Anybody know of breakout boards for the Beagleboard?
I don’t. Depending on what it is you want access to, there is a Zippy board that brings some of the expansion interfaces out.
http://www.tincantools.com/home.php?cat=255
2009/12/5 akamlani <akamlani@gmail.com>
What are you trying to get access to? Beagleboard has most of the connections one would want already, including headers for general expansion and LCD.
There are a number of expansion / add-on boards that give additional peripherals - such as Tin Can Tools Zippy which gives Ethernet, a second MMC card, a second RS232, and 5v I2C; or BeagleBoard Toys’ VGA adaptor which is a one-trick pony.
I understand the next rev (C4) of BeagleBoard will have a header for the camera interface - it is inaccessible on the existing design.
Then there are a number of boards in the works including a Trainer breakout board from Tin Can Tools (which might be the kind of thing you are looking for: http://elinux.org/BeagleBoard_Trainer).
C4 will NOT have a header for the camera interface. The C4 is exactly the same as the rev C3, with a 720MHZ processor and a change in the EHCI PHY power arrangement.
