I’m trying to boot a beaglebone linux 3.2 SD card on a beaglebone black and I get the following error after the kernel loads:
[ 1.842913] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.852180] Waiting for root device /dev/mmcblk0p2…
[ 1.896105] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 1.906422] mmc0: new high speed SDHC card at address b368
[ 1.912515] mmcblk0: mmc0:b368 USD 7.45 GiB
[ 1.918442] mmcblk0: p1 p2
[ 1.966129] EXT3-fs (mmcblk0p2): error: couldn’t mount because of unsupported optional features (240)
[ 1.975844] List of all partitions:
[ 1.979498] b300 7822336 mmcblk0 driver: mmcblk
[ 1.985058] b301 102400 mmcblk0p1 00000000-0000-0000-0000-000000000mmcblk0p1
[ 1.993445] b302 1835008 mmcblk0p2 00000000-0000-0000-0000-000000000mmcblk0p2
[ 2.001821] No filesystem could mount root, tried: ext3
[ 2.007393] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
Any ideas on how to resolve this?
Sounds like your 3.2 SD card is not compatible with the BeagleBone Black. Did you disable the eMMC or are you holding the boot button down?
Gerald,
I held down the boot button.
Do you know what all I need to do to get my 3.2 build to work on the black?
For the 3.2 to work, just use the image we point everyone to that already works.
http://circuitco.com/support/index.php?title=BeagleBoneBlack#TI_EZSDK
Gerald,
You should really look at the error message again...
[ 1.966129] EXT3-fs (mmcblk0p2): error: couldn't mount because of
"hint".
aka... Just maybe your "partition" is not ext3 and "possibly" ext4?
