Booting BBB with latest Debian image
When i boot my BBB Rev C i have face this problem please help me with this.
I2C:   ready
DRAM:  512 MiB
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net:   <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Hit any key to stop autoboot:  0
mmc0 is current device
SD/MMC found on device 0
** File not found uEnv.txt **
Checking if uenvcmd is set ...
uenvcmd was not defined in uEnv.txt ...
SD/MMC found on device 1
reading uEnv.txt
1430 bytes read in 5 ms (279.3 KiB/s)
Importing environment from mmc ...
Running uenvcmd ...
reading zImage
3717760 bytes read in 205 ms (17.3 MiB/s)
reading initrd.img
2870013 bytes read in 161 ms (17 MiB/s)
reading /dtbs/am335x-boneblack.dtb
25080 bytes read in 9 ms (2.7 MiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x38ba80 ]
## Flattened Device Tree blob at 88000000
   Using Device Tree in place at 88000000, end 880091f7
Starting kernel ...
Uncompressing Linux... done
Vishal Chopra
