170156] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.170939] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.171828] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.174408] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.174634] media: Linux media interface: v0.10
[ 0.174754] Linux video capture interface: v2.00
[ 0.175425] Advanced Linux Sound Architecture Driver Initialized.
[ 0.176616] NetLabel: Initializing
[ 0.176636] NetLabel: domain hash size = 128
[ 0.176648] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.176764] NetLabel: unlabeled traffic allowed by default
[ 0.177296] Switching to clocksource gp_timer
[ 0.233763] NET: Registered protocol family 2
[ 0.234973] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.235120] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.235281] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.235384] TCP: reno registered
[ 0.235412] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.235457] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.235882] NET: Registered protocol family 1
[ 0.236607] RPC: Registered named UNIX socket transport module.
[ 0.236630] RPC: Registered udp transport module.
[ 0.236643] RPC: Registered tcp transport module.
[ 0.236656] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.238109] CPU PMU: probing PMU on CPU 0
[ 0.238143] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.238648] omap2_mbox_probe: platform not supported
[ 0.511967] VFS: Disk quotas dquot_6.5.2
[ 0.512256] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.513590] NFS: Registering the id_resolver key type
[ 0.513703] Key type id_resolver registered
[ 0.513720] Key type id_legacy registered
[ 0.513792] fuse init (API version 7.20)
[ 0.514712] Btrfs loaded
[ 0.514892] msgmni has been set to 990
[ 0.517987] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.518015] io scheduler noop registered
[ 0.518031] io scheduler deadline registered
[ 0.518072] io scheduler cfq registered (default)
[ 0.520205] tps65217-bl tps65217-bl: no platform data provided
[ 0.520251] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.521105] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.523871] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.524213] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 1.249283] console [ttyO0] enabled
[ 1.254115] [drm] Initialized drm 1.1.0 20060810
[ 1.272537] brd: module loaded
[ 1.282792] loop: module loaded
[ 1.286268] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.293564] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.300840] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.308112] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.315391] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.329658] bone-capemgr bone_capemgr.8: Baseboard: ‘A335BNLT,0A5C,2513BBBK4894’
[ 1.337441] bone-capemgr bone_capemgr.8: compatible-baseboard=ti,beaglebone-black
[ 1.376641] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 1.413746] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 1.450854] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 1.487964] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 1.494214] bone-capemgr bone_capemgr.8: slot #4: specific override
[ 1.500811] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 4
[ 1.508846] bone-capemgr bone_capemgr.8: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[ 1.518983] bone-capemgr bone_capemgr.8: slot #5: specific override
[ 1.525574] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 5
[ 1.533602] bone-capemgr bone_capemgr.8: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[ 1.543651] bone-capemgr bone_capemgr.8: slot #6: specific override
[ 1.550247] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 6
[ 1.558279] bone-capemgr bone_capemgr.8: slot #6: ‘Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN’
[ 1.568904] bone-capemgr bone_capemgr.8: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.577790] bone-capemgr bone_capemgr.8: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.586671] bone-capemgr bone_capemgr.8: loader: before slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.595435] bone-capemgr bone_capemgr.8: loader: check slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.604137] bone-capemgr bone_capemgr.8: initialized OK.
[ 1.609739] bone-capemgr bone_capemgr.8: loader: before slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.618585] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.629372] OneNAND driver initializing
[ 1.634951] usbcore: registered new interface driver cdc_ether
[ 1.641137] bone-capemgr bone_capemgr.8: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.649911] bone-capemgr bone_capemgr.8: loader: after slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.658680] usbcore: registered new interface driver rndis_host
[ 1.664978] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.673858] usbcore: registered new interface driver cdc_ncm
[ 1.679835] bone-capemgr bone_capemgr.8: slot #4: Requesting firmware ‘cape-bone-2g-emmc1.dtbo’ for board-name ‘Bone-LT-eMMC-2G’, version ‘00A0’
[ 1.694233] usbcore: registered new interface driver cdc_acm
[ 1.700206] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.708588] Initializing USB Mass Storage driver…
[ 1.713741] bone-capemgr bone_capemgr.8: slot #4: dtbo ‘cape-bone-2g-emmc1.dtbo’ loaded; converting to live tree
[ 1.724467] bone-capemgr bone_capemgr.8: slot #5: Requesting firmware ‘cape-boneblack-hdmi-00A0.dtbo’ for board-name ‘Bone-Black-HDMI’, version ‘00A0’
[ 1.738855] bone-capemgr bone_capemgr.8: slot #4: #2 overlays
[ 1.745041] usbcore: registered new interface driver usb-storage
[ 1.751354] USB Mass Storage support registered.
[ 1.757113] bone-capemgr bone_capemgr.8: slot #4: Applied #2 overlays.
[ 1.764022] bone-capemgr bone_capemgr.8: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.772729] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.781514] bone-capemgr bone_capemgr.8: slot #5: dtbo ‘cape-boneblack-hdmi-00A0.dtbo’ loaded; converting to live tree
[ 1.792954] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.799717] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.804975] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.814800] bone-capemgr bone_capemgr.8: slot #5: #4 overlays
[ 1.823314] platform 4830e000.fb: alias fck already exists
[ 1.829449] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.834547] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.841673] bone-capemgr bone_capemgr.8: slot #5: Applied #4 overlays.
[ 1.848560] bone-capemgr bone_capemgr.8: loader: done slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.857158] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.866702] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.871972] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.880753] bone-capemgr bone_capemgr.8: loader: after slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.889651] bone-capemgr bone_capemgr.8: slot #6: Requesting firmware ‘cape-boneblack-hdmin-00A0.dtbo’ for board-name ‘Bone-Black-HDMIN’, version ‘00A0’
[ 1.904240] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.909305] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.914618] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.921083] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.929595] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.936753] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.944328] usb usb1: Product: MUSB HDRC host driver
[ 1.949544] usb usb1: Manufacturer: Linux 3.8.13-bone22 musb-hcd
[ 1.955843] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.961143] bone-capemgr bone_capemgr.8: slot #6: dtbo ‘cape-boneblack-hdmin-00A0.dtbo’ loaded; converting to live tree
[ 1.973580] hub 1-0:1.0: USB hub found
[ 1.977879] bone-capemgr bone_capemgr.8: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 1.987472] bone-capemgr bone_capemgr.8: slot #6: Failed verification
[ 1.994239] bone-capemgr bone_capemgr.8: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 2.004117] hub 1-0:1.0: 1 port detected
[ 2.009801] mousedev: PS/2 mouse device common for all mice
[ 2.018240] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 2.026075] i2c /dev entries driver
[ 2.031525] Driver for 1-wire Dallas network protocol.
[ 2.038813] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.046919] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-devel@redhat.com
[ 2.055863] cpuidle: using governor ladder
[ 2.060233] cpuidle: using governor menu
[ 2.064867] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 2.072097] omap_hsmmc mmc.4: Failed to get rstctl; not using any
[ 2.078527] omap_hsmmc mmc.4: unable to select pin group
[ 2.084390] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 2.091602] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 2.098971] mmc.4 supply vmmc_aux not found, using dummy regulator
[ 2.105611] omap_hsmmc mmc.4: pins are not configured from the driver
[ 2.140658] gpio-rctrl rstctl.3: gpio_rctrl_request eMMC_RSTn
[ 2.146896] omap_hsmmc mmc.10: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 2.154892] gpio-rctrl rstctl.3: gpio_rctrl_deassert eMMC_RSTn
[ 2.161386] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 2.168555] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 2.176112] mmc.10 supply vmmc_aux not found, using dummy regulator
[ 2.182874] omap_hsmmc mmc.10: pins are not configured from the driver
[ 2.217027] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 2.228732] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 2.236036] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 2.245018] leds-gpio gpio-leds.7: pins are not configured from the driver
[ 2.253386] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.260293] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 2.268020] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 2.276418] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 2.282830] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 2.290086] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 2.298407] usbcore: registered new interface driver usbhid
[ 2.304362] usbhid: USB HID core driver
[ 2.309570] ashmem: initialized
[ 2.313452] logger: created 256K log ‘log_main’
[ 2.318791] logger: created 256K log ‘log_events’
[ 2.324282] logger: created 256K log ‘log_radio’
[ 2.329234] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.338083] logger: created 256K log ‘log_system’
[ 2.347600] davinci_evm sound.13: nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[ 2.355355] mmc0: new high speed SDHC card at address e624
[ 2.361919] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ 2.370468] TCP: cubic registered
[ 2.375647] NET: Registered protocol family 10
[ 2.380614] mmcblk0: p1 p2 p3
[ 2.385361] NET: Registered protocol family 17
[ 2.392483] Key type dns_resolver registered
[ 2.397562] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.405737] ThumbEE CPU extension supported.
[ 2.410293] Registering SWP/SWPB emulation handler
[ 2.416524] registered taskstats version 1
[ 2.421713] slave hdmi.12: modes-blacklisted #0 → 1920x1080@25
[ 2.428121] slave hdmi.12: modes-blacklisted #1 → 832x624@75
[ 2.436482] tilcdc 4830e000.fb: No power control GPIO
[ 2.480212] usb 1-1: new low-speed USB device number 2 using musb-hdrc
[ 2.551642] tilcdc 4830e000.fb: found TDA19988
[ 2.557196] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.564148] [drm] No driver support for vblank timestamp query.
[ 2.595833] tilcdc 4830e000.fb: mode 832x624@75 is blacklisted
[ 2.609790] usb 1-1: New USB device found, idVendor=045e, idProduct=0040
[ 2.609803] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 2.609814] usb 1-1: Product: Microsoft 3-Button Mouse with IntelliEye™
[ 2.609824] usb 1-1: Manufacturer: Microsoft
[ 2.614813] input: Microsoft Microsoft 3-Button Mouse with IntelliEye™ as /devices/ocp.2/47400000.usb/musb-hdrc.1.auto/usb1/1-1/1-1:1.0/input/input1
[ 2.615861] hid-generic 0003:045E:0040.0001: input: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye™] on usb-musb-hdrc.1.auto-1/input0
[ 2.657622] Console: switching to colour frame buffer device 90x30
[ 2.723691] tilcdc 4830e000.fb: fb0: frame buffer device
[ 2.729361] tilcdc 4830e000.fb: registered panic notifier
[ 2.735087] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 2.790715] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.797150] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.804966] libphy: 4a101000.mdio: probed
[ 2.809255] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.819134] Detected MACID = 90:59:af:4e:a8:53
[ 2.823950] cpsw 4a100000.ethernet: NAPI disabled
[ 2.831328] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.841841] mmc1: BKOPS_EN bit is not set
[ 2.848811] mmc1: new high speed MMC card at address 0001
[ 2.855054] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[ 2.860080] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 2.866525] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 2.875092] mmcblk1: p1 p2
[ 2.880117] mmcblk1boot1: unknown partition table
[ 2.886756] mmcblk1boot0: unknown partition table
[ 2.898099] tilcdc 4830e000.fb: timeout waiting for framedone
[ 2.916124] ALSA device list:
[ 2.919296] #0: TI BeagleBone Black
[ 3.302337] EXT4-fs (mmcblk0p2): recovery complete
[ 3.310025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.318584] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.326700] devtmpfs: mounted
[ 3.330249] Freeing init memory: 292K
[ 3.379276] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 3.503134] init: cannot open ‘/initlogo.rle’
[ 4.007958] EXT4-fs (mmcblk0p3): recovery complete
[ 4.015909] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[ 4.057902] init: cannot find ‘/system/bin/sgx/rc.pvr’, disabling ‘pvr’
[ 4.119336] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
root@android:/ # [ 23.174374] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
[ 32.755945] net eth0: initializing cpsw version 1.12 (0)
[ 32.764046] net eth0: phy found : id is : 0x7c0f1
[ 32.769029] libphy: PHY 4a101000.mdio:01 not found
[ 32.774063] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 32.791745] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 41.614522] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
