I’m trying to boot from a USB flash drive. I essentially copy the u-boot commands for booting from the SD card. I’m running into a problem once the kernel has loaded:
Begin: Mounting root file system … Begin: Running /scripts/local-top … done.
Begin: Waiting for root file system … done.
Gave up waiting for root device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Check root= (did the system wait for the right device?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/sda1 does not exist. Dropping to a shell!
modprobe: module i8042 not found in modules.dep
modprobe: module ehci-hcd not found in modules.dep
modprobe: module uhci-hcd not found in modules.dep
modprobe: module ohci-hcd not found in modules.dep
I plugged in /dev/sda1 as a place holder, but I can’t find any indication that the initramfs was able to detect a USB flash drive. For some reason it complains about ehci-hcd and ohci-hcd modules not being found. The stock kernel is able to mount flash drives without any issues using the builtin usb-storage and musb-hdrc modules.
[ 1.617727] Initializing USB Mass Storage driver... [ 1.625471] usbcore: registered new interface driver usb-storage [ 1.634288] USB Mass Storage support registered. [ 1.641729] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
I’d really appreciate any advice on how to detect and mount the flash drive. Do I need to make a modification to initrd? Or do I need to rebuild the kernel with the ehci-hcd / ohci-hcd modules? Why isn’t it detecting the eMMC?
