I can’t get the BBB to boot from eMMC or SD. The following is what I get on the serial terminal at start:
U-Boot SPL 2018.03-00002-gac9cce7c6a (Apr 05 2018 - 13:07:46 -0500)
Trying to boot from MMC1
Loading Environment from EXT4… ** File not found /boot/uboot.env **
** Unable to read “/boot/uboot.env” from mmc0:1 **
Failed (-5)
mmc_load_image_raw_sector: mmc block read error
Loading Environment from EXT4… ** Can’t read partition table on 0:0 **
** Invalid partition 1 **
Failed (-5)
** Partition 1 not valid on device 0 **
spl_register_fat_device: fat register err - -1
spl_load_image_fat: error reading image u-boot.img, err - -1
Failed (-5)
bad MBR sector signature 0x2f40
spl: no partition table found
SPL: failed to boot from all boot devices
ERROR ### Please RESET the board
I am trying to use this image flashed to SD ‘bone-debian-9.4-iot-armhf-2018-06-17-4gb.img’
I get it to boot off a card using this image ‘beaglelogic-stretch-2017-07-13-4gb.img’. Did something change on the latest image that is not compatible with my beaglebone?
Travis
