booting with no x11 environment
i build angstrom image via narcisus with x11 environment..
it is booting, there is no x11 on screen, a console application with
black screen.
how i can boot it with graphical interfaces?
can you help me , are there any error in logs?
thanks..
Here is output:
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.11 (Feb 23 2010 - 15:33:48)
OMAP3530-GP ES3.1, CPU-OPP2 L3-165MHz
I2C: ready
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision C4
Die ID #7cea000400000000040365fa1500d022
mmc0 is available
reading boot.scr
** Unable to read "boot.scr" from mmc 0:1 **
reading uImage
3194732 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 82000000 ...
   Image Name: Angstrom/2.6.32/beagleboard
   Data Size: 3194668 Bytes = 3 MB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.............................................................
done, bootin
g the kernel.
[ 0.000000] Linux version 2.6.32 (koen@dominion) (gcc version 4.3.3
(GCC) ) #
3 PREEMPT Wed Dec 15 13:19:23 CET 2010
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction ca
che
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp 720m )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pag
es: 65024
[ 0.000000] Kernel command line: console=ttyS2,115200n8 vram=12M
omapdss.def_
disp=dvi omapfb.mode=dvi:1024x768MR-24@60 root=/dev/mmcblk0p2 init=/
init rw root
wait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5,
131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB total
[ 0.000000] Memory: 240384KB available (5896K code, 671K data, 204K
init, 0K
highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/720 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupt
s
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 677.46 BogoMIPS (lpj=2646016)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option 'mode'
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 15.398925] OMAP DMA hardware revision 4.0
[ 15.405273] bio: create slab <bio-0> at 0
[ 15.406463] SCSI subsystem initialized
[ 15.407745] usbcore: registered new interface driver usbfs
[ 15.407867] usbcore: registered new interface driver hub
[ 15.408050] usbcore: registered new device driver usb
[ 15.416931] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 15.419525] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 15.419555] twl4030: power (irq 373) chaining IRQs 376..383
[ 15.419860] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 15.421234] regulator: VUSB1V5: 1500 mV normal standby
[ 15.421447] regulator: VUSB1V8: 1800 mV normal standby
[ 15.421661] regulator: VUSB3V1: 3100 mV normal standby
[ 15.425262] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 15.425659] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 15.425903] regulator: VDAC: 1800 mV normal standby
[ 15.426116] regulator: VPLL2: 1800 mV normal standby
[ 15.426330] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 15.426635] regulator: VAUX3: 1800 mV normal standby
[ 15.426971] regulator: VAUX4: 1800 mV normal standby
[ 15.438995] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 15.453643] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 15.454803] Switching to clocksource 32k_counter
[ 15.463806] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 15.464080] musb_hdrc: USB OTG mode controller at fa0ab000 using
DMA, IRQ 92
[ 15.464080] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 15.464202] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number
1
[ 15.464324] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 15.464355] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=
1
[ 15.464355] usb usb1: Product: MUSB HDRC host driver
[ 15.464355] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 15.464385] usb usb1: SerialNumber: musb_hdrc
[ 15.464965] hub 1-0:1.0: USB hub found
[ 15.464996] hub 1-0:1.0: 1 port detected
[ 15.466033] NET: Registered protocol family 2
[ 15.466217] IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 15.466735] TCP established hash table entries: 8192 (order: 4,
65536 bytes)
[ 15.466918] TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
[ 15.467010] TCP: Hash tables configured (established 8192 bind
8192)
[ 15.467010] TCP reno registered
[ 15.467041] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 15.467071] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 15.467285] NET: Registered protocol family 1
[ 15.467681] RPC: Registered udp transport module.
[ 15.467712] RPC: Registered tcp transport module.
[ 15.467712] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 15.468597] omap-iommu omap-iommu.0: isp registered
[ 15.470245] VFS: Disk quotas dquot_6.5.2
[ 15.470336] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 15.471374] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 15.472137] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red
Hat, Inc.
[ 15.472869] msgmni has been set to 470
[ 15.476837] alg: No test for stdrng (krng)
[ 15.477111] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 2
54)
[ 15.477111] io scheduler noop registered
[ 15.477142] io scheduler deadline registered
[ 15.477264] io scheduler cfq registered (default)
[ 15.533233] OMAP DSS rev 2.0
[ 15.533294] OMAP DISPC rev 3.0
[ 15.533325] OMAP VENC rev 2
[ 15.533569] OMAP DSI rev 1.0
[ 15.870391] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 15.890380] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 15.909729] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 15.929016] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 16.468170] console [ttyS2] enabled
[ 16.477905] brd: module loaded
[ 16.484069] loop: module loaded
[ 16.488342] omap2-nand driver initializing
[ 16.492706] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 25
6MiB 1,8V 16-bit)
[ 16.501892] cmdlinepart partition parsing not available
[ 16.507171] Creating 5 MTD partitions on "omap2-nand":
[ 16.512359] 0x000000000000-0x000000080000 : "X-Loader"
[ 16.518707] 0x000000080000-0x000000260000 : "U-Boot"
[ 16.525085] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 16.531158] 0x000000280000-0x000000680000 : "Kernel"
[ 16.538391] 0x000000680000-0x000010000000 : "File System"
[ 16.643066] usbcore: registered new interface driver catc
[ 16.648498] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 16.654571] usbcore: registered new interface driver kaweth
[ 16.660217] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet dr
iver
[ 16.667846] usbcore: registered new interface driver pegasus
[ 16.673522] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 16.680541] usbcore: registered new interface driver rtl8150
[ 16.686340] usbcore: registered new interface driver asix
[ 16.691864] usbcore: registered new interface driver cdc_ether
[ 16.697845] usbcore: registered new interface driver dm9601
[ 16.703521] usbcore: registered new interface driver smsc95xx
[ 16.709411] usbcore: registered new interface driver gl620a
[ 16.715118] usbcore: registered new interface driver net1080
[ 16.720886] usbcore: registered new interface driver plusb
[ 16.726501] usbcore: registered new interface driver rndis_host
[ 16.732543] usbcore: registered new interface driver cdc_subset
[ 16.738616] usbcore: registered new interface driver zaurus
[ 16.744323] usbcore: registered new interface driver MOSCHIP usb-
ethernet dri
ver
[ 16.752380] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 16.759185] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 16.765197] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus numbe
r 2
[ 16.772827] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 16.790863] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 16.796752] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 16.803619] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=
1
[ 16.810913] usb usb2: Product: OMAP-EHCI Host Controller
[ 16.816253] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 16.821685] usb usb2: SerialNumber: ehci-omap.0
[ 16.826904] hub 2-0:1.0: USB hub found
[ 16.830749] hub 2-0:1.0: 3 ports detected
[ 16.861328] Initializing USB Mass Storage driver...
[ 16.866394] usbcore: registered new interface driver usb-storage
[ 16.872467] USB Mass Storage support registered.
[ 16.877471] mice: PS/2 mouse device common for all mice
[ 16.883087] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 16.890869] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/1-
0049/twl4030_pwrbutton/input/input1
[ 16.901550] i2c /dev entries driver
[ 16.905639] Linux video capture interface: v2.00
[ 16.910583] omap-iommu omap-iommu.0: isp: version 1.1
[ 16.916961] vpfe_init
[ 16.919799] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 17.033508] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card
detect
[ 17.040527] Registered led device: beagleboard::usr0
[ 17.045684] Registered led device: beagleboard::usr1
[ 17.051696] Registered led device: beagleboard::pmu_stat
[ 17.058990] usbcore: registered new interface driver usbhid
[ 17.064636] usbhid: USB HID core driver
[ 17.068664] Advanced Linux Sound Architecture Driver Version
1.0.21.
[ 17.075592] usbcore: registered new interface driver snd-usb-audio
[ 17.152832] No device for DAI omap-mcbsp-dai-0
[ 17.157287] No device for DAI omap-mcbsp-dai-1
[ 17.161804] No device for DAI omap-mcbsp-dai-2
[ 17.166290] No device for DAI omap-mcbsp-dai-3
[ 17.170776] No device for DAI omap-mcbsp-dai-4
[ 17.175262] OMAP3 Beagle SoC init
[ 17.179870] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 17.190979] ALSA device list:
[ 17.193969] #0: omap3beagle (twl4030)
[ 17.197967] oprofile: using arm/armv7
[ 17.201843] TCP cubic registered
[ 17.205139] NET: Registered protocol family 17
[ 17.209655] NET: Registered protocol family 15
[ 17.214233] lib80211: common routines for IEEE802.11 drivers
[ 17.219940] ThumbEE CPU extension supported.
[ 17.224273] Power Management for TI OMAP3.
[ 17.229156] SmartReflex driver initialized
[ 17.241119] VFP support v0.3: implementor 41 architecture 3 part 30
variant c
rev 1
[ 17.249572] registered taskstats version 1
[ 17.254882] fbcvt: 1024x768@60: CVT Name - .786M3-R
[ 17.296661] Console: switching to colour frame buffer device 128x48
[ 17.324005] regulator_init_complete: incomplete constraints,
leaving VAUX3 on
[ 17.331420] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 17.338745] omap_vout omap_vout: probed for an unknown device
[ 17.345001] Waiting for root device /dev/mmcblk0p2...
[ 18.244110] mmc0: new high speed SD card at address 1234
[ 18.249938] mmcblk0: mmc0:1234 SA02G 1.83 GiB
[ 18.254852] mmcblk0: p1 p2
[ 18.341583] EXT2-fs (mmcblk0p2): warning: mounting unchecked fs,
running e2fs
ck is recommended
[ 18.350372] VFS: Mounted root (ext2 filesystem) on device 179:2.
[ 18.358459] devtmpfs: mounted
[ 18.361541] Freeing init memory: 204K
[ 18.369079] Failed to execute /init. Attempting defaults...
INIT: version 2.86 booting
Please wait: booting...
Starting udev
[ 19.008392] EXT2-fs (mmcblk0p2): error: ext2_lookup: deleted inode
referenced
: 31272
cmp: /etc/udev/saved.uname: Input/output error
Remounting root file system...
Caching udev devnodes
Populating dev cache[ 28.600067] EXT2-fs (mmcblk0p2): error:
ext2_lookup: dele
ted inode referenced: 31272
mv: cannot stat '/etc/udev/saved.uname': Input/output error
[ 28.760925] NET: Registered protocol family 10
ALSA: Restoring mixer settings...
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such
device
ifconfig: SIOCGIFFLAGS: No such device
done.
Starting portmap daemon: portmap.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
hwclock: can't open '/dev/misc/rtc': No such file or directory
Thu Dec 16 08:20:00 GMT 2010
INIT: Entering runlevel: 5
Starting Dropbear SSH server: dropbear.
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting syslogd/klogd: done
      > > __ | ---'| '--.| .-'| | |
The Angstrom Distribution beagleboard ttyS2
Angstrom 2010.7-test-20101105 beagleboard ttyS2
beagleboard login:
Its just a guess, but you can try to run “startx” command in console.
2010/12/27 ramo <ramazanfirin@gmail.com>
