Brand new beaglebone freezing
I purchased several beaglebones black wireless and powered them with a 5V, 2A power supply to the microUSB header. However, this problem still exists with 5V barrel power. The BBB will start, Wi-Fi and bluetooth comes on, then after several minutes, the board will freeze to an unusable state (no response until reboot). This is happening on multiple BBB.
Is it possible this is a firmware or software issue? Can I update the image and hope that it will solve the problem?
Here is the output from Serial port:
beaglebone login: [  OK  ] Stopped Light Display Manager.
         Starting Light Display Manager...
[  OK  ] Started Light Display Manager.
[  OK  ] Found device /dev/ttyGS0.
[  OK  ] Started Serial Getty on ttyGS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Created slice User Slice of debian.
         Starting User Manager for UID 1000...
[  OK  ] Started Session 1 of user debian.
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Generic Board Startup.
         Starting BB WL18xx Bluetooth Service...
[  OK  ] Started BB WL18xx Bluetooth Service.
[   89.428880] Unhandled fault: external abort on non-linefetch (0x1028) at 0xf9e00604
[   89.436793] pgd = c0004000
[   89.439700] [f9e00604] *pgd=44e11452(bad)
[   89.444085] Internal error: : 1028 [#1] SMP ARM
[   89.448807] Modules linked in: ccm bnep iptable_filter xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_connt
rack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables x_tables c_can_platform c_can can_dev spi_omap2_mcspi pwm_tiec
ap arc4 wl18xx wlcore hci_uart btbcm btqca bluetooth mac80211 snd_soc_hdmi_codec cfg80211 rfkill snd_soc_simple_card omap_aes_dri
ver omap_sham omap_rng rng_core tilcdc snd_soc_davinci_mcasp snd_soc_edma snd_soc_omap wlcore_sdio snd_soc_core snd_pcm_dmaengine
 snd_pcm snd_timer snd soundcore evdev tda998x uio_pdrv_genirq uio usb_f_mass_storage usb_f_acm u_serial usb_f_ecm usb_f_rndis u_
ether libcomposite spidev tieqep pwm_tiehrpwm pru_rproc pruss_intc pruss
[   89.517761] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.59-ti-r96 #1
[   89.524521] Hardware name: Generic AM33XX (Flattened Device Tree)
[   89.530872] task: c0f9c268 ti: c0f94000 task.ti: c0f94000
[   89.536504] PC is at 0xe0834488
[   89.539862] LR is at 0xe0834434
[   89.543299] pc : [<e0834488>]    lr : [<e0834434>]    psr: 200f0093
[   89.543299] sp : c0f95df8  ip : c0f97a98  fp : 00000002
[   89.555129] r10: 00000000  r9 : ffffffff  r8 : c1064148
[   89.560613] r7 : 000001ff  r6 : cea4afb3  r5 : 0000001d  r4 : 00000009
[   89.567411] r3 : 00000004  r2 : 00000006  r1 : f9e00604  r0 : 0a000023
[   89.574208] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[   89.581712] Control: 10c53879  Table: 9b538019  DAC: 00000051
[   89.587705] Process swapper/0 (pid: 0, stack limit = 0xc0f94218)
[   89.593961] Stack: (0xc0f95df8 to 0xc0f96000)
[   89.598600] 5de0:                                                       00000030 c0f95e4c
[   89.607219] 5e00: cea4afb3 00000014 c1064148 c1048e18 c0f97a98 c0f95e84 c0016df0 9c144000
[   89.615828] 5e20: c0f95e4c 80024640 00000000 00000000 00000000 00000051 80004019 10c5387d
[   89.624440] 5e40: 00000042 00f00000 00000000 e0834400 db76bc40 cea4afb3 00000014 c1064148
[   89.633035] 5e60: c1048e18 c0f97b84 c0f95e84 c0016fbc e0834400 00000009 c0f95e9c c0f95e88
[   89.641650] 5e80: c0032c48 c0016f78 c113bcec 00000009 c0f95eb4 c0f95ea0 c06345a0 c0032c08
[   89.650262] 5ea0: 00000001 00000000 c0f95ec4 c0f95eb8 c00326c0 c063455c c0f95ed4 c0f95ec8
[   89.658878] 5ec0: c0016680 c003268c c0f95eec c0f95ed8 c0874e84 c0016650 daa8a600 00000000
[   89.667493] 5ee0: c0f95f3c c0f95ef0 c0872ba8 c0874e40 00000001 00000000 c1064148 df922b44
[   89.676105] 5f00: cea4afb3 00000014 cea4afb3 00000014 d4ff7d61 00000001 c1064148 c0f97b28
[   89.684725] 5f20: daa8a600 c1048e18 c0a6057c c0f97b84 c0f95f4c c0f95f40 c0872ef0 c0872b04
[   89.693344] 5f40: c0f95f64 c0f95f50 c008bf48 c0872ed8 dc8ba63b c0f94000 c0f95f94 c0f95f68
[   89.701964] 5f60: c008c148 c008bf1c c106380e c0f97b90 c0f91910 c0f8d47c c0f95f68 c1064148
[   89.710584] 5f80: c0a548ec dfdff480 c0f95fa4 c0f95f98 c0a53268 c008bf78 c0f95ff4 c0f95fa8
[   89.719196] 5fa0: c0ed9dc8 c0a531ec ffffffff ffffffff 00000000 c0ed9714 00000000 c0f97a88
[   89.727807] 5fc0: c0f53a28 00000000 00000000 c107c214 c0f97b04 c0f53a24 c0f9d738 80004059
[   89.736106] 5fe0: 413fc082 00000000 00000000 c0f95ff8 8000807c c0ed999c 00000000 00000000
[   89.744670] Code: 1afffffb e3140008 0a000003 e59f10dc (e5912000)
[   89.751029] ---[ end trace 5b0116b5d9711cb1 ]---
[   89.755883] Kernel panic - not syncing: Attempted to kill the idle task!
[   89.762881] ---[ end Kernel panic - not syncing: Attempted to kill the idle task!
Thanks.
Oh fun, care to try something more modern…
Hi Robert,
Thanks for replying so quickly. I indeed tried something more modern, but it seemed like that did not help. The BBB took longer to freeze, but freeze nonetheless.
[ 68.839005] Unhandled fault: external abort on non-linefetch (0x1028) at 0xf9e00004
[ 68.846729] pgd = 9f556494
[ 68.849449] [f9e00004] *pgd=44e11452(bad)
[ 68.853491] Internal error: : 1028 [#1] PREEMPT SMP ARM
[ 68.858740] Modules linked in: aes_arm_bs crypto_simd cryptd xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat wl18xx wlcore mac80211 rfcov
[ 68.897917] CPU: 0 PID: 1800 Comm: irq/160-wl18xx Not tainted 4.19.94-ti-r42 #1buster
[ 68.905780] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 68.911922] PC is at am33xx_clkdm_clk_enable+0x3c/0x54
[ 68.917087] LR is at _clkdm_clk_hwmod_enable+0x74/0xc8
[ 68.922247] pc : [] lr : [] psr: 20000093
[ 68.928540] sp : d9b93a80 ip : d9b93a90 fp : d9b93a8c
[ 68.933786] r10: ffffe000 r9 : c018c878 r8 : c012b278
[ 68.939032] r7 : c1506e08 r6 : dc0bda80 r5 : c161cf9c r4 : c1511b48
[ 68.945586] r3 : 00000004 r2 : f9e00004 r1 : c161ce80 r0 : 00000004
[ 68.952144] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[ 68.959397] Control: 10c5387d Table: 9aef4019 DAC: 00000051
[ 68.965168] Process irq/160-wl18xx (pid: 1800, stack limit = 0xf1d24633)
[ 68.971899] Stack: (0xd9b93a80 to 0xd9b94000)
[ 68.976280] 3a80: d9b93aa4 d9b93a90 c0133f04 c013175c dc0bca80 00000000 d9b93ab4 d9b93aa8
[ 68.984497] 3aa0: c013537c c0133e9c d9b93af4 d9b93ab8 c07ce284 c0135368 dc10b540 a0000093
[ 68.992714] 3ac0: 00000000 c1515cdc 00000000 00000000 c07c33d8 754b2d89 dc0bca80 00000000
[ 69.000931] 3ae0: 00000000 c1515cdc d9b93b14 d9b93af8 c07c33fc c07ce234 dc0bca80 a0000093
[ 69.009147] 3b00: 00000000 c1515cdc d9b93b2c d9b93b18 c07c36a0 c07c3390 c151587c c151587c
[ 69.017364] 3b20: d9b93b3c d9b93b30 c07c36d8 c07c3684 d9b93b54 d9b93b40 c01277b4 c07c36c0
[ 69.025581] 3b40: c151587c c161c9a8 d9b93b7c d9b93b58 c0128b08 c0127788 d9b93b7c d9b93b68
[ 69.033797] 3b60: c151587c c15158c8 a0000013 c012b278 d9b93b9c d9b93b80 c012a554 c0128a48
[ 69.042014] 3b80: 00000000 dc332f00 00000001 c012b278 d9b93bbc d9b93ba0 c012b224 c012a52c
[ 69.050231] 3ba0: dc32fe10 00000000 dc32fe88 c012b278 d9b93bd4 d9b93bc0 c012b298 c012b1e0
[ 69.058448] 3bc0: dc32fe10 00000000 d9b93c0c d9b93bd8 c08eaedc c012b284 d9b93c24 d9b93be8
[ 69.066665] 3be0: c082bd84 dc32fe10 ffffe000 00288040 c012b278 00000004 c018c878 ffffe000
[ 69.074882] 3c00: d9b93c2c d9b93c10 c08eb0a0 c08eae5c dc32fe10 dc2f4810 c1504d00 c012b278
[ 69.083099] 3c20: d9b93c7c d9b93c30 c08eabc8 c08eb048 d9b93c5c c1506e08 d9b93c64 d9b93c48
[ 69.091315] 3c40: c0169bb4 c019aa10 dc32fe88 754b2d89 00000004 dc32fe10 dc32fe88 00000004
[ 69.099533] 3c60: 60000013 00000000 ffffe000 da833c00 d9b93c9c d9b93c80 c08eae38 c08ea518
[ 69.107750] 3c80: 00000000 da833e08 60000013 00000000 d9b93cf4 d9b93ca0 c082bfdc c08eade8
[ 69.115967] 3ca0: d9b93cdc c1506e08 da833e54 db1f6d00 00000000 db1f6d00 c016db68 00000100
[ 69.124184] 3cc0: 00000200 754b2d89 c1507478 da844600 c1506e08 0001fffc db3d5e10 00000004
[ 69.132401] 3ce0: d9ba7040 00000000 d9b93d04 d9b93cf8 c083a6ec c082be08 d9b93d4c d9b93d08
[ 69.140616] 3d00: bf0da2ac c083a6c8 d9b93d34 d9b93d18 c0169bb4 c019aa10 d9990e44 754b2d89
[ 69.148833] 3d20: c1504d00 d9990e20 c1506e08 c1504d00 bf3f1640 d9990e70 d9990e44 bf0da258
[ 69.157049] 3d40: d9b93da4 d9b93d50 bf3cc120 bf0da264 00000000 d9b93d60 ffff1e3f 00000001
[ 69.165266] 3d60: 00000000 00000000 00000000 d9b93d6c d9b93d6c 754b2d89 d9b93da4 db3d5e10
[ 69.173482] 3d80: 00000000 db3d5e88 c08e768c c08e768c c018c878 ffffe000 d9b93db4 d9b93da8
[ 69.181700] 3da0: c08e76c8 bf3cc038 d9b93dec d9b93db8 c08eaedc c08e7698 c08ea9a0 c0d3d0c8
[ 69.189917] 3dc0: d9b93e14 db3d5e10 ffffe000 00208040 c08e768c 00000004 c018c878 ffffe000
[ 69.198135] 3de0: d9b93e0c d9b93df0 c08eb0a0 c08eae5c db3d5e10 da844608 c1504d00 c08e768c
[ 69.206352] 3e00: d9b93e5c d9b93e10 c08eabc8 c08eb048 c017ff9c c1506e08 d9b93e44 d9b93e28
[ 69.214569] 3e20: c0169bb4 c019aa10 db3d5e88 754b2d89 00000004 db3d5e10 db3d5e88 00000004
[ 69.222786] 3e40: 60000013 d9990e20 c01afdf0 00000001 d9b93e7c d9b93e60 c08eae38 c08ea518
[ 69.231003] 3e60: d9990e20 00000001 d9990e70 bf3f1640 d9b93edc d9b93e80 bf3c7fb0 c08eade8
[ 69.239219] 3e80: 60000013 df8fcb00 db1f6d00 db7fad00 daec4e00 00000000 d9b93ec4 754b2d89
[ 69.247437] 3ea0: c0169bb4 d9990e20 d9990e44 d9990e70 d9990e5c d9990e20 d9990e44 d9990e70
[ 69.255653] 3ec0: d9990e5c d9990ff8 c01afdf0 00000001 d9b93f04 d9b93ee0 bf3cc444 bf3c7f64
[ 69.263870] 3ee0: d9b9a840 d99ba300 ffffe000 00000000 d9b9a840 c01afdf0 d9b93f24 d9b93f08
[ 69.272086] 3f00: c01afe1c bf3cc3bc d99ba300 d9b9a864 ffffe000 00000000 d9b93f74 d9b93f28
[ 69.280303] 3f20: c01b0194 c01afdfc c10e6c60 c1506e08 c15dd6a1 d9b93f40 c0d3d4c8 00000000
[ 69.288520] 3f40: c01aff4c 754b2d89 c015ffb0 d9b9a200 d9b9a700 00000000 d9b92000 d9b9a840
[ 69.296737] 3f60: c01b0030 da857d84 d9b93fac d9b93f78 c01604c0 c01b003c d9b9a21c d9b9a21c
[ 69.304954] 3f80: 00000000 d9b9a700 c0160354 00000000 00000000 00000000 00000000 00000000
[ 69.313171] 3fa0: 00000000 d9b93fb0 c01010e8 c0160360 00000000 00000000 00000000 00000000
[ 69.321388] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 69.329604] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 69.337835] [] (am33xx_clkdm_clk_enable) from [] (_clkdm_clk_hwmod_enable+0x74/0xc8)
[ 69.347365] [] (_clkdm_clk_hwmod_enable) from [] (clkdm_clk_enable+0x20/0x2c)
[ 69.356296] [] (clkdm_clk_enable) from [] (_omap4_clkctrl_clk_enable+0x5c/0x164)
[ 69.365489] [] (_omap4_clkctrl_clk_enable) from [] (clk_core_enable+0x78/0x2f4)
[ 69.374580] [] (clk_core_enable) from [] (clk_core_enable_lock+0x28/0x3c)
[ 69.383148] [] (clk_core_enable_lock) from [] (clk_enable+0x24/0x28)
[ 69.391289] [] (clk_enable) from [] (_enable_clocks+0x38/0xc0)
[ 69.398898] [] (_enable_clocks) from [] (_enable+0xcc/0x2b0)
[ 69.406330] [] (_enable) from [] (omap_hwmod_enable+0x34/0x54)
[ 69.413940] [] (omap_hwmod_enable) from [] (omap_device_enable+0x50/0xa4)
[ 69.422507] [] (omap_device_enable) from [] (_od_runtime_resume+0x20/0x50)
[ 69.431169] [] (_od_runtime_resume) from [] (__rpm_callback+0x8c/0x1ec)
[ 69.439563] [] (__rpm_callback) from [] (rpm_callback+0x64/0x90)
[ 69.447343] [] (rpm_callback) from [] (rpm_resume+0x6bc/0x8d0)
[ 69.454949] [] (rpm_resume) from [] (__pm_runtime_resume+0x5c/0x74)
[ 69.462995] [] (__pm_runtime_resume) from [] (__mmc_claim_host+0x1e0/0x230)
[ 69.471740] [] (__mmc_claim_host) from [] (sdio_claim_host+0x30/0x48)
[ 69.479979] [] (sdio_claim_host) from [] (wl12xx_sdio_raw_write+0x54/0x1b4 [wlcore_sdio])
[ 69.490236] [] (wl12xx_sdio_raw_write [wlcore_sdio]) from [] (wlcore_runtime_resume+0xf4/0x224 [wlcore])
[ 69.501622] [] (wlcore_runtime_resume [wlcore]) from [] (pm_generic_runtime_resume+0x3c/0x48)
[ 69.511937] [] (pm_generic_runtime_resume) from [] (__rpm_callback+0x8c/0x1ec)
[ 69.520942] [] (__rpm_callback) from [] (rpm_callback+0x64/0x90)
[ 69.528723] [] (rpm_callback) from [] (rpm_resume+0x6bc/0x8d0)
[ 69.536331] [] (rpm_resume) from [] (__pm_runtime_resume+0x5c/0x74)
[ 69.544457] [] (__pm_runtime_resume) from [] (wlcore_irq_locked+0x58/0x79c [wlcore])
[ 69.554139] [] (wlcore_irq_locked [wlcore]) from [] (wlcore_irq+0x94/0x188 [wlcore])
[ 69.563757] [] (wlcore_irq [wlcore]) from [] (irq_thread_fn+0x2c/0x88)
[ 69.572065] [] (irq_thread_fn) from [] (irq_thread+0x164/0x234)
[ 69.579760] [] (irq_thread) from [] (kthread+0x16c/0x174)
[ 69.586934] [] (kthread) from [] (ret_from_fork+0x14/0x2c)
[ 69.594187] Exception stack(0xd9b93fb0 to 0xd9b93ff8)
[ 69.599261] 3fa0: 00000000 00000000 00000000 00000000
[ 69.607477] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 69.615692] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 69.622341] Code: e1d001b0 e5912004 e0833000 e0822003 (e5923000)
[ 69.628468] —[ end trace b4fa4b1e88e3e5d0 ]—
[ 69.633364] note: irq/160-wl18xx[1800] exited with preempt_count 3
[ 69.639650] genirq: exiting task “irq/160-wl18xx” (1800) is an active IRQ thread (irq 160)
Please retest with something more recent…
Hi Robert,
I am obtaining the images from BeagleBoard.org - latest-images
When I download the image for " [AM3358 Debian 10.3 2020-04-06 4GB SD IoT]" and wrote it into an SD card using Balenaetcher, the beaglebone does not respond to the package. There is no LED running back and forth shown when flashing.
Thus, I used " [AM3358 Debian 10.3 2020-04-06 4GB eMMC IoT Flasher]", which was posted above.
I can’t upgrade the BBB using terminal since it freezes before I can do anything.
@Martin13 no idea… looks like a bug in the wl18xx driver with 4.19.94-ti-r42, which was released on (Commits on Mar 31, 2020)…
The v4.19-ti branch is now at: 4.19.94-ti-r72 (Commits on Mar 8, 2022)
Feel free to test the “iot snapshot” from: Debian 10.x (Buster) - Monthly Snapshots to see if that bug has been fixed as that ships with 4.19.94-ti-r72 …
There is also a really small chance u-boot is really old… Do you have the usb ftdi adapter to be plugged into J1 so we can see a full bootup?
Hi Robert,
Sorry for the late reply.
Using the debugger cable, this is the output from a Beaglebone wireless board while booting from a SD card with the latest image bone-debian-10.12-iot-armhf-2022-04-01-4gb.img
The Wi-Fi and Bluetooth led lights were on. The four heartbeat leds blinked until they froze to an off, on, off, off pattern.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.04.29 12:36:12 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot SPL 2019.04-g923f8b8 (Jan 02 2022 - 19:05:15 +0000)
Trying to boot from MMC1
Loading Environment from EXT4… ** File not found /boot/uboot.env **
** Unable to read “/boot/uboot.env” from mmc0:1 **
U-Boot 2019.04-g923f8b8 (Jan 02 2022 - 19:05:15 +0000)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBoard.org BeagleBone Black Wireless:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth0: MII MODE
Could not get PHY for cpsw: addr 0
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[BBBW] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
2023 bytes read in 35 ms (55.7 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.19.94-ti-r72 …
10170880 bytes read in 670 ms (14.5 MiB/s)
debug: [enable_uboot_overlays=1] …
debug: [enable_uboot_cape_universal=1] …
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] …
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] …
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb …
loading /boot/dtbs/4.19.94-ti-r72/am335x-boneblack-uboot-univ.dtb …
167492 bytes read in 134 ms (1.2 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r72/overlays/BB-ADC-00A0.dtbo …
645 bytes read in 87 ms (6.8 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r72/overlays/BB-BONE-eMMC1-01-00A0.dtbo …
1605 bytes read in 78 ms (19.5 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r72/overlays/BB-HDMI-TDA998x-00A0.dtbo …
5321 bytes read in 105 ms (48.8 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r72/overlays/BB-BBBW-WL1835-00A0.dtbo …
3261 bytes read in 92 ms (34.2 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r72/overlays/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo …
3627 bytes read in 91 ms (38.1 KiB/s)
loading /boot/initrd.img-4.19.94-ti-r72 …
7413511 bytes read in 499 ms (14.2 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] …
debug: [bootz 0x82000000 0x88080000:711f07 88000000] …
Loading Ramdisk to 8f8ee000, end 8fffff07 … OK
Loading Device Tree to 8f861000, end 8f8edfff … OK
Starting kernel …
[ 0.002290] timer_probe: no matching timers found
[ 0.202767] l4_wkup_cm:clk:0010:0: failed to disable
[ 1.524270] omap_voltage_late_init: Voltage driver support not added
Debian GNU/Linux 10 beaglebone ttyS0
BeagleBoard.org Debian Buster IoT Image 2022-04-01
Support: BeagleBoard.org - debian
default username:password is [debian:temppwd]
beaglebone login: [ 47.591450] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 67.606262] Unhandled fault: external abort on non-liîefetch (0x1028) at 0xf9e00c08
[ 67.613946] pgd ½ 016f2f7f
[ 67.616638] [f9e°0c08] *pgd=44e11452(bad)
[ 67.620642] Internal error: : 1028 [#1] PREEMPT SMP ARM
[ 67.625874] Modules linked in: aes_arm_bs crypto_simd cryptd xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc rfcomm bnep pruss pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc virtio virtio_ring pruss_soc_bus hci_uart btqca btbcm btintel bluetooth ecdh_generic wlcore_sdio usb_f_acm u_serial usb_f_ncm uio_pdrv_genirq uio usb_f_mass_storage usb_f_rndis u_ether libcomposite spidev
[ 67.666601] CPU: 0 PID: 1139 Comm: irq/148-wl18xx Not tainted 4.19.94-ti-r72 #1buster
[ 67.674419] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 67.680559] PC is at am33xx_pwrdm_read_pwrst+0x30/0x3c
[ 67.685725] LR is at _pwrdm_state_switch+0x54/0x39c
[ 67.690619] pc : [] lr : [] psr: a0070093
[ 67.696897] sp : da43bab0 ip : da43bac0 fp : da43babc
[ 67.702143] r10: ffffe000 r9 : c018c878 r8 : c012b278
[ 67.707391] r7 : c161e54c r6 : c1511c08 r5 : 00000000 r4 : c150e250
[ 67.713942] r3 : f9e00c08 r2 : 00000c08 r1 : c161e404 r0 : 00000008
[ 67.720495] Flags: NzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[ 67.727742] Control: 10c5387d Table: 9c7f8019 DAC: 00000051
[ 67.733529] Process irq/148-wl18xx (pid: 1139, stack limit = 0x4246166a)
[ 67.740260] Stack: (0xda43bab0 to 0xda43c000)
[ 67.744639] baa0: da43baf4 da43bac0 c01330f0 c0130e04
[ 67.752839] bac0: df8f8b00 db162d00 da1c9e00 c150e250 00000000 c1511c08 c1515d9c c012b278
[ 67.761021] bae0: c018c878 ffffe000 da43bb0c da43baf8 c013366c c01330a8 c1511c08 00000000
[ 67.769237] bb00: da43bb24 da43bb10 c0134e18 c013362c c1511c08 c161df68 da43bb3c da43bb28
[ 67.777454] bb20: c013506c c0134db4 c1511c08 c161df68 da43bb54 da43bb40 c01350c4 c0134fe0
[ 67.785669] bb40: c151593c c161df68 da43bb7c da43bb58 c0128aec c01350a8 da43bb7c da43bb68
[ 67.793886] bb60: c151593c c1515988 a0070013 c012b278 da43bb9c da43bb80 c012a554 c0128a48
[ 67.802103] bb80: 00000000 dc33e2c0 00000001 c012b278 da43bbbc da43bba0 c012b224 c012a52c
[ 67.810319] bba0: dc33fa10 00000000 dc33fa88 c012b278 da43bbd4 da43bbc0 c012b298 c012b1e0
[ 67.818530] bbc0: dc33fa10 00000000 da43bc0c da43bbd8 c08eb2e4 c012b284 c0169bb4 c019aa10
[ 67.826747] bbe0: da43bd40 dc33fa10 ffffe000 00288040 c012b278 00000004 c018c878 ffffe000
[ 67.834955] bc00: da43bc2c da43bc10 c08eb4a8 c08eb264 dc33fa10 dc314e10 c1504d00 c012b278
[ 67.843169] bc20: da43bc7c da43bc30 c08eafd0 c08eb450 da43bc5c c1506e08 da43bc64 da43bc48
[ 67.851360] bc40: c0169bb4 c019aa10 dc33fa88 76429d26 00000004 dc33fa10 dc33fa88 00000004
[ 67.859576] bc60: 60070013 00000000 ffffe000 da9a9c00 da43bc9c da43bc80 c08eb240 c08ea920
[ 67.867793] bc80: 00000000 da9a9e08 60070013 00000000 da43bcf4 da43bca0 c082c3e0 c08eb1f0
[ 67.876010] bca0: da43bccc c1506e08 da9a9e54 db162d00 00000000 db162d00 c016db68 00000100
[ 67.884223] bcc0: 00000200 76429d26 c0839980 dab35200 c1506e08 0001fffc db6d6010 00000004
[ 67.892425] bce0: da507480 00000000 da43bd04 da43bcf8 c083aaf0 c082c20c da43bd4c da43bd08
[ 67.900641] bd00: bf0da2ac c083aacc da43bd34 da43bd18 c0169bb4 c019aa10 db74ce44 76429d26
[ 67.908866] bd20: c1504d00 db74ce20 c1506e08 c1504d00 bf4e4640 db74ce70 db74ce44 bf0da258
[ 67.917082] bd40: da43bda4 da43bd50 bf4bf0f0 bf0da264 00000000 da43bd60 ffff1d0b 00000001
[ 67.925298] bd60: 00000000 00000000 00000000 da43bd6c da43bd6c 76429d26 da43bda4 db6d6010
[ 67.933508] bd80: 00000000 db6d6088 c08e7a94 c08e7a94 c018c878 ffffe000 da43bdb4 da43bda8
[ 67.941712] bda0: c08e7ad0 bf4bf008 da43bdec da43bdb8 c08eb2e4 c08e7aa0 c08eada8 c0d45188
[ 67.949929] bdc0: da43be14 db6d6010 ffffe000 00208040 c08e7a94 00000004 c018c878 ffffe000
[ 67.958146] bde0: da43be0c da43bdf0 c08eb4a8 c08eb264 db6d6010 dab35208 c1504d00 c08e7a94
[ 67.966360] be00: da43be5c da43be10 c08eafd0 c08eb450 c017ff9c c1506e08 da43be44 da43be28
[ 67.974577] be20: c0169bb4 c019aa10 db6d6088 76429d26 00000004 db6d6010 db6d6088 00000004
[ 67.982794] be40: 60070013 db74ce20 c01afdf0 00000001 da43be7c da43be60 c08eb240 c08ea920
[ 67.991008] be60: db74ce20 00000001 db74ce70 bf4e4640 da43bedc da43be80 bf4bafb0 c08eb1f0
[ 67.999224] be80: 60070013 df8f8b00 db162d00 da1c9e00 da147e00 da147e00 da43bec4 76429d26
[ 68.007440] bea0: c0169bb4 db74ce20 db74ce44 db74ce70 db74ce5c db74ce20 db74ce44 db74ce70
[ 68.015656] bec0: db74ce5c db74cff8 c01afdf0 00000001 da43bf04 da43bee0 bf4bf414 bf4baf64
[ 68.023871] bee0: da507100 da331900 ffffe000 00000000 da507100 c01afdf0 da43bf24 da43bf08
[ 68.032087] bf00: c01afe1c bf4bf38c da331900 da507124 ffffe000 00000000 da43bf74 da43bf28
[ 68.040296] bf20: c01b0194 c01afdfc c10ec370 c1506e08 c15deaa1 da43bf40 c0d45588 00000000
[ 68.048513] bf40: c01aff4c 76429d26 c015ffb0 da507680 da507940 00000000 da43a000 da507100
[ 68.056730] bf60: c01b0030 dc305d84 da43bfac da43bf78 c01604c0 c01b003c da50769c da50769c
[ 68.064947] bf80: 00000000 da507940 c0160354 00000000 00000000 00000000 00000000 00000000
[ 68.073163] bfa0: 00000000 da43bfb0 c01010e8 c0160360 00000000 00000000 00000000 00000000
[ 68.081379] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.089596] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 68.097826] [] (am33xx_pwrdm_read_pwrst) from [] (_pwrdm_state_switch+0x54/0x39c)
[ 68.107096] [] (_pwrdm_state_switch) from [] (pwrdm_state_switch_nolock+0x4c/0x58)
[ 68.116451] [] (pwrdm_state_switch_nolock) from [] (clkdm_wakeup_nolock+0x70/0xcc)
[ 68.125804] [] (clkdm_wakeup_nolock) from [] (clkdm_deny_idle_nolock+0x98/0xc8)
[ 68.134895] [] (clkdm_deny_idle_nolock) from [] (clkdm_deny_idle+0x28/0x34)
[ 68.143621] [] (clkdm_deny_idle) from [] (_enable+0xb0/0x2b0)
[ 68.151142] [] (_enable) from [] (omap_hwmod_enable+0x34/0x54)
[ 68.158749] [] (omap_hwmod_enable) from [] (omap_device_enable+0x50/0xa4)
[ 68.167315] [] (omap_device_enable) from [] (_od_runtime_resume+0x20/0x50)
[ 68.175978] [] (_od_runtime_resume) from [] (__rpm_callback+0x8c/0x1ec)
[ 68.184372] [] (__rpm_callback) from [] (rpm_callback+0x64/0x90)
[ 68.192153] [] (rpm_callback) from [] (rpm_resume+0x6bc/0x8d0)
[ 68.199760] [] (rpm_resume) from [] (__pm_runtime_resume+0x5c/0x74)
[ 68.207807] [] (__pm_runtime_resume) from [] (__mmc_claim_host+0x1e0/0x230)
[ 68.216553] [] (__mmc_claim_host) from [] (sdio_claim_host+0x30/0x48)
[ 68.224790] [] (sdio_claim_host) from [] (wl12xx_sdio_raw_write+0x54/0x1b4 [wlcore_sdio])
[ 68.235042] [] (wl12xx_sdio_raw_write [wlcore_sdio]) from [] (wlcore_runtime_resume+0xf4/0x224 [wlcore])
[ 68.246423] [] (wlcore_runtime_resume [wlcore]) from [] (pm_generic_runtime_resume+0x3c/0x48)
[ 68.256739] [] (pm_generic_runtime_resume) from [] (__rpm_callback+0x8c/0x1ec)
[ 68.265743] [] (__rpm_callback) from [] (rpm_callback+0x64/0x90)
[ 68.273525] [] (rpm_callback) from [] (rpm_resume+0x6bc/0x8d0)
[ 68.281132] [] (rpm_resume) from [] (__pm_runtime_resume+0x5c/0x74)
[ 68.289260] [] (__pm_runtime_resume) from [] (wlcore_irq_locked+0x58/0x79c [wlcore])
[ 68.298941] [] (wlcore_irq_locked [wlcore]) from [] (wlcore_irq+0x94/0x188 [wlcore])
[ 68.308557] [] (wlcore_irq [wlcore]) from [] (irq_thread_fn+0x2c/0x88)
[ 68.316865] [] (irq_thread_fn) from [] (irq_thread+0x164/0x234)
[ 68.324560] [] (irq_thread) from [] (kthread+0x16c/0x174)
[ 68.331734] [] (kthread) from [] (ret_from_fork+0x14/0x2c)
[ 68.338988] Exception stack(0xda43bfb0 to 0xda43bff8)
[ 68.344062] bfa0: 00000000 00000000 00000000 00000000
[ 68.352273] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.360488] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 68.367138] Code: e5d0008d e5913004 e0822000 e0833002 (e5930000)
[ 68.373265] —[ end trace 74e8344eb5fcc2cb ]—
[ 68.378137] note: irq/148-wl18xx[1139] exited with preempt_count 2
[ 68.384420] genirq: exiting task “irq/148-wl18xx” (1139) is an active IRQ thread (irq 148)
