Boot logo
I want to use my own boot logo. I found some advices in psplash folder
in the OE/packages dir but I did not get an idea how to get it.
Is there any step by step advice for making a own boot logo and
replace the Angstrom one?
Robert
1. I replaced $OE/openembedded/packages/psplash/files/psplash-hand-img.h
which one I generated with make-image.sh.
2. opkg install psplash-support_0.0\+svnr249-r16.1_armv7a.ipk
-force-reinstall -force-overwrite
3. opkg install psplash_0.0\+svnr249-r16.1_armv7a.ipk
...but the logo remains the same - no change.
What do I miss?
Robert
I am trying the same thing, trying to have a custom startup screen.
Did you or anyone have any success?
-Deven
Please stop top posting.
My notes:
1. create png logo (exchange blue and red channel if 24bit)
2. execute "./make-image-header.sh logo_450x185_bgr.png HAND"
(make-image-header is part of psplash)
3. cp logo_450x185_bgr-img.h $OE/.../files/psplash-hand-img.h
4. bitbake -c rebuild -b psplash-angstrom_svn.bb
5 reinstall all psplash-ipk's
for example.
HTH
Robert
My apologies. I do not understand what you mean to say.
Thanks for the answer. I will try your suggestion.
-Deven
A better idea is to create your own psplash-robert.bb that install a new splash using u-a.
regards,
Koen
Deven T said the following on 04/23/2009 03:53 AM:
http://www.arm.linux.org.uk/mailinglists/etiquette.php#e3
Nishanth Menon
Thanks for the link. I am used to posting on forums and now I will get used to posting in a mailing list :).
-Deven
Deven T said the following on 04/23/2009 06:36 AM:
    > > Please stop top posting.
    > My apologies. I do not understand what you mean to say.
yep, takes a little getting used to. by the way, a good idea is to
switch to text only emails.. saves quite a few bytes for thousand+
people downloading the same email..
Nishanth Menon
Another solution is to re-compile psplash directly on the beagleboard
whit the good header.
1.create png logo (exchange blue and red channel if 24bit)
2. download http://labs.o-hand.com/sources/psplash/psplash-0.1.tar.gz
, the tarball containing psplash and the script make-image-header.sh
-> wget http://labs.o-hand.com/sources/psplash/psplash-0.1.tar.gz
3. extract the tarball
-> tar xvf psplash-0.1.tar.gz
3. execute "psplash-0.1/make-image-header.sh logo_450x185_bgr.png
HAND"
   3.1 if gdk-pixbuf-csource is missing, "opkg install gtk+-dev"
should fix that.
4. copy the header within the logo in the source folder
-> cp logo_450x185_bgr-img.h psplash-0.1/psplash-hand-img.h
5. go into the source folder
-> cd psplash-0.1
6. Prepare the installation
-> ./configure
7. compile and install
-> make && make install
8. redirect the symoblic link to our new psplash
-> ln -sf /usr/local/bin/psplash /usr/bin/psplash
Another solution is to re-compile psplash directly on teh beagleboard
HAND"
should fix that.
-> cd psplash-0.1
-> ./configure
Thank you for the tips, but the link to the sources is not working. I will try to do it by bitbake psplash.
Fernando
Did you succeed?
I try on beaglebone black. But I can’t do it.
Were you ever able to get psplash going on the BBB??
Trying to do this as well.
Sheldon.
