I couldn't get analogwrite to work on P9_31 or 14, so I naively tried upgrading bonescript to see if that was the problem. Upgrade failed and now BBB can't find bonescript at all.
Here are my errors, I don't know if it's a node issue or what. Im running debian 3.8 kernel, on a rev A6A or whatever was before rev B.
ref@1.3.2 install /usr/local/lib/node_modules/bonescript/node_modules/ffi/node_modules/ref
node-gyp rebuild
make: Entering directory /usr/local/lib/node_modules/bonescript/node_modules/ffi/node_modules/ref/build' CXX(target) Release/obj.target/binding/src/binding.o In file included from ../src/binding.cc:7:0: ../node_modules/nan/nan.h:328:47: error: ‘REPLACE_INVALID_UTF8’ is not a member of ‘v8::String’ make: *** [Release/obj.target/binding/src/binding.o] Error 1 make: Leaving directory/usr/local/lib/node_modules/bonescript/node_modules/ffi/node_modules/ref/build'
gyp ERR! build error
gyp ERR! stack Error: make failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
gyp ERR! stack at ChildProcess.emit (events.js:98:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:809:12)
gyp ERR! System Linux 3.8.13-bone70
gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /usr/local/lib/node_modules/bonescript/node_modules/ffi/node_modules/ref
gyp ERR! node -v v0.10.29
gyp ERR! node-gyp -v v0.12.2
gyp ERR! not ok
npm WARN This failure might be due to the use of legacy binary "node"
npm WARN For further explanations, please read
/usr/share/doc/nodejs/README.Debian
npm ERR! ref@1.3.2 install: node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the ref@1.3.2 install script.
npm ERR! This is most likely a problem with the ref package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get their info via:
npm ERR! npm owner ls ref
npm ERR! There is likely additional logging output above.
npm ERR! System Linux 3.8.13-bone70
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "bonescript"
npm ERR! cwd /root
npm ERR! node -v v0.10.29
npm ERR! npm -v 1.4.21
npm ERR! code ELIFECYCLE
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /root/npm-debug.log
npm ERR! not ok code 0
